Question about Insignia Digital-to-Analog Converter for Analog TVs
Remote doesn't work for the Insignia converter box
Just purchased two Insignia DXA1-APT converter boxes. Trying to set up for two analog TV sets, but neither remote works. I'm wondering if it's only a change in battery needed, but think it strange that I have two and neither works.
Strange as it seems, both converters had "bad" batteries included for the remote. Bought new batteries, problem solved.
Posted on Dec 31, 2008
I own an Insignia flat screen tv, NS-LCD27, & I was given the Insignia converter box, NS-DXA1; how do I program tv remote for the box? Thanks, frances b.
The digital to analog converters did not exist when the TV was built and the remote programmed. Thus you will have more luck programming the converter box's remote to control the TV. (At least with my converter box, the included remote could only turn on and off the TV. It would only change channels on the converter.)
Most universal remotes only have codes for devices released 6 months or more before the TV was programmed. So a new universal remote will probably control both the TV and the converter box. (Program the converter box using a code for LG or Zenith set top boxes if Insignia isn't listed. LG makes Insignia video products for Best Buy.) The remotes that are programmable by a USB connection to a computer are the fastest to set up.
A replacement remote for your TV is available here: http://www.mcmelectronics.com/partfinder.aspx?brand=&mdl=NS-LCD27&mode=part . An exact replacement remote for the converter box can be purchased at: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13055197980390&smodel=NSDXA1&brand_pn=INSIGNIA_NSDXA1 . The manual for the converter box (as a PDF) is here: http://cbsdallas.files.wordpress.com/2011/01/insignia-ns-dxa1-manual.pdf .
I hope this helps.
May 16, 2011 | Insignia Televison & Video
I need to program a universal remote, a ge modal249 my Insignia modal NS-DXA1-APT digital analog converter chgang4895@yahoo.com
Since Insignia and LG share compatible codes for digital-to-analog converters, review your remote control's manual for LG VCR codes as they should work to control our converter.
Apr 19, 2010 | Insignia Digital-to-Analog Converter for...
Where can i find the method and codes to program my insignia digital converter remote for my symphonic tv
http://insigniaproducts.com/cms/documents/NS-DXA1-APT%20UM%20EN.pdf
Here are the Symphonic TV codes. These are for a universal remote OK
SYMPHONIC
520 904 906
Hope this helps. As for the insignia, if you can not click the link copy and paste. What you need is on page 18, instruction on how to program your converter. Download if you lost it and print if needed. You will need Acrobat to view this. Good luck
Sep 12, 2009 | Insignia Digital-to-Analog Converter for...
Programming Insignia Digital Box to Phillips Universal Remote
I have the Phillips Universal Remote (model#SRU4208WM) and I have the Insignia digital converter box (model#NS-DXA1-APT). The code was 0267. The Insignia converter box is the one the government grants work for.
Feb 03, 2009 | Insignia Digital-to-Analog Converter for...
Insignia NS-DXA1 APT remote control doesn't work
Set your TV input to match the input your have your Insigna connected to. Then run the Insignia setup. You are getting a distorted screen because you probably have the Insignia connected to channel 3 and the TV on channel 4.
Dec 30, 2008 | Insignia Digital-to-Analog Converter for...
No set-up menu from insignia ns-dxa1 converter box
Set your television to channel 3. Then power on your Insignia unit and run the auto-search function as described in the user manual found here - http://www.insignia-products.com/skins/skin_1/Topics/Documents/07-576_NS-DXA1_WEB.pdf
Dec 29, 2008 | Insignia Digital-to-Analog Converter for...
Lost the Welcome/Installation Menu
http://www.ezdigitaltv.com/support-files/ns_dxa1_manual.pdf
All you have to do is use the auto tuning function. Your remote control has a menu button, you can get to the feature via the on-screen menu.
If you press the menu button while the box is on and you see no menu, change your television's input to match what the box's output is.
Nov 23, 2008 | Insignia Digital-to-Analog Converter for...
Insignia NS-DXA1 - Digital to Analog converter box
I have had my converter box 5 days now. I hooked it up to the TV and set it up. No Problem. Except there are no instructions on how to set up the VCR/DVD player with it, which we use more than we do watching TV. Everything worked fine until on the second day we had it I read I could program the remote to turn the TV on and off. I followed the instructions and the TV went off. When I turned it back on, my remote went berserk. If I try to change a channel it will quickly flip through all the channels until I turn the converter box off. Same with the volume, it goes up and down, up and down until I shut off the box. The remote does not work unless you are about 1 foot away from the box. And the remote has never turned the TV on or off except that first time I programed it.
May 19, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital-to-Analog Converter for Analog TVs Logo
125 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
