Question about Sony VAIO VGN-CR320ER Notebook
Blue tooth receptivity between sony notebook and microsoft mouse
My Sony Vaio notebook doesn't recognize my microsoft blue tooth mouse
I have sony wireless keyboard and mouse. how can it work with other computer
It is wireless probably because there is a small usb dongle plugged into your laptop or it is blue tooth/wifi. It will possibly work with other machines if you use the dongle or pair the blue tooth or set up the wifi.
Jan 15, 2014 | Sony VAIO 15.5 LCD, Core i5 Laptop Bundle...
VAIO blue tooth mouse won't work onn my vgn-fw190
un install bluetooth driver..and software then reinstall it..if possible get the updated copy of bluetooth ..then restart pc
Apr 10, 2012 | Sony VAIO VGP-BMS33/B
Can it use a bluetooth mouse direct[sony vgp-bms33 bluetooth lazer mouse]
Hi barfowler...
No, you cannot use a blue tooth mouse with your Sony Vaio because this model does not come with the blue tooth built in.
You can buy a plug in usb bluetooth to use with your mouse for your Sony Vaio like this many places besides the one that I show you here: http://us.kensington.com/html/9403.html
Webpage for your computer specs: http://www.epinions.com/specs/Sony_Vaio_FZ21E_VGNFZ21E_CEK_PC_Notebook
Aug 30, 2011 | Sony Vaio VGN-FZ21ECEK Notebook
Blue tooth and wireless LAN does not install after installing windows XP sp3
Problem with a Sony Vaio. It seems one of the updates put entries in my registry to start a Vaio Lan Manager with Windows.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
Check these keys to see if any kind of a 3rd party Lan Manager is running. If so, delete the entries and reboot.
Feb 28, 2011 | Sony VGN-TX670P/B: VGN-TX670 PM...
Sony vaio vgn cr320E không
For the model # VGNCR320E/P, Sony has not released XP Drivers, but you can try the XP models for the other computer models. I have checked and found that all the drivers of the below mentioned VAIO matches with your model except Blue tooth. So do not install the Bluetooth driver in the below link.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR115E&SelectOS=7
Please let me know if you are able to install the above drivers. Please get back to me if any issues.
Thanks!!!!
Dec 18, 2010 | Sony VGN-CR320E/P Notebook
I got a sony vaio VPCEB3AFM laptop from USA last week blue tooth is not detecting and also the touch pad and left and right mouse buttons are not detecting
if these devices are not detected, either there is a hardware failure, or you just need the drivers installed, go to sony's website and look for the drivers for your bluetooth, and touchpad. hope this helps
Dec 08, 2010 | Sony Computers & Internet
My computer is not recognized as a sony vaio vgnt37gp
Vaio is tricky to get working right,,
you must install in this order!!!!!
  1. BIOS update (if available)
  2. Intel® Chipset (if applicable)
  3. Microsoft KB896256 (Mobile Dual Core) (only available on some models, please verify with Sony Support web site http://www.sony.com/pcsupport)
  4. Microsoft KB909667 (System stops responding during standby, hibernate or shutdown.) (only available on some models, please verify with Sony Support web site http://www.sony.com/pcsupport)
  5. Sony Notebook Control (if applicable)
  6. Sony Programmable I/O (if applicable)
  7. Sony Shared Library
  8. Video NOTE: On some newer VAIO PC models, the system will support two different graphics hardware. The setting mode is identified as:
    1. Stamina: Intel Graphic mode
    2. Speed: Nvidia® Graphic mode
  9. Audio
  10. Modem
  11. Network
  12. Camera
  13. Wireless
  14. MPEG Encoder
  15. Multi Card reader (if applicable)
  16. Flash Media (if applicable)
  17. Flash Media registry
  18. Memory Stick® media
  19. Memory Stick Registry
  20. Bluetooth® Registry (if applicable)
  21. UPEK TouchChip Fingerprint Coprocessor
  22. Infineon® Trusted Platform Module
  23. Wireless Keyboard and Mouse utility
  24. SmartWi™ Utility
  25. Cingular Connection Utility
  26. WWAN driver
  27. Any other Sony Utilities NOTE: Will be explained in the software dependency section
  28. Hard drive protection
  29. Toshiba Bluetooth application
Feb 26, 2010 | Sony VAIO VGN-T370P/L Notebook
Does Sony VAIO VGN-NR310E/S Laptop Computer have blue tooth
it does not have blue tooth.but you can connect usb blue tooth dongle. which is easily available in the market.
Dec 10, 2009 | Sony VAIO VGN-NR310E/S Laptop
Where is bluetooth module in sony t350p?
Typically, the blue tooth modules are found in the same compartment as your RAM.
Let me know if you can't find it...or look at your owner's manual
Apr 13, 2009 | Sony VAIO VGN-T350P/T Notebook
Usb device not recognized problem
uninstall driver then turn off the PC then unplug the power cord from power socket, short its legs then leave it unconnected for 5min, then reconnect it to power socket and turn on PC and install driver it should work :)
Dec 29, 2008 | Sony VAIO VGN-SZ110/B Notebook
Sony VAIO VGN-CR320ER Notebook Logo
63 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
