Question about Frigidaire FDE336RE Dryer
How do i remove top to replace guide assembly
I cannot figure out how to replace guide assembly
  • 61 Answers
Hello, there are 2 hold down clips about 2 inches in from either side that hold the top to the front panel. Take a putty knife or a flat head screw driver and pry the top up on both sides. now you have access to the 2 screws that are located about 6 inches down from the top on either side, remove these and the front will now come off and you can change the glides. good luck
Posted on Dec 27, 2008
How to remove xerox 7545 high voltage power supply
  1. Press the Job Status button to check that there are no jobs in progress.
  2. Switch off the power and disconnect the power cord.
  3. Remove the following parts:
  4. Remove the Tie Bar. ( Figure 1)
    1. Remove the screws (x4).
    2. Remove the Tie Bar.
    Figure 1. Remove the Tie Bar
  5. Disconnect the connectors (x2). ( Figure 2)
    1. Remove the cable band.
    2. Disconnect the connectors (x2).
    Figure 2. Disconnect the connectors
  6. Remove the Bottle Guide Assembly. ( Figure 3)
    2. Remove the Bottle Guide Assembly.
    Figure 3. Removing the Bottle Guide Assembly
  7. [7525/30/35]: Remove the HVPS (Dev/BCR). ( Figure 4)
    1. Disconnect the connector.
    2. Remove the screws (x2).
    3. Hold onto the tabs (x2) of the Bracket and pull out the HVPS (Dev/BCR) in the direction of the arrow.
    Figure 4. Remove the HVPS (Dev/BCR)
  8. [7545/56]: Remove the HVPS (BCR). ( Figure 5)
    3. Pull out and remove the HVPS (BCR).
    Figure 5. Remove the HVPS (BCR)
Sep 08, 2014 | Xerox Office Equipment & Supplies
Changing the fuser for a CM1415fnw
If your capable of searching google, you may want to grab the service manual for this, heres the procedure to change it out but as you can see there are even more procedures along the way...
Fuser 1. Remove the following components: ? Right cover. See Right cover on page 17. ? Right-front cover-1 and cover-2. See Right-front cover-1 and cover-2 on page 20. ? Control panel. See Control panel on page 22. ? Left cover. See Left cover on page 25. ? Document-feeder and scanner assembly. See Document-feeder and scanner assembly on page 28. ? Rear-center cover. See Rear-center cover on page 30. ? Rear-upper cover. See Rear-upper cover on page 31. ? Speaker. See Speaker on page 33. ? Top cover. See Top cover on page 34. ? Rear door and rear-lower cover. See Rear door and rear-lower cover on page 41. 2. Remove two screws (callout 1) and the black plastic cover (callout 2). Figure 1-117 Remove the fuser (1 of 4) 1 2 80 Chapter 1 Removal and replacement ENWW 3. Disconnect five wire-harness connectors (callout 1). Remove the wire harness from the guides (callout 2 and callout 3) and one retainer (callout 4). Figure 1-118 Remove the fuser (2 of 4) 2 1 3 4 4. Remove four screws (callout 1). Figure 1-119 Remove the fuser (3 of 4) 1 ENWW Removal and replacement procedures 81 5. Remove the fuser. CAUTION: Handle the fuser carefully. The sensors that are mounted to the output side of the fuser can be easily dislodged. When the fuser is reinstalled, make sure that the sensors are present, and correctly fastened to the fuser assembly. Figure 1-120 Remove the fuser Hope this helps...
Feb 16, 2014 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
How do I replace keyboard assembly on Samsung NF210 Netbook?
Here is a pictorial guide, step-by-step:
http://hope-works.weebly.com/change-netbook-palmrest.html
Jul 09, 2012 | Samsung NF210-A02 Netbook
How to replace mirror motor assembly lexmark t632 or printhead
I would suggest you contact a certified Lexmark trained technician to replace the printhead or you may contact Lexmark Technical Support.
