Question about Malber WD1000 Front Load Washer/Dryer
Need service manual for Malber WD800
My Malber WD800 doesn't heat up during dry cycle... I know it's probably the heating elements, and as an engineer and avid DIYer I'm prepared to replace them myself, I'm looking for help in locating a service manual to show me where they're located, and therefore the recommended way to disassemble the unit etc...
I can't seem to find this manual online anywhere...
thanks in advance for the help!
4 Suggested Answers
  • 55 Answers
SOURCE: Malber WD800 - Will not fill
The thing making noise is probably the inlet valve, not the pump. The pump pumps the used water out the drain hose. Anyway, if the noise happens when water is trying to come in, the inlet valve is probably faulty. Onw way to get around this without repair is this: If you are hooking up to the sink, that means you are using only one hose to the machine. The other inlet to machine is probably capped off. Remove the cap, and the hose to the respective inlets, and reverse. You will probably have to change your water temp selectors on the front of the machine. If this makes it run OK, then you can later buy an inlet valve and replace at your leisure. For parts call 718-767-7396 in NY. I hope they will ship to where you are. Good luck and let me know what happens.
Posted on Mar 21, 2008
  • 55 Answers
SOURCE: MALBER WD 800 WASHING MACHINE USER MANUAL
Sorry, I don't know what your question/problem is. If you need a manual, I have one for WD 1000, but not for WD 800.
Posted on May 06, 2008
  • 29 Answers
SOURCE: Need service for Malber 1000 heating element..
Hi. Mike here. I repair Malbers in the Washington D.C. area. The most likely problem is not the heating element, but the hi-temp (or "brown") thermostat. They cost about $25 and are very simple to install. A "Torx 1.5" screwdriver (asterisk tip) removes two screws, in back, holding top on. Lift off top, and (from the front) see silver-foil-wrapped heating assy. At lower right will be a small philips screw holding a thin wire "hasp" which holds the thermostat in place. Remove screw and hasp (without dropping in machine!), unplug two "quiik-connect" lugs (orange & red wires) and pull out thermostat to the right. New one slips right back in. Replace wires, hasp, phillips screw and top -and you're done! This is 90% sure to fix. The heating element is only about 5% likely.
One last thing ... when re-inserting new thermostat, you'll have to "wrestle" with it a bit, as the tip needs to slip into a tiny (hard to "find") hole. Keep trying, and eventually it'll fit ALL the way in, so the hasp can hold it. To purchase part, call Joel (at Malber): 800-600-8913
Oh yeah, one MORE last thing... That red wire may be burnt a little, or completely burnt in two. Radio Shack and Home Depot sell "crimp-on" lugs (1/4") like these (female). Trim back the wire, crimp a new lug on the end, and push it back onto lower terminal on thermostat. If wire is too short, of course, add a few inches of 16 guage "stranded" (lamp cord). The same stores also sell tubular "crimp-on" wire-connectors (little blue tubes) to join the old and new wires. May God bless.
Posted on Mar 11, 2009
Water comes in on dry cycle
this could be normal, flushing the lint out of the drain hose. Mine does that as well. i find lint in the grey water tank. I live on my boatfull time. My heat has gone out now. cant determine if :its the thermostat or the heating element.
Oct 01, 2013 | Malber WD1000 Front Load Washer/Dryer
No longer heats during dry
HELLO THERE:
if you have cleaned all of the lint from the filter and still no luck you are goiong to be looking at replacing the heating element.
contact your local appliance repair for this part and a price ok?
best regards mike
Aug 09, 2009 | Malber WD1000 Front Load Washer/Dryer
Not drying dishes
Without knowing the make and model of your dishwasher, the most probable causes of no drying is:
1.) RinseAid being empty or not dispensing (as in you never seem to have to refill the dispenser.)
2.) The Heating element has failed. But if it has failed, you would also have foggy, film on your glassware.
3.) The timer is failing to turn on the heating element during the (at least) the heating element during drying cycle.
Good Luck!
Apr 06, 2009 | Dishwashers
Mar 02, 2009 | Malber WD1000 Front Load Washer/Dryer
Heats but won't dry
I'm not at all familiar with the Malber brand, but I do know that the basics any dryer needs to work are: 1. Heat 2. tumbling (so the air can reach all areas of the wet clothes) and 3. air flow, so the moist air is removed from the dryer.
The number one cause of poor or no drying is poor air flow. Check the end of the vent outside to see if you are getting a strong flow of air out when the dryer is running. I'll bet you are not. Find out why and correct. (clean out lint, reduce or better yet eliminate any flex duct, try to make vent pipe as short and straight as possible, use a dryer vent end cap which has a large opening, etc.)
Nov 02, 2008 | Malber WD1000 Front Load Washer/Dryer
Malber WD 1000 takes four plus hours to dry one load
i would check the thermostat and heating element. one or the other is not on enouph to dry your clothes.
Aug 14, 2008 | Malber WD1000 Front Load Washer/Dryer
Forgot how to use
Doing a Load of Wash for Portable/ Kitchen Faucet
1) Make sure machine is set to Cold/Cold and never use Hot/Cold button (Hot/Cold is only for permanent hook-ups). Connect water hose to kitchen faucet. Turn on water to temperature of choice.
