Question about Proview PL926WBi 19" LCD Monitor
Screen goes black
I turn on my screen...picture looks good for like 3 seconds then dissapears. black. blue light still stays on though. what board is it that needs to be replaced?
  • 3 more comments
  • djxfinity Dec 27, 2008
    thanks man. is there another name for that board im having trouble finding one
  • mphuston Dec 31, 2008
    monitor screen comes on and goes black in 3 or so secs but the blue light stays on.
  • Anonymous Jan 04, 2009
    the screen on my lcd monitor goes blank after about 3 seconds. the light still is blue though.
  • peggyrudd1 Jan 09, 2009
    The monitor comes on fro about 5 seconds and the screen goes blank. The power remains on. If I replace the car, does that fix the problem?
    Thanks,
    Peggy
  • marlaa Mar 18, 2009
    The Proview stays on for about 10 seconds and then appears to go black. Blue power light is still on. If you look really close, I can still see my screen, but very faint. I unplugged it from one pc and into another. Exact same problem. Does this rule out the video card then?
It is probably the 6 450uf capasitors on the inverter board.
Buy a new board or replace the 6 blown capasitors.
Ive fixed 4 other proviews the same way. They all have the same cheap xunda caps.
Posted on Jan 10, 2009
  • 741 Answers
The video adapter board is what controls the monitor. If you are going to replace a board that would be the one.
Posted on Dec 27, 2008
  • Randall  Trahan
    Randall Trahan Dec 27, 2008
    Yes you can find the exact make and model of yours. Go into Device manager Start>Right-Click on My Computer>Hardware Tab>Device Manager. Look for Sound cards, right click on the sound card and it will give you the make and model. If problems let me know.
  • Randall  Trahan
    Sorry not Sound card I met to say Video card..my bad...but same place same way.
I recently bought a Hp Lcd w1907 Monitor off craigslist, the screen worked fine for about an hour then went black, button stays blue. Now every time I power on the monitor it stays lit for 3 seconds...
hi the cause is screen back light not working properly. you need to remove the back cover of the monitor to access the internal part of the monitor. then look for the connector of the cold cathode fluorescent tube back light going to the power inverter board of the back light you will noticed a dry joints which cause a loose connection that is why you hear a sound that cause of spark. you need to re soldered the connector or replaced if totally burned.
Nov 08, 2012 | HP w1907 LCD Monitor
Turns on but dosn't show any video sounds like it wants to start but only the blue power light stay on got sound but screen stays black
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Oct 08, 2010 | HP Pavilion dv6000t Notebook
I cant get the svideo to stay on after initial startup
Did you try pressing the FN (function) key and F8?
F8 should have what looks like a computer or tv on it in blue.
Hope that works!
Mar 01, 2010 | Dell Latitude C600 Notebook
Our television just began having what looks like a 'double screen'...or the picture has a 'shadow'...and also looks as though the entire screen 'curves' ..at the top and bottom of the screen it is...
Hi
Thanks for using FixYa. First of all please check whether all the cables from your dish network are fine and connected firmly. If yes then you'll need to pull off the front of the TV, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage the tube. So you need to do only a small adjustment. Turn the color off on the TV and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittent blue picture tube, a bad blue driver transistor on the CRT board, a bad connection on the blue CRT board or a problem in the RGB coming from the video jungle IC. The price to resolve the issue will most likely run you about 300 to 500 bucks, unless it is the picture tube.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Sony Televison & Video
No picture
Hi
You have parts on the power supply board which are going bad. You can send it to a company like mine or take it to a local repair person.
Aug 05, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Mar 01, 2009 | Sanyo DP32746 32 in. LCD Television
Gateway Monitor FPD1760
Power light coming on when you plug it in but no lighting of the screen is usually caused by the power inverter board having gone bad. Common on the 17s due to their age is a bad bulb or more.
I repair these 90% of the time
bammbamm@ptd.net
Jun 27, 2008 | Gateway FPD2275W LCD Monitor
A17w221 goes off automatically with power on
I have the same problem. The next stage is that the picture won't come on at all and the blue light will constantly blink. I think the light source is bad. Noit sure though.
Mar 25, 2008 | Envision A17W221 Television
The picture disapears, though the monitors stays on - every few seconds
Check the cable connections on the back of the monitor and the PC it sounds like the connection isn't made properly make sure they are tight.
Oct 28, 2006 | BenQ FP71E+ (Black, Silver) (Silver,...
Proview PL926WBi 19" LCD Monitor Logo
178 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
