Replace thermal coupling of Williams wall furnace
How do you take the cover off to get to the thermal coupling nut on top? I can't seem to get it out to replace.
SOURCE: Williams wall furnace, top vent.
if your old furnace is faulty replace the unit for safety and efficiency. it will pay for itself in energy.
Posted on Dec 20, 2007
hotuna
  • 288 Answers
SOURCE: Williams gravity vented wall furnance - where is the pilot?
Its in the bottom of the heater behind the vent cover . I don't know where you are but your local gas utility will come out and lite this for free.
Posted on Dec 23, 2007
hotuna
  • 288 Answers
SOURCE: Williams wall non-elec gas heater. Black copper wire tagged thermostat?
First make sure this is a heater set up for a remote mounted thermostat. If so, the gas valve has 3 screws labeled TH (thermostat) and TP (thermopile) that's the flame sensor with 2 wires coming off it, I don't know where the goofy name comes from. there will be one screw that has both, usually the top one. Wire accordingly. The new valves have a solenoid on the bottom. this connects to the high temp. sensor up top. It has 2 wires on it, one connects to the thermostat wire, the other goes to the screw with TH and TP. Or you can skip it and connect the wire from the back of the valve to the Th and TP screw. Make sure the thermostat wires aren't pinched somewhere, thus eliminating the thermostats control.
Posted on Mar 02, 2008
SOURCE: Wall furnace model # SFB50146B Thermal Coupler. Does it have 2 wires?
if the pilot light stays lit, but the burners don't kick on, it's a problem with the thermostat or thermostat wiring, or a problem with the valve inside the gas actuator
Posted on Oct 25, 2008
  • 11 Answers
SOURCE: How to reset vent safety switch
the reset is at the top left side of the furnace. take the cover off n press the red button. the switch could be failing but CHECK drafting through the furnace. hold a flame at the top of the furnace n make sure its pulling inward. u could have a blocked vent pipe or vent cap which will cause excessive heat n tip the safety switch. good luck!
Posted on Nov 24, 2009
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
Chimney type wall furnace. The furnace won't start However after switch was off for a couple hours and turn on the switch it started. What is a possible problem?
The problem sounds like the thermocouple is not working correctly. After being off for a couple hours allowed it to cool down and reset. Sometimes you can clean the soot build up from it and it will work again. Sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 16, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
Rattling expansion and contraction noise, seems to come from header area toward top of heater
I would suggest an insulation foam. Should help to reduce the rattling and some of the expansion pops. Or you could brace the ducting, ducting is very thin metal and moves fairly easily if built real loose.
Mar 04, 2013 | Williams Furnace. 35,000 Btu/hr Monterey...
Williams direct-vent wall furnace gas pipes instalation process
There is only 1 way and that is inside the unit, How would your gas line end up outside the wall ?
I suggest you have someone who has experience do this for your safety.
Feb 19, 2013 | Williams 14,000 Btu/hr Direct-Vent Furnace...
One of the thermastat wires attaching to the williams heating on the wall became loose from the screw and didn't seem to be making little of no solid contact like a car battery might due. i tightened the...
If it touched a grounded metal surface, it is possible, leave the wires hooked up at the furnace, pull the thermostat off of the wall, disconnect the 2 thermostat wires, and then twist them together, the furnace should fire, if it does, then the thermostat is shot. Replace the thermostat, usually when there is a short, it burns out the heat anticipator on the thermostat.
Good Luck,
Paul Gibson
Apr 03, 2010 | Williams 1403622 Gas Compact Heater
I have a williams wall furnace model 5009622,and the pilot will not stay lit ,i cleaned the thermacouple,still no luck,i also then replaced thermal couple still wont stay lit,any other ideas thanx ,i was...
Assuming the pilot is clean and sharp. Before replacing the valve, clean any spade connections, those going up to the spill switch in particular. Clean and tighten all 4 connections. Good luck.
Jan 11, 2010 | Williams 2509612 Ceramic Mid-Size Heater
I have model#2509622 Williams wall heater. I just installed it and the pilot lights fine. There is a copper ground wire, but the only way the furnace will fire up is when the ground wire is in contact with...
can you manually fire the unit w/o the thermostat by shorting 2 of the 3 wires, there may be more wires than that, but you should be able to fire it on 2 to 3 wires alone let me know it sounds like something is floating voltage wise on the unit
Oct 09, 2009 | Williams 1403622 Gas Compact Heater
Williams wall furnace no longer adequately heats home
A couple thoughts. On some of the wall furnace gas valves there's a knob that you can set for low fire or high fire. If your valve has this make sure it is in the high fire setting. Is the wall furnace controlled by a wall thermostat or a knob on the heater? With the thermostat turned all the way up like to 90, does the burner and fan continue to run or is the burner short cycling. Is the fan clean and running up to speed. Some of the Williams wall furnace had a two speed fan motor so when the fan came on at first it would run on low speed. As the heat exchanger got hotter the internal fan switch would switch it to high speed. Outside of that you would need a monometer to check the manifold gas pressure.
Aug 31, 2017 | Heating & Cooling
Heating & Cooling Logo
511 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
