Question about Sony Playstation 3 (PS3) Console
I press the power button and it turns green for bout 10 seconds then it turns red. Nothing shows up on the screen er anything.
    Novelist:
  • 89 Answers
PS3 flashes in red and suddenly turn off by itself : All of them means hardware errors. But do you know many of them can be repair by yourself?
There is a PS3 repair guide I can share with you. It is an all-in-one text and video guide. It show you how to dis-assembly your PS3, apply fixes and return to work!
It's incredible!
PS3 Repair Guide
Posted on May 30, 2012
    Problem Solver:
  • 7 Answers
This is meant to happen if u turn the ps3 off it flashes for about 10 seconds and stays on standby with the redlight
Posted on Dec 27, 2008
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet
Oct 27, 2014 | Tablets & eReaders
My phone doesn't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 10, 2012 | Cell Phones
Computer is not working
The computer may be in hibernate or standby. Try pressing the space bar, and then wait a moment. See if anything happens. If nothing happens, press the power button for one second and wait a moment and see if anything happens. If nothing occurs, you may need to force a restart.
To force a restart, hold in the power button for approximately 15-20 seconds, this should force the computer to turn off all the way. If holding the power button doesn't do the trick - you can unplug the computer from the wall and take out the laptop battery as a last resort.
Once you are sure the computer is off all the way, press the power button and see if anything at all shows on the screen. If you are not able to see any information on the screen, it is possible that the Laptops screen has gone bad. If you have an external monitor you can try to plug into it and see if anything shows. If nothing shows, it is possible the video card/motherboard is gone bad.
To fully diagnose a bad motherboard or video card - you would need to take it to a qualified computer technician.
Nov 15, 2011 | HP Compaq Presario C306US Notebook
Turns on nothing displays on the screen
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
May 06, 2010 | Sony Playstation 3 (PS3) Console
Ok my v3 turs on but no screen comes up the phone rings incoming
I THINK THE RIBBON OF YOUR PHONE ARE DAMAGED..REPLACED IS NEEDED...
Mar 26, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Tv wont turn on
i had this problem myself, press the power button and when it goes green press it again but hold it for 10 seconds, then it should work fine mine did good luck :)x
Jan 29, 2010 | Televison & Video
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
I downloaded PS3 system software update 3.15 last night. Now when i turn it on the green and blue lights come on and it starts to boot up but stops and there is nothing on the screen and my controller...
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. i had the same issue and this fixed it.
Jan 22, 2010 | Sony Playstation 3 (PS3) Console
It comes on but I can't get anything on the screen. if I put a game in it gives me the blue and green light but nothing happens
try this
Jan 13, 2010 | Sony Playstation 3 (PS3) Console
The led screen shows genera error
you need to reset your printer try doing this
  • Press and hold “Stop”, “Maintenance”, and “Power” buttons for about 10 seconds. A message will come on the screen saying counter is reset and to turn the printer off. The R200 and others don’t have a screen so just wait until the 10 seconds is up.
  • Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That’s all there is to the reset procedure.
Nov 24, 2008 | Epson Stylus Photo R300 InkJet Printer
Sony Playstation 3 (PS3) Console Logo
129 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
