Question about JVC XV-N412S DVD Player
Hello, I have the JVC XV-N412 DVD player. It has been working fine for a couple of years now, but lately it will no "read" regular commercial DVDs. I place a DVD in the tray, it struggles to lock in, but I only get a "No Disc" notice onscreen. This happens with numerous DVDs, including ones I tried knowing that I had played them previously with no problem. The only DVDs that seem to play OK are those that I burn myself-- photo collections, QT movies recorded from my DVD or output through iMovie, etc. But regular DVDs no longer seem to play. Any thoughts...? Thanks, Ernest Farino
  • ernieworld Dec 27, 2008
    Additional info: I had heard that shutting down the a player like this can help (recycle the memory or whatever), so I unplugged the player for approximately 24 hours. I then plugged it back in and tried various discs again, but with the same problem as described above.
    Just thought I would add that in to skip over that step as a possible solution.
    Thanks,
    Ernest Farino
    Thank for the quick response. I don't have any experience in cleaning internal components-- can you tell me the best way to access the lens to clean it...? Thanks.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, try a CD disc cleaner that is readily available from most audio/video stores and even computer stores. They are designed to look and play like regular discs but with a brush like attachment designed to clean the lens.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grime, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image below.
Good luck and Thank you for using FixYa.
Posted on Dec 27, 2008
    Sergeant:
  • 250 Answers
Hi Ernest,
It sounds to me as though the lens needs cleaning or replacing. So if a lens clean doesn't work you could look around for a replacement lens unit. Heres one i found:
http://www.4jvc.co.uk/cgi-bin/search.pl?parts_search=s&model=XV-N412&part=
but that might just mean the front glass of the unit. Failing that it's time for a new player.
All the best
Sean
PiDigital
    Guru:
  • 829 Answers
Hi did you try cleaning the lens of your DVD player , In most cases due to moisture the DVD head fails to recognize the DVD in turn an error displays No Read disk or no disc found. Please let me know how old the DVD player is . Sometimes if its too old the DVD head might have worn out which needs an replacement.
    Genius:
  • 3,422 Answers
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image i have attached.
  • 10,594 Answers
First, unplug dvd player from AC outlet for couple of minutes, replug and try to play dvd.
2nd is to clean dvd lens with either cd cleaner or cotton bud by taking off top cover of unit.
  • Shahid Electronics
    Shahid Electronics Dec 27, 2008
    Unplug unit from AC outlet.
    Cleaning the optical lens is to take off cover of unit and see lase optical lens.
    Get good quality soft cotton bud and clean the glass lens on laser optical with round / circular motion. do not press cotton bud so ******* lens.
    Put back cover on unit and replug unit in AC.
    Power it up and load disc, press play and check.
    sample picture of optical lens is here...
    Sergeant:
    Novelist:
  • 327 Answers
Simple.its the problem of lens got dirty internally it needs cleaning.or the lens got faulty in that case it needs replace ment.try cleaning the lens with your haND manually and check out.
I have a JVC DVD Player (XV-N670B), (XV-N672S). I recently purchased a BluRay DVD and after inserting the DVD into the player, "Disc Error" appears. Would you tell me if my player can...
Sorry to say, no; this is a model limitation not a fault as such. XV-N670B is a DVD player, and the playable formats are:
DVD-Video, DVD-RW/-R, +RW/+R, CD, CD-R/RW, SVCD/VCD, WMA/MP3/JPEG, DivX. No Blu-ray support.
The JVC XV-BP11 and XV-BP1 do play Blu-Ray discs, as they are specifically Blu-Ray players (according to the JVC website).
I have heard of quite a few Blu-Ray players allowing DVD playback. The XV-BP1 supports the following playable media: BD-R/RE (Blu-Ray), DVD-Video/-R/-RW, R/ RW, CD, USB (again, this is from the same JVC website). You would need to purchase this or a similar Blu-Ray player to enjoy the benefits it has to offer (but it's up to you if you want one of those later on).
