Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
Do I Need A Convertor Box?
I Have A Phillips 26PF 5321 D/37. When they test my screen goes blank. I use a roof antenna, but I get DTV stations such as 10.1, 10.2, 10.3, 10.4
Thanks
    President:
  • 948 Answers
No, your television has a digital tuner built in. You will not need a converter box. When the switch to digital is made, simply use the auto scan feature to program all of the new channel locations. Instructions found in the manual here - http://www.p4c.philips.com/files/2/26pf5321d_37/26pf5321d_37_dfu_aen.pdf
Posted on Dec 29, 2008
I cant seem to get all my tv stations on digital. my tv aerial is in the loft not on the chimney but I was told its an in door/ out door aerial. some of the stations I can get break up so im not able to...
The antenna may be an in door/out door antenna, but it will perform better mounted on your roof out doors.
Inside your loft, the antenna is lower and it has the walls and roof to attenuate the tv signal.
You can test the antenna by temporarily mounting it to the chimney. If you get better reception outdoors, then you’ll know.
Jan 28, 2018 | Televison & Video
I have color on all but 1 TV station. That staion has color on other TV's in my house. Any sugestions?
Ur tvs in ur house it is getting a paid tvs incomming broadcasting tv signals like a cables or a satalites dishes companies?Yes,than that incomming broadcasting wire that plug into ur tv Ant. input port hole might have some kind of signals interference at that channel frequencies,call ur cables tvs or satalites tvs companies providers for an answers and get their field Tech. to come out and check it out.If all ur tvs in the house are analoge tvs and u are using a DTV signal through a DTV converter box to getting a Free over the air DTV air to recieving tv broadcasting tv channels stations only than tries it with another antenna signals sources like a better antenna design like a portable digital antena or good roof antenna should solved this problems.
Oct 03, 2011 | Philips Magnavox 20MS3442 20" TV
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Since Texas went digital I am only getting some of the digital chanels. I have changed it to digital programming but they are not all coming through. What do I need to do?
we need more information:
1) Your city in Texas; so I can look up the stations and find what frequency's they are broadcasting their DTV on.
2) What kind of antenna do you have ?
VHF ? UHF ? Inside ? On the Roof ?
A couple things you can try:
- instead of having the TV AutoScan for channels, manually enter the channel for the TV stations not being received.
- call the TV station you're having trouble receiving: they will ask you where live, what kind of antenna you have etc..
but you really should have a 'roof mounted' antenna that is matched to youre reception needs.
Jun 16, 2009 | RCA TruFlat 27F520T 27" TV
Im not getting any signal weak or strong! What am I doing wrong?
What's your source for signal? You need an antenna to be the capture source for your signal that has a wire going from the antenna to the INPUT of the box. That's usually coaxial input. The box is the middle component between your TV and antenna.
Apr 26, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Pixation with hdtv convertor box
if it is pixlating you do not have a good signal if you have a good signal then you have a defective box
Mar 14, 2009 | Televison & Video
Can I receive a digital signal and if so, how?
I'm pretty sure this TV already has an NTSC/ATSC/QAM tuner in there, and should need no converter box whatsover... I say this because I own one...
Mar 09, 2009 | Insignia NS-27 TV TV
DTV Box
Dtv Ready Only Means That It Has A Cable Outlet On The Back They Are Gonna Need The Digital Box If They Wanna Continue Getting Antenna Stations.
Jan 07, 2009 | iLO 3200 32 in. LCD Television
Televison & Video Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
