Question about Philips SA3025/37 Flash MP3 Player
Wont turn on
Phillips mp3 2g player when plugged in to usb shows it charging but it wont turn on can it be reset without losing music
  • Anonymous Dec 27, 2008
    I just got the Philips mp3 player on Christmas, and on the very next day it didn't work. I've tried using the Philips Device Manager and resetting it, and I've plugged the USB so it'll charge, but it's not turning on.
  • 8,596 Answers
You can reset the player without losing the music, but Repairs and firmware Updates will result in songs being erased.
Make sure the hold/lock switch is not activated.
If it is not, then try a different USB port on your computer.
If you get the same result:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Mar 06, 2009
Wont turn on when not plugged in. but will turn on if charg plug is plugged in and you turn on the power switch and unplug the charger it will stay on but wont play, keeps coming up format error.
Customer Reviews: Kubik Evo 8GB MP3 Player with Radio ...
www.amazon.com/Kubik-Player.../B0041MMMWW
Amazon.com, Inc.Find helpful customer reviews and review ratings for Kubik Evo 8GB MP3 Player with ... Con's - Wonder if some of these items can be fixed with a firmware update. ... Just push the main button (or any button) and it will turn on and function as usual. ... 2) Play while plugged in charging works with the wall charger, but still NOT ...
Evo won't charge via USB ' Android Forums
androidforums.com > Android Phones > HTC EVO 4G
Jun 29, 2010 - Whenever I plug in my Evo, I select Charge Only (or if I do nothing, it selects Charge. ... If I turn off my Evo it charges from the USB fine. ... Check your computer's stats... what does it say about its USB status when your Evo is plugged in or ... I had a problem a while back where it would charge via USB, but not ...
Dec 29, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
WHEN I PLUG IN MY PHILIPS GOGEAR PM3 2GB PLAYER IT TELL ME THAT ITS OKAY TO DISCONECT AND THATS ALL IT DOES !IT WONT TURN ON AND IT WONT POP UP THE BOX TO ADD MUSIC ... WHAT DO I DO ?
Heh.
When you plug in ANY MP3 player, it will show a general screen saying not to DC or that its charging. As for adding music, check your "My Computer" area, look for removable devices. And please, talk without caps lock on, it makes you look unprofessional, people will read it the same either way.
Hope this helps
Aug 06, 2010 | Philips GoGear HDD075/17 MP3 Player
When i turned on my mp3 it froze and wont turn off. i dont want to reset it because I'll lose ll my music!
Ok what you do is plug it up to the Computer/Charger Then It should say USB or Charging. Then Umplug it. It Happens to my mp3 all the time.
Jun 22, 2010 | Audio Players & Recorders
My Sony Walkman NWZ-E435F wont turn on at all even when plugged in with my USB
I had the same problem. For at least a week. Try pressing the reset button. The reset button won't delete your music, videos, pictures, etc. Just resets your system. If that does not work then i don't know what else to tell you.
May 05, 2009 | Sony Walkman NWZ-S616F MP3 Player
Phillips go gear 8gb
Reset the player by inserting a paerlcip into the reset hole. If that fails, go to Philips' website and upgrade the firmware on your player to solve the freezing issue permanently. Actually, don't go to Philips website - run the Philips Device Manager and select Update. If the device manager won't recognize the player, unplug the GoGear, hold in either the shuffle button or volume + and reconnect it to the computer until a Found New Hardware Wizard window pops up.
-Tha Mp3 Doctor
Dec 29, 2008 | Philips GoGear SA5285/37 Digital Media...
Nextar MA715 MP3 player wont take a charge.
Best first bet is dead battery. If it is a special battery then do the costings for the repair as it may be cheaper to replace the player.
Jun 13, 2017 | Nextar MA7151B MP3 Player
Wont turn on at all
i pressed the reset button and all of my music was still on it. I didn't lose nething! my player is running fine again. just press the reset button and then attempt to turn it on again. this worked for me
Jul 28, 2008 | Creative Labs Zen Digital Media Player
Frozen solid
i have the same promblem i was listening to my music and it had full batteries and it just shut off this is so bull like i think i have to return it and buy something else!!
May 06, 2008 | Philips GOGEAR SA6045 MP3 Player
Wont charge and memory corrupt even after i reset tons of times
Plug your MP3 Player into your Pc and Format The removable Drive Then Re-load your music onto it if that doesn't work it'll have to be a hardware problem my only other suggestion is get out your Guarantee and send it in
Jan 15, 2008 | Philips SA5125/37 MP3 Player
This damn thing....
Charge the player - it needs to be charged daily.
Dec 18, 2006 | SanDisk Sansa m250 MP3 Player
Philips SA3025/37 Flash MP3 Player Logo
94 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
