Storage heater not working
I have a Dimplex CXL18N - 2.5kW Storage Heater + Convector, it has been working up until yesterday.The fuse for he convector has blown, any ideas how I can replace this.This morning there was also no heat coming from this. It is running on Economy 7.Please help.ThanksMills
  • Danny Clark
    Danny Clark May 11, 2010
    Yeah, its not goig to heat with a blown fuse.
    Describe the fuse to me and its locaton and I will help you with how to replace it.
SOURCE: dimplex dual night storage heater/convector heater
runs for 30 seconds then shuts off
Posted on Jan 23, 2008
  • 230 Answers
SOURCE: Hi - I have a
I believe the 12 is the error code for "incomplete combustion". In this case you will want to start with the thermocouple. If you are not handy at these things I would call a service tech. You can find a service person on their website.
http://www.rinnai.us/
Posted on Jun 16, 2008
SOURCE: Hi i have a Rinnai
technical by the looks of it! This is how to fix it:
http://www.paulsupply.com/files/rinnai429docs.pdf
Posted on Aug 25, 2008
  • 38 Answers
SOURCE: i have a creda storage heater 79153, i turned it
Check the fuse board it should be marked up (but often is not especially if POLISH electricians concerned) it should be a 32 amp fuse.
The heater has a thermal fuse installed internally £12 replacement, these tend to be the only things that go wrong with storage heaters! get a qualified electrician who you trust to have a look otherwise who-ever looks at it will say its F****d and will take you to the cleaners
Posted on Nov 04, 2009
  • 3087 Answers
SOURCE: Hi 1 of my economy 7 heaters has stopped working
Hi in side the case on the left hand side there is a reset looks like a flat pieceof metal push this it will make a loud click this should reset heat , turn heater off first
Posted on Jan 21, 2010
Hi, I have a Dimplex DUO500i storage heater and
Sounds like you heating coils burnt threw. how much did you pay for it? Might want to buy another.
Oct 29, 2013 | Heating & Cooling
How to operate an economy 7 heater
storage is when it stores up heat at night and convector is when you use it in the day , best I can tell you .
Oct 21, 2011 | Heating & Cooling
Hi - I have an old Glen Dimplex CLX (I think is the name) wall heater. The switch for turning on the heater broke 2 days ago. It sounded like a fuse blew. How on earth can I get this fixed?!
You say the heater is 'old', so I assume that it's out of its 2 year warranty? Are you referring to the wall-switch or the switch on the heater itself?
The customer service department will be able to give you guidance on finding the problem and resolving it. If you call 0845 600 5111 and have your series number (top left of the unit) and model (CXL) to hand they will be able to help you.
P.S. Please don't try to take the heater apart or remove it from the wall unless you have experience in working on storage heaters, as the unit is VERY heavy!
Nov 16, 2010 | Dimplex DXLWP400 Electric Wall Mounted...
Dimplex oil heater FR24. 2400W oil heater. shorts fuse box
I would suggest that the element may have absorbed some mloisture whilst being left in storage for a period of time. You may need to take it to a local repairer to see if they can dry out the element.
If there is moisture in the element it is not safe to use, hence it trips your circuit breaker.
May 27, 2010 | Dimplex Heating & Cooling
Dimplex Convector Heater EPX1000 turns off by itself
I have the same problem with 3 of the 5 EPX1000s I have fitted in my flat, although mine don't even warm up. They just immediately turn themselves off. My only conclusion is that they are rubbish. Specifically, the so-called overheat protection doesn't work. Avoid.
Jan 16, 2010 | Dimplex Heating & Cooling
My dimplex night storage heater is not heating up, the power supply is fine. Is there a fuse or trip switch anywhere
thermal heat line melted just 2years 3 weeks old should this heater have been recalled some were put in by the warm front scheme frozen old age pensioner
Dec 19, 2009 | Dimplex Heating & Cooling
I have two dimplex XLN storage heater, it was working last year but after someone put damp clothes on it, they are not working, could you help me please
It sounds as though it has tripped the internal cut-out - this can be manually reset quite easily by yourself. It would probably be best to ring Dimplex customer services on 0845 6005111 to get them to talk you through it step-by-step though.
Dec 18, 2009 | Dimplex DS5603 Heater
Dimplex storage heaters dead
sir please check the heater connection inside.then check if there are any damages in the control cables.
Mar 07, 2009 | Dimplex DS5598 Mid-Size Heater
Dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
