Question about Toshiba Satellite P205-S6337 Notebook
TOSHIBA SATELLITE P205-S6337 wont turn on
The laptop has been charged all night and when turned on the hard drive light blue, battery light blue but still a black screen. When plugged in to AC the blue light is on but still a black screen and nothing happens. The laptop is 1 year and 1 month old.
  • rushnp774 Jan 02, 2009
    That has happened to me a couple times. The first time, I just waited a while before I turned my computer on again and it worked. The second time, I removed my battery, plugged it into the AC adapter and it started up fine. I put my battery in and Vista said it was 100% charged. Who knows?
CMOS Battery
On the mother board. It is a rechargeable type.
Jan 27, 2014 | Toshiba Satellite P205-S6337 Notebook
Broken screen on toshiba p205-6337
LCD screens and Inverters for your laptop maybe available from this WEB site.
www.lcdparts.net
Jul 06, 2012 | Toshiba Satellite P205-S6337 Notebook
I have a Toshiba Satellite P205-S6337 that will only show a black screen. I can outboard the video and this works but only in safe mode. The laptop screen has perfect backlighting and no dead pixels so I'm...
QUICK SOLUTION IS
the os with the correct disks 2. Ensure the correct drivers are used 3.request the correct installation disks from the PC manufacturer 4. The blue screen will no longer be an issue as you should not see it anymore
LONG SOLUTION
TRY AN EXTERNAL MONITOR TO SEE IF YOUR MONITOR IS THE PROBLEM. IF IT IS, BE PREPARED TO PAY OUT $125 PLUS FOR A NEW ONE
Jan 25, 2011 | Toshiba Satellite P205-S6337 Notebook
How do you change a keyboard in a toshiba p205-s6337 laptop
It is not a simple operation -- if you have to ask "how", STOP, and take the computer to a qualified technician, to get it done correctly, and without any collateral damage.
Nov 14, 2009 | Toshiba Satellite P205-S6237 Notebook
Upgrading ram
You can only run 2gig max IE: 2- 1gig or 1-2gig you cant run 2-2gig the bios will not accept it
Mar 13, 2009 | Toshiba Satellite P205-S6337 Notebook
Need to unlock phoenix bios password for toshiba satellite a135-s4527
remove the keyboard the mobo battery is there you need to unsolder one end of it, lift the leg, and turn it on that way for it to clear.. you will have to resolder once done.. have the skills or find someone that does... and you're set..
Jan 16, 2009 | Computers & Internet
I won't to Know if I can use bitlocker on my laptop
If the TPM is not enabled in the Bios,Then you can use Bitlocker.
If it is enabled,You will need to check with Toshiba for compatibility issues or disable TPM
I run it on mine and it works fine.
Jan 11, 2009 | Toshiba Satellite P205-S6337 Notebook
Toshiba Satellite with web cam
Could be that the power supply failed, you will need to test it with an ohm meter. If it checks good then try removing the battery and starting the machine. If it still doesn't work then you will need to take it to a tech for diagnosing, because the problem will be on the motherboard.
Jun 27, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba Satellite P205-S6337 Notebook Logo
302 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
