Question about Nintendo Wii Fit for Wii
Unable to sync Balance Board and its knocking the remotes out too
Had Wii for a year now and works perfectly. Got a balance board for Xmas and when trying to sync error message comes up saying connection broken press A but neither of the Wii remotes work anymore. Tried the re-syncing instructions in the manual and eventually got one remote to work again but when retried with balance board same message and remotes knackered again. Please help!!
  • 1 more comment
  • lisamclisa Jan 08, 2009
    I have this exact problem and am trying to find a solution - help people! Have I broken my dad's wii console!!??
  • Anonymous Mar 01, 2009
    When i click on wii fit cd, then start to start game (so i can sync) - screen goes blank and i have to reboot console to get anything back -- plus i sometimes loose remote
  • Anonymous Mar 11, 2009
    I have had my fit for a year and all has worked fine. Now when I want to sync it it disrupts my wii remotes.Help it's very frustrating!
When you are prompted to press the sync buttons you just have to press and release just once the sync button on the console and then on the board. Do not hold the buttons in because you just end up un syncing everything!
Posted on Apr 04, 2009
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
How can i re connect the wii fit balance board to my wii ?
Synching can be completed only if a compatible game disc is running in the console. Compatible game discs (such as Wii Fit) will display the Wii Balance Board icon on their packaging.
The Wii Balance Board must be synced to each compatible game individually.
Follow these directions to sync the Wii Balance Board (so that it is recognized by the Wii console):
Insert a Wii Balance Board compatible game disc (such as Wii Fit) in the Wii console.
Mar 16, 2011 | Nintendo Wii Console
How do you sync the wii fit board and wii console
  • Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
  • Insert a Wii Balance Board compatible game into the Wii system.
  • Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
  • Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
  • Turn the Wii Balance Board upside down.
  • Remove the battery cover under the balance board to reveal another sync button.
  • Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
  • Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
  • Mar 03, 2011 | Nintendo Wii Console
    Board wont calibrate
    ifif your talking about the Wii and the balance board wont calabrate, you need to sync the balance board to the Wii by removing the battery lid and pressing the sync button. The board power button lights should blink for about 20 seconds. At this time, you open up the SD card lid on the council and press the sync button on there. The board will stop blinking when it is synced. After this, insert a video game that requires a balance board. You go to "controls" on the main menu and set it to Wii balance board mode. after this you press "ok" and it should tell you which way to set the board. After this, you go to Wii home by pressing the button that looks like a house in the middle of the remote. Then, you hold down the power button on the board and wait until player 4 shows life. (player 4 is the board.) The board should work now.
    Jan 09, 2011 | Video Game Consoles & Games
    When sychronizing the wii balance board we held the sychronize button down to long and now the wii remote control won't work how do we fix this
    2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
    3. Open the small SD Card slot cover on the front of the Wii console.
    5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
    6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
    7. The blue light will stop blinking and stay on steady once the synchronization is complete
    Click here to download repair guide
    Jan 05, 2011 | Nintendo Wii Console
    I have a wii balance board, the batteries ran out so i changed them -now the board will not work. Ive tried pressing the red buttons together but still no joy. my neighbour is having the same issuses. Why...
      Try these steps!
    7. The blue light will stop blinking and stay on steady once the syncronization is complete
    click here to download repair guide if u need
    Dec 17, 2010 | Nintendo Wii Fit - Balance Board + Game...
    When syncing a new wii balance board game to the balance board it unsyncs the remotes every time i resync the remote it unsyncs the balance board
    Get a partner and do the syncing at the same time or take the the controller far away when it is synced so it doesn't turn off
    Feb 17, 2010 | Nintendo Wii Console
    We used our wii fit on another wii system. After
      Try these steps!
    7. The blue light will stop blinking and stay on steady once the syncronization is complete.
    Fore more detailed information (including pictures) on how to sync the Wii Balance Board, click here.
    If you are still unable to sync your Wii Balance Board, please call 1-800-255-3700 so that they may assist you further.
    Hope it helped.
    Nov 22, 2009 | Nintendo Wii Fit for Wii
    Cant sync wii balance board
    I know it's been a while since you have posted and have prob already figured it out. But just in case this may help someone else. Try turning off your wii and unplugging from the power source for a few minutes. The plug back in and turn on. At the initial warning screen press and hold the sync button on the wii console for about 4 sec. You will have to resync your wii remotes. Next make sure the disc for the game you are going to use the balance board with is in the system and start the game. Then try to sync the balance board.
    Nov 17, 2008 | Nintendo Wii Fit for Wii
    Nintendo Wii Fit for Wii Logo
    488 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
