Question about Kenmore 15864/15862 Top Load Washer
Leaking washer
Leaking when filling, standing and washing
When leaking from front center below, is probably the pump. Remove cover to verify.
Posted on Jan 29, 2009
My kenmore washer molel 110-82873120 is leeking from the top.
Dear R.A.,
If your washer is leaking you should first check the hoses.
  • There are several types of hoses found on a washing machine and the most common are the drain and fill hoses.
  • The fill hoses connect the household supply to the water inlet valve and are normally located at the rear of the washer. Check to make sure that the threaded fittings are tightened securely and that the leak is not caused by the faucet.
  • The drain hose is also located at the rear of the machine and may not be properly installed into the household drain. Verify that the leak is not caused by a restricted household drain that is backing up through the stand pipe.
  • Washers will also have internal hoses that connect the inlet valve to the tub. A defect in this hose would create a leak during the fill cycle.
  • Access the tub inlet by lifting the main top or removing the cabinet and inspect the hoses for signs of abrasion or cracking.
  • Also inspect the other components of the water inlet system such as a siphon break or tub injection assembly for signs of a leak. Check for loose or corroded clamps, and cracked or perforated hoses.
  • Your inlet Valves may also be totally defective and cause the washer to overfill therefore causing a leak over the top.
  • Check for the tub Pressure switch assembly may be defective causing such leak.
  • Your model requires removing the complete cabinet.(front and sides come out as on piece) Here a link to all your machine parts
I think we cover all the possibilities.
Best of Luck,
JP
KENMORE AUTOMATIC WASHER Parts Model 11082873120 Sears PartsDirect
Jul 03, 2015 | Kenmore Washing Machines
My Frigidaire affinity washer leaks water into the washer stand. Whenever I open the drawer after washing a couple of loads there's water in the drawer.
That's what I thought was wrong with mine to I had 1.75 in change and a piece of a wash clothe in the screen. I toke all that out and it still leaked. Took it apart further and found a piece of the weight that is made out of cement broke of and rubbed through the drum. That sounds like junk to me!!!
Oct 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Washer leaks during fill up
check the bottom of the inlet hose where it enters the machine. It is most like;y a split hose or a corroded valve.
Sep 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaks out when it is filling.
Make sure the drain hose is higher than the top of the washer tub.
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
During the fill cycle, the washer leaks water?
I've repaired leaks from bad rubber washers on the fill hoses as well as loose hose clamps on the back of the fill solenoids that run into the tub. Check closely.
Jun 27, 2009 | Maytag Washing Machines
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Kenmore 15864/15862 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