Oct 12, 2011 | Lexmark T632 Laser Printer
Drivers side headlight bulb replacement
  1. Open the hood to the 1999 Dodge Stratus.
  2. Locate the two headlight lens assembly retaining screws at the top of each side of the assembly.
  3. Remove each screw with the ratchet and a suitable socket.
  4. Place the screwdriver behind the lens assembly to assist in prying out the guide pins that secure and align the headlight assembly. Hold the lens assembly from the outside edge (marker light/directional light section) first and pry from behind with the screwdriver to unseat the guide pins. Pry from the inside end of the lens assembly to unseat the other guide pin.
  5. Pull the lens assembly out far enough to reach behind it and disconnect the headlight bulb wire harness from the back of the bulb. Or simply remove the bulb by twisting the harness and retaining ring counterclockwise and remove it as an assembly.
  6. Turn the marker light/directional light socket and wire counterclockwise to remove it from the headlight lens assembly.
  7. Remove the assembly from the front of the Stratus.
Feb 28, 2011 | 1999 Dodge Stratus
I have a 2001 cavalier. When I researched the Haynes guide it seemed like an easy fix; unplug the battery and the fan, gently lift the fan assembly to release it from the fasteners on the side and the...
TRY REMOVING HOOD SUPPORT BRACKET THAT OVER TOP RADIATOR.ALSO CONDENSOR BRACKET THAT WILL ALLOW YOU ROOM YOU DONT HAVE TO REMOVE RADIATOR OR CONDENSOR
Sep 13, 2009 | Chevrolet Cavalier Cars & Trucks
Replacement drum for Q3964a
HP Color LaserJet 2820 and 2840 AiO Series Products - How to Replace the Imaging Drum Replace the imaging drum
  1. Push the scanner-release button to open the scanner assembly. Figure 1: Example of scanner release button location c00364331.gif
  2. Open the top cover. Figure 2: Example of top cover being opened c00364332.gif
  3. Grasp the imaging drum handle, and then rotate the drum until the handle is at the top.
    NOTE: The drum may be a snug fit. If needed, gently apply some force while rotating and removing the drum. Figure 3: Example of imaging drum rotation c00364333.gif
  4. Lift the imaging drum straight up to remove it from the device. Figure 4: Example of imaging drum removal c00364334.gif
  5. Remove the new imaging drum from its packaging.
  6. Place the imaging drum on a firm surface, and then pull the orange rings to remove the shipping pins. Figure 5: Example of shipping pin locations c00364335.gif
  7. Remove the orange shipping lock on each end of the imaging drum, and remove the two orange shipping spacers. Figure 6: Example of shipping lock and spacer locations c00364336.gif
  8. Remove the orange cover from the imaging drum. Figure 7: Example of orange cover location c00364337.gif CAUTION: Do not touch the surface of the roller or expose the roller to light for an extended period of time. Doing so could cause print-quality issues.
  9. Align the arrows on the side of the imaging drum with the arrows inside the printer. Figure 8: Example of arrow location c00364338.gif
  10. Lower the imaging drum into the printer, and then press it firmly into place. Figure 9: Example of imaging drum installation c00364339.gif
  11. Close the top cover and the scanner assembly.
Feb 27, 2009 | HP LaserJet 2840 All-In-One Printer
99 olds culass headlight bulb replacement
Look at the top of the headlight assembly. There is a plastic panel on top of the assembly that is held in place by two plastic pins. Remove those pins by lifting the center of the pin and then pull out the pin. Remove the panel. Then you will find two small plastic levers that will lift about 1/2 inch. They do not come out but they will release two studs that secure the assembly. After the assembly is released, slide it forward to access the bulbs you need to replace. Installation is the reverse of these procedures.
Feb 25, 2009 | 1999 Oldsmobile Cutlass
Printer won't print
60.2
printer error
The tray 2 lifter-motor is not functioning. 1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
This is straight out of the manual.
Tray 2 lifter-drive assembly
Remove the following assemblies:
● Rear accessory cover. See Accessory covers and the tray 2 extension door.
