Question about Kenmore 85920 PowerSpin Upright Wet/Dry Vacuum
Thr brushes are not spinning and it smells
When I turn it on, the brushes are not spinning to clean and it smells almost like a burning smell. It happened while cleaning out the filter.
  • Anonymous Mar 21, 2014
    smell hot, brush does not spin
That is your belt burning, turn the vacuum upside down and make sure your brush is spinning freely. Something may be wedged in your brush.
Posted on Dec 27, 2008
What is causing the beater bar brush to spin extremely fast?
HI, it's Jim from Crucial Vacuum!
First thing is to be sure to unplug your vacuum. Once you begin smelling a burning smell it's essential to stop vacuuming immediately.
One of two things may be happing here:
1) Your brush roll may need replacing. It's possible that the sides where it attaches to the vacuum have been worn down with age. The bristles falling off is a clear indicator that it's time to replace the brush roll. Also, look for debris, or hair that's wrapped around the brush. Remove all of this with either a razor, or a scissor.
2) Check your vacuums belt. Is it wrapped around the brush roll at all, or is too loose? If so, this means there's no tension around your brush roll and it could be causing your vacuum to overwork the motor and overheat, hence the smell.
Clean this area out and then replace the brush roll and belt. You should be seeing a noticeable difference in both your vacuums suction, and a lack in the burning smell.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 30, 2015 | Vacuums
Burning smell
Something may be keeping the brush roll from spinning freely which may have caused the belt to break.
Jan 02, 2014 | Electrolux Central Vacuum
Brush not spinning
1. Make sure the belt is in contact with the shaft. 2. Remove the roller and clean the brushes AND the area that seats into the vacuum. If there is too much hair, string, etc. the brush may not roll. chances are the belt is probably not making contact. If it was you would smell rubber burning if the brush wasn't turning.
Mar 03, 2013 | Kirby Vacuums
Hoover Dimension has no suction and it smells of something burning
pets in house? check all hose passages for "hairball" clog...and check the drivebelt that spins the brush...(some have an electric motor to spin the brush, thus no belt)
Nov 02, 2012 | Hoover Bag Paper Microfilter Dimension...
My Kenmore model 116 33300300C smells like burning when we use it. The bag has been replaced
If it is a burning rubber smell it may be the belt slipping. Make sure your brushes are clean and spin freely and then put the belt back on and see if that helps.
Apr 05, 2011 | Vacuums
My vacuum was working fine, then started to smell a little funny like something was burning. Turned it off. Now when you turn it on it will run for a few minutes and then shuts off, like something is...
The smell is usually the fan belt. When the brush is stuck in place, the belt spins and burns. Check to see if the brush is free to spin. If the Belt is burnt, it needs to be replaced.
Jan 31, 2018 | Kenmore 28015 Bagged Canister Vacuum
Every so often I get a smell of burning from my g4 Kirby vacuum. I noticed it's when I'm vacuuming a fairly new rug on this house I clean. Should I be concerned?
If it is a smell of burning rubber - most likely your vacuum belt is overdue for replacement.
At this point - remove the brush roller, remove the old belt, clean off your brush roller and remove any string or hair that may be bound up around it (usually around where the belt goes or on the sides), and put on a new belt. Your Kirby should act good as new if your bag is replaced at the same time.
If the brush roller has too much string and hair wrapped around it, many times the brush roller will not spin as fast as the belt is driving it and you will get that burning smell.
Dec 23, 2009 | Vacuums
Burning smell
The bottom doesn't come apart. you have to remove the top cover to get to any components. But if you have a burning smell, then it is probably ther motor and would have to be replaced. Motors cost anywhere from $70 to $90.
Jun 14, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Kenmore 85920 PowerSpin Upright Wet/Dry Vacuum Logo
316 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