DVDs are still good, the 'disc error' message on your DVD player is normal due to the wrong media format inserted. The bonus here is it didn't cost you anything to ask, and you don't need a workshop quote on repairs.
This is the best free advice I can offer.
Mar 07, 2011 | JVC Televison & Video
WHATS THE HACKING CODE FOR MY JVC XV-N322 DVD PLAYER
Try this link: http://www.videohelp.com/dvdhacks/jvc-xv-n322s/5424#30023
1. When "REGION CODE ERROR" shows on screen after you've input your wrong-region DVD you push "ON SCREEN".
2. When the DVD-menu is showing push "ON SCREEN" again and another DVD-menu will appear.
3. Move the arrow over to the clock and press enter. The menu asks for "TIME" and you write 0:00:00 and push enter.
4. You will now see the menu for the movie. Remove the DVD-menu by pushing "ON SCREEN" once. You can now watch the movie.
(Tested and Worked!)
Report this hack (requests/questions/spam/wrong/****).-->
icon_minipost.gifRegion code hack posted by Alex2000, October 31 2009:
Your hack is GREAT!
Works fine on the JVC XV-N342 too.
And right for JVC on the ESS chip:
JVC XV-N320, XV-N322, XV-N330, XV-N332, XV-N340, XV-N342
and so on.
Thanks!
Mar 05, 2010 | JVC XV-N322 DVD Player
Jvc dvd player no disc error
Hello!
I did have a similar problem. It was solved by cleaning the laser lenses/prisma. You have to dismantle the whole pick-up the to see the laser lenses.
There is one lens which is held by couple wires and below there is prisma/mirror.
I did use ear-cleaner-stick and desinfection liquid (with alcohol) for cleaning. Now it works!
Aug 16, 2009 | JVC XV-N312S DVD Player
Jvc dvd XV-N322S REGION CODE-2 is showing 'NO FILE'
It's a software problem pls upgrade ur dvd player.ur problem will be solved
May 11, 2009 | JVC XV-N322 DVD Player
The on screen menu doesnt work at all
Call JVC Customer Support. If no help there, take it back to where you bought it if it's not to late.
Jan 24, 2009 | JVC XV-S40 DVD Player
Disc starts to play and then locks up
All regions are not equal, and different DVD players can and will act differently when an improper DVD is loaded....accordianman
Aug 03, 2008 | JVC XV-N320 DVD Player
Jvc xv m-567 won' t read cd or dvd
The problem, ended up being the DVD drive motor. Unfortunately, it wasn't worth finding a replacement motor.
Jul 10, 2008 | JVC XV-M567 DVD Player
Not recognizing any DVD inserted on my DVD player
dust in lens mean dvd does read! clean the lens with disc cleaner! some problem comes again mean you want to change the lens!
Jul 01, 2008 | JVC XV-S300 DVD Player
XV-N40BK/XV-N44SL (NO DISK INSERTED)
Hey WeiesBlitz,
There may be a number of reasons why you may be encountering this problem, but there are a couple of quick solutions that may always try before seeking repairs on the player.
First, I would suggest making sure that the DVD's being used have been cleaned and are dust-free. Imperfections or impurities of any kind on the surface of a CD or DVD may prevent the laser in your player from being able to read, or even recognize the media inserted. You should be able to clean the DVD by using a soft and dry, lint-free (typically microfiber) cloth. Remember to try using gentle, outward strokes that run from the inner ring of the disc directly to the outer edge.
Second, you can always try cleaning the lens of the player itself using a commercial cleaning kit. Many retailers (including your local Best Buy™ store) may sell kits that clean lenses when inserted into your player like a normal DVD. Please keep in mind that not all DVD players are designed to function with these cleaning kits, and that you should always refer to your owner's manual for any possible warnings against the use of such products.
Should these suggestions fail resolve the problem, you may wish to try using other DVD's from your film library in the player. If other discs function normally, the non-functioning disc may be damaged. If using other discs results in the same error message, the player may be in need of physical repairs.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 06, 2008 | JVC XV-N40BK DVD Player
JVC XV-N412S DVD Player Logo
162 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
