Question about Maytag MER5775Q Electric Kitchen Range
Indicator Light My kitchen range indicator light stays on at all times. Do you know what may be causing this? Thanks.
  • 76 Answers
If your referring to the one that indicates that one of the burners is on. Then your problem is one of your burner switches is starting to go bad. To find out which one. Open the back and with the unit unpluged you will notice that all the switches are wired to the light. Disconnect the wire from one of the switches and plug unit back in to see if that corrected the problem. If it did .. that is your bad switch, if it's still on disconnect your power and try the next switch until you find the switch that causes your problem. That switch will have to be replaced.
Posted on Jul 21, 2007
Hot surface indicator light stay on?
One of your surface elements is bad (the hot-element switch that is part of the element is stuck on). If each element has its own hot-light, then you know which element is bad; but if you have just 1 hot-surface indicator, your problem is figuring out which element is bad. That takes an electronic technician with patience and an ohmmeter.
Sep 24, 2014 | Whirlpool RF378LXKS Electric Kitchen Range
Indicator is on and all elements are off
The hot indicator light will stay on until the burners cool down. If they are cool and the light has not shut off, there is a short in the light or the main circuit board.
Feb 05, 2013 | Amana ACF4225AS Electric Kitchen Range
Range indicator light doesn't shut off
the poles for the light are reversed or miswired
at the selector switch
make sure the light goes back to p1 or p depending on your switch
Oct 09, 2009 | Kitchen Ranges
One cooktop circle doesn't heat. Heat indicator light always on.
this could be cause by a faulty infinite switch,or the heating element has burned out
Sep 19, 2009 | Kitchen Ranges
Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
May 30, 2009 | Kitchen Ranges
The hot surface indicator light remains ON all the time.
Your hot surface indicator light might have a short that causes it to stay on all of the time. If you can, try unplugging it for a little while and plugging it back up. If the light is still on, you have a short. You can still use the stove, but the light staying on will not be any help to you.
Oct 22, 2008 | Frigidaire FEF366EC 30" Freestanding...
Kenmore ultra bake cook top indicator light
is there multiple lights(one for each burner?) of so thers an issue with the sensor on the element and the element would need to be replaced, check your manual generally a loner possibly 5 year warr on elemnts
Apr 09, 2008 | Kenmore 92022 / 92024 / 92025 / 92029...
Cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Mar 08, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
The component that controls the hot surface light is part of the element. If there is a light for each element you just replace that element. If there's one for the whole surface or each side you'll have to figure out which element is causing the problem.
Oct 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER5775Q Electric Kitchen Range Logo
333 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