● Top cover. See Top cover.
● Right-side cover. See Right-side cover.
● Formatter cover. See Formatter cover
● Formatter. See Formatter assembly
● Paper-pickup drive assembly. See Paper-pickup drive assembly.
2 Unplug the tray 2 lifter-drive assembly connector from the dc controller PCA (location J93) and
the two flat cables (callout 1, locations J80, J81). Unweave the wire-harness from the cable
guide (callout 2).
NOTE You might have to remove additional wire-harnesses from the cable guide to gain
access to the lifter-drive assembly wire-harness.
Figure 6-51 Tray 2 lifter-drive assembly (1 of 3)
Main assemblies 227
Unhook the tension spring (callout 3) at the lifter-drive assembly, remove one screw (callout 4),
and then slide the support plate (callout 5) out of the printer.
Figure 6-52 Tray 2 lifter-drive assembly (2 of 3)
228 6
Rotate the top of the lifter-drive assembly away from the printer to remove it from the printer.
NOTE You might have to remove some cable guides to easily remove the lifter-driver
assembly.
Figure 6-53 Tray 2 lifter-drive assembly (3 of 3)
Main assemblies
unfortunately i couldn't paste the pictures to help you.
Assembly is the exact reverse of removal, Good Luck!
Nov 20, 2008 | HP LaserJet 4250n Printer
Check Printhead cleaner Path
Sounds
    1. Attempt to duplicate the message by turning the printer on, reloading the media, and printing several test prints.
    2. Note the movement and position of the carriage when the error occurs.
    3. If the carriage stops on the left-hand side (roughly 12 inches from the ink supply station), unplug the power cable from the printer, open the top cover and try to move the carriage to the right. Closely inspect the ink tubes for wear, and check for ink tube binding or catching on the tube guide (stopping/hindering carriage movement). If true, continue with the remaining steps below.
        NOTE: If the steps above do not describe the issue correctly, refer to the work instruction for a typical “Switch Power Off, Check Printhead Path” message (bpp90070).
Check/replace the Ink Tube Systemgtabtop.gif
    1. Turn the printer off.
    2. Remove the old Ink Tube System (refer to pages 8-53 of the Service Manual).
        NOTE: If the printer is installed on a Multi-roll feeder accessory, some additional disassembly is required to gain access to the printer. Instructions for multi-roll disassembly are listed at the bottom of this document for reference.
    3. Move the carriage assembly to the right side of the printer.
    4. Clean the rear tube guide assembly with a moistened lint free cloth to prepare the mounting of the Mylar tape.
      Figure 1:Cleaning the rear tube guide assembly
    5. Remove the backing on the Mylar tape and align the line on the tape with the front edge of the rear-tube guide so that the narrower section is towards the front of the printer. Do not attach the tape yet.
      Figure 2:Aligning line on Mylar tape with front edge of rear-tube guide assembly
        NOTE: Ensure that the Mylar film is perfectly aligned with the rear Tube Guide surface with no protrusions or unevenness.
    6. Carefully position the Mylar tape about 1/4 of an inch from the left-end of the rear-tube guide (do not go all the way to the end as the beveled edge will cause crimping of the tape).
      Figure 3:Attaching the Mylar tape
    7. Ensure tape is evenly positioned and any air bubbles are smoothed out along the tape.
      Figure 4:Smoothing out the air bubbles along the Mylar tape (view from rear of printer)
    8. Carefully fold under the narrow section of the tape to the underside of the rear tube guide assembly and smooth out any air bubbles.
      Figure 5:Installing Mylar tape under rear-tube guide assembly (view from front of printer)
    9. The Mylar tape should look like the image below.
      Figure 6:Final installation of Mylar tape (view from top of printer)
    10. Once the Mylar tape is installed, install the new Ink Tube System (refer to pages 8-53 of the Service Manual).
    11. Following replacement, verify printer functionality.
like a bad belt.
Feb 11, 2008 | HP DesignJet 1050c InkJet Printer
Dryers Logo
62 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
