Question about Lexmark Office Equipment & Supplies
Printer my printer is connected to my computer but will not print.
    President:
  • 2,692 Answers
Start- control panel- printer and faxs - add a printer.
Follow prompts.
Posted on Dec 27, 2008
Printer not responding
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 27, 2012 | Lexmark X3650 Printer
Can't print. Lexmark has an x by offline
  4. Reboot computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 10, 2012 | Lexmark X6150 All-In-One InkJet Printer
How can I fix printing hesitation on my lexmark x5495
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/hsBChY. Select your operating system, download and execute the file.
Feb 16, 2012 | Lexmark X5495 Printer
Printer keeps saying busy printing another document
  4. Reboot computer.
Feb 10, 2012 | Lexmark X4580 InkJet Printer
Not able to print
  4. Reboot computer.
Jan 25, 2012 | Lexmark X8350 Print, Scan, Copy and Fax...
An error occured while printing
  4. Reboot computer.
Jan 12, 2012 | Lexmark X6675 All-In-One InkJet Printer
Can we use MF6550 for wireless network?
If you use a wireless USB print server like this . Keep in mind that you may not get all functions such as scanning to work but it will allow for printing for sure. If the scanning works consider it a bonus.
Jun 11, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
Lost connectivity after power outage
If this is a printer WITHOUT WiFi or bluetooth - and you have it connected to another computer (Print Server) via a USB cable - you need to make sure you can see that computer from the other computer you are printing from. Use the network explorer - if you can see the computer and the printer you should be able to print to it.
Sometimes, it may be secured with a password. I found if I can map a shared drive from my laptop to my print server then I can print again. So see if you can see the printer and printer server computer from the other computer. If so you may need to add that printer again to you printer list.
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
May 01, 2017 | Zonet ZPS3611 Print Server
Can I connect my printer to the uverse router USB port for sharin
If your using Windows operating system you can share your printer. That way you can keep your printer on one pc and when the other pc wants to print it will connect to your printer over your home network and print.
How to setup it in Windows XP
To share the printer, I opened the Printers and Faxes folder on the computer that was connected to my printer.
To open the Printers and Faxes folder
• Click Start and then click Control Panel.
• Click Printers and Other Hardware, and then click Printers and Faxes.
• In the Printers and Faxes folder, I clicked the printer's icon and, in the tasks pane, I clicked Share This Printer.
• I opened the printer's Properties dialog box, and clicked on the Sharing tab.
• I clicked Share Name, and then clicked OK.
That's it—the printer was immediately available for other computers to use.
Now that I had a network printer, I was ready to connect to it and print from other computers on the network.
To connect to the printer
• I opened Control Panel, and clicked Printers and Other Hardware.
• I clicked Add a Printer.
• Instead of adding a local printer, though, I clicked Printer Connection and then browsed the network for the printer.
The whole process took less than a minute before I was printing to the network printer as though it was connected to the computer.
Nov 30, 2009 | Computers & Internet
Switching from copy to print from computer
If you look carefully at the printer you'll note that there is no button for "Print" and the reason for this is that all the other functions are for using the printer as if it wasn't connected, nor needed a computer.
All your printing functions that DO use a computer require you to interact with the printer via the computer.
In short, to use the printer from the computer you'll need to make sure you've installed the correct drivers (see your installation CD or the Canon website) and then plug the printer in using a USB cable connection to your computer. If the computer recognises the printer you'll then be able to print.
In a nutshell if your printer is connected and drivers installed properly it doesn't matter what your printer has selected on the printers own control panel, you just print :)
Hope that helps.
Feb 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
15 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