2) Load machine half to three-fourths full of clothes. (only half full is recommended if you intend to use the dry cycle right after the wash cycle. For half loads, push in the half-load button. )
3) Add detergent and fabric softener:
a. Liquid detergent into 2nd slot: only 1 tablespoon, 2 tablespoons maximum
b. Fabric softener into 3rd slot. this really helps in preventing wrinkles
(****NOTE: THE MOST COMMON AND MOST DAMAGING ERROR IN THE USE OF FRONT-LOADING MACHINES IS OVERSOAPING. oversoaping causes - pump failure, drain failure, etc. - none of
which are covered by the warranty. The only reason top
loaders use so much soap is because they use so much water and this dilutes the soap. Also, always use detergents that have an HE -- High Efficiency -- rating.)
4) Select Wash Cycle
Permanent Press is likely to be fine (32 minutes) as the USA has softer water than in Europe for which machine was originally designed. Hard water, as in Europe, means it requires more detergent and more washing motion than in the USA. Prewash and/or Superwash (53 minutes) might be preferred for dirtier clothes.
5) Select Spin Cycle
600 should be fine. A higher cycle means dryer clothes, perhaps more wrinkles, and certainly more noise. (Malber USA suggests 800-900 as the norm).
6) Make sure Spin cycle has cold water.
Faucet should be changed to cold water AFTER the initial fill even if you are not drying - all rinses should be in cold water for more complete removal of soap residue
If you use Dry Cycle
7) Select time for desired dry cycle. Make sure to change the faucet to cold water. If you do not want to use Dry cycle, select 0 minutes. Otherwise, use 120 minutes the first time until you can gauge what types of loads require how much drying time. Here's how the Dryer works: A heating element inside the washer heats up the load. During the dry cycle, as the cold water from the faucet circulates into the machine (in tubes, not mixed in with the load), it cools the steam and condenses it into liquid water which is pumped out.
After Wash & Dry
8) It takes approximately 90 seconds after the cycles are completely done before it allows you to open the door. Malber USA says it is due to safety requirement of UL. Who knows what UL security feature is for. Perhaps extra time to finish draining.
9) door slightly ajar to let the machine dry out. I have read postings that say the machine becomes smelly with mildew if you do not. Malber USA says this is true for all horizontal axis (front-loading) washers.
Most common complaints
1) Using too much detergent.
Front loader machines do not need so much water, and thus not so much detergent. Also USA water is softer than European water, for which the machine was originally designed, and that may explain why the detergent compartment is so big to hold more detergent. Soft water is easier to get suds. Damage is caused by suds. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element.
2) Dryer does not work, for several main reasons:
(thanks to Malber USA for points a and b)
a) the system may have overheated, tripping the safety thermal switch. This switch is located under the top of the machine and can be easily fixed by the consumer.
b) broken working thermostat. It is a relatively inexpensive repair to remove and replace this part and takes only about 10 minutes. It can be done by the consumer but it
is recommended that a qualified tech do the job.
c) Machine is too full and/or fabrics are too heavy.
Even though you can wash a maximum load of 11 lbs. of clothes, the manual suggests to dry no more than 7 lbs. of cotton clothes and 5 lbs. of heavy or extra large fabrics. Thats because the dryer works by heating up the clothes and then condensing the steam from the circulating air into liquid water which is pumped out. If the machine is filled too much or if the fabrics are too dense (e.g., jeans), the system cannot condense enough water and the clothes remain humid. Perhaps a second 2 hour dry cycle could work, but who wants to dry clothes for 4 hours.
d) Broken heating element
Seems that the heating element breaks after 2-3 years and needs to be replaced. And why is that? Most common reason for heating element failure is oversoaping. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element. But many people simply choose to not use the dryer rather than have it fixed.
Hope this works. Please be sure to rate me. thanks
Apr 17, 2008 | Malber WD1000 Front Load Washer/Dryer
My 7 year old Malber WD 1000 won't dry - Where to order heating element?
pete5runner back again: The check you should make is to disconnect the two wires to the heating element carefully (with unit unplugged). Then connect a 110 voltmeter to the two wires. The plug in the machine and start a dry cycle. If you see 110 volts on the voltmeter, then you know that power is getting to the heating element, and you have isolated the heating element as defective. If you need a heating element, I got one in NY by calling 718-767-7396. New element was $29, shipping included. I don't know if he will ship to where you are located. Good luck, and let me know what happens.
Mar 10, 2008 | Malber WD1000 Front Load Washer/Dryer
Hotpoint Aquarius Condensor Dryer not getting Hot
I don't know Hotpoint models but I do know Malber models very well which also have a condensing dryer. The dryer has a fan and a heating coil or heating element, similar to a hair dryer. If you are getting no air flow, then it could be the fan. If you are getting air flow but it is not hot, then it is probably the heating element which burnt out. In the Malber machine, the top cover comes off and you can see an aluminum duct on top with two terminals sticking out the side. These two terminals go to the heating element inside the duct, and the heater element is like the heating element in an oven. You have to remove the duct and then it splits into a top and bottom half, and then you can remove the heating element to replace it. The way to tell if it is bad is to run the machine in a dry cycle and see if there is 110 volts across the heating element terminals. If there is power, but no heat, then the heating element is bad. That element is usually the first thing to fail.
Feb 11, 2008 | Hotpoint NVL333EY Electric Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
311 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
