Question about Sony KP-51HW40 51" Rear Projection Television
Sony 51inch tv blue screen appears
I have a 4 year old tv and when I turn on my tv the picture shows after a couple minutes the screen turns blue and I can only hear sound. I read it might be a blue tube problem and sony knows about a manufacturers defective tube. How would I know if its a manufacturers defective tube. If sony doesn't change it for me, where can I go to find a blue tube for a low price.
I had just adjusted the lower right adjustment on the screen focus block. 1. Remove the front speaker panel (there were 2 screws) 2. After the panel is remove, unscrew the sheet of plywood that's held together with 4 screws, this will expose the TV's innards (guns, etc) -- be careful. 3. At the bottom, there's a small box with 6 adjustable (via a philips head screwdriver) screws. Disregard the top row of 3 (they're for focus). 4. What I had to do was adjust the left most one ever so slightly with my philips screw driver. It seems the TV was over-firing blue causing everything to have a very slight blue tint as well as the lines. Once adjusted, the TV was good as new.
Posted on Sep 12, 2007
    President:
  • 1,284 Answers
The CRT's are the most common problem on those sets and if you have to replace one, plan on replacing all three otherwose the other two will follow shortly. This was a defect in the CRT's and Sony did cover them up to 4 years from date of purchase.
Posted on Apr 24, 2007
    Scholar:
  • 77 Answers
Could be a blu tuibe but also i've seen many bad sony CRT Drive bds(the circuit board connected to the neck of the tube). You won't find really any place cheaper than the next if your a consumer. just try partstore.com Oh, and forget about sony paying for it 4 years is way out of warranty.
Posted on Apr 23, 2007
  • josh vannoy Apr 25, 2007
    TVTEK is right, I forgot about the lengthend warranty period on those sets, however in my experience anyway, that problem was just a subtle flicker in color and usually would not go entirely blue, also the Sony service bullitin had you change I believe 3 resistors, 2 of which were tiny surface mounts. I do remember doing the big job with all three tubes once or twice on tvs that went really dominatlly one color just to find out that the problem was the drive. None the less, you should let a Sony service center do the warranty job with the tubes and if they find out they need to repair the drive then at least you got three new tubes.
Sony 42 inch plazma display on screen ...fan problem powering down
if the fans are stopping you will need to replace them
Apr 29, 2014 | Televison & Video
Sony Bravia LCD 40" XBR2- Sound, but no picture; solid bright green screen
Sorry about your issue, however, LCD's do not have a lamp, they have a back light but the chances that is bad is a million to one. I strongly recommend taking it in for an evaluation. I understand your feelings that it should last 5 years or so, however I see every brand, a year or two old with these types of issues. The day's of no problems for 5 yrs up to 20 are definitely over. This is technology at it's finest.
May 23, 2009 | Sony Televison & Video
Blue color flowing from side and bottom into picture
Sony tech support (no charge) said it was definitely not the lamp.
Their suggestion- By unplugging the TV for a minute then turning back on, the blue color was substantially but not toally reduced.
Perhaps there is an electrical charge building up distoring the color by having the TV in the ready mode for too long and by unplugging, the charge dissipates?
No other phone solution recommended other than calling for repairs.
Mar 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
KP-51HW40 Sony 51" Fades to blue screen
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Aug 26, 2008 | Sony KP-51HW40 51" Rear Projection...
No image but good quality speaker.
Sony has had a problem in older sets with-believe it or not- lack of humidity. I had one with the same problem. If it is under warentee take it back, if not-I know it sounds insane- put a large plastic garbage bag over the turned off set. Leave it that way for a couple of days. do not turn it on during this time. After a couple of days remove the bag and turn it on. If it works-that's the problem, if it doesn't- it's dying, and to expensive to fix. Surprised the heck outta' me when I tried it on my old Sony 19" set- it worked.
Jul 01, 2008 | Sony KP-46S25 TV
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
FADING TO BLUE SCREEN
Sounds like you have a problem with the blue gun in your picture tube or its drive circuit. You might remove the back cover and gently tap on the neck of the picture tube using a plastic screwdriver handle while watching the screen in a mirrow. If the picture flashes back on or on and off then the picture tube is the problem. If this is a projection tv you have three separate tubes : red, green & blue. you'd need to tap the blut one.Gently!!!! Stargazer
Feb 13, 2007 | Sony KP-53HS20 TV
Sony KP-51HW40 51" Rear Projection Television Logo
267 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
