Connecting my laptop to my tv via hdmi
I'm using the hdmi port on side of my laptop to watch programs on my 40" samsung lcd tv but i'm not getting any sound out of the speakers on the tv or on my surround sound that is connected with a hdmi lead and an optical lead help me please. Tom
    Scholar:
  • 51 Answers
The first step is to determine whether the computer, the HDMI cable or the TV is the faulty link in the chain. I know it's a tremendous hassle to try a different TV, different computer, etc. But it will at least narrow the problem down to one component. My guess is that it's something in the computer that needs reconfiguring; that would be the most likely scenario, assuming you have a new HDMI cable.
Posted on Dec 27, 2008
What cables do I use to connect my Samsung r519 laptop to my bush LCD tv so I can watch movies
http://www.intel.com/content/www/us/en/tech-tips-and-tricks/dave-taylor-hdmi-article.html
HDMI cables but check the link if you have further questions or stop by a RadioShack with your laptop if your laptop doesn't have HDMI and let them show you the cables you will need to use with the available ports on yourlaptop
Jan 12, 2013 | Samsung Computers & Internet
When I connect my laptop to my tv with an HDMI cable the video works but the sound comes out the laptops speakers. How do I get sound to the tv?
What operating system are you using? If you are using Windows 7, right click on the Volume icon on the system tray and select "Playback Devices". A window would pop up showing you speaker and HDMI. Select HDMI and then choose the "Set Default" Button on top of the OK button. Thats it! If you want the sound to come out of the laptop again when you disconnect the HDMI from your TV, you have to do this again, then choose the speakers.
Cheers!
Mar 01, 2011 | Vizio 42 in. LCD TV
How to conect my laptop to LCD
It depends on the laptop connections. First make sure that your computer is sending data to the port (particularly VGA); you may have to access the BIOS to change the setting (often F1 or F2 on restart). If you have a VGA port on the laptop, get a video cable (VGA-VGA) and connect the two together (this is usually a blue port and you need M/M ends). Then enable in the graphics properties (right click on the display where there are no icons or running program). You want the section that lets you choose sending to the external monitor, the laptop monitor or showing the same contents on both. The version of your OS may alter which command you need (you can also access this in the Control Panel (Display). You may need to restart the computer with the TV on to get the computer to recognize the TV. Set the TV to have the source the PC input. Also connect the speaker cable from the laptop to the TV if you want to use the TV's speakers (there is an audio port next to the VGA port that I believe is a 3.5 mm jack (would need a stereo 3.5 mm m/m cable between the two). Make sure you select the optimum resolution of 1360 x 768.
If you have an HDMI port on the laptop (newer laptops), get an HDMI cable (m/m) and connect the two. Set the TV to DVI or HDMI source (depending on if you need the audio cables separate) and reboot the computer. Then enable the display, as above. I believe you still need the audio cable as well (should use a 3.5 mm stereo to RCA R/L (red/white) cable) look for the DVI audio next to the HDMI/DVI port.
I hope this helps.
(my understanding is that computer HDMI ports do not send the audio but you should check your laptop manual.)
Jun 09, 2010 | Samsung LE32R71B 32 in. HD-Ready LCD...
No sound on my Samsung 2333 LCD TV
use the menu setup and tell it how u want it to be configured and make sure tv speakers are on if u are using the tv, if not use the computer settings on the menu, u probaly already have found this out, by looking fully at the onscreen menu.
Oct 25, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
LG 37LG30 HDMI no sound problem
This is more probably a software fault within the TV. They need instructions for HDMI inputs & a no sound is a related fault. I would get in touch with your dealer to arrange the TV to be updated to cure this problem. Hope this helps.
Apr 11, 2009 | LG 37LG30 37 in. LCD HDTV
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
How to connect IBM T61 to my Samsung LCD TV 40'' 3xHDMI
If you have an s-video port you will need to buy s-video cables and a separate audio cable for sound. With HDMI you will only need 1 cable for both video and sound. Just connect your s-video cable to your s-video output ( your laptops quick reference manual should show you where your s-video jack is at ) and the other end to the back of your LCD tv video input ( consult your lcd tv manual )
Jan 02, 2009 | IBM Lenovo ThinkPad® T61 PC Notebook
Getting the TV to play through the HDMI cord
First, you need to set the playstation to display on HDMI out.
Plug the HDMI cable into the TV and into the PS3.
Use the PS3 to setup the video settings to 720p which every HDTV can display. Then switch the TV-out to HDMI and it should display.
Also consult your televisions manual to set it up for HDMI input as well. Make sure that the TV allows sound through the HDMI port as some older HDTV's didn't have that ability.
If you still have a problem; please let me know! I hope it helps you out
Aug 08, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Open Questions:
How do I fix my Toshiba laptop? Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 25, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
298 people viewed this question
David Payne
David Payne
