Question about Sansui TVS2750 27"
Sansui 27" Have a problem with 27" sansui tv, after being on for a period of time picture starts to pull in from right side, then tv shuts off, suspect a B+ or High voltage problem, or possibly a capacitor, not sure, don't have schematic, wondering if this is a common generic problem with a simple solution.
  • Mark Moore Apr 24, 2007
    Hi
    Well, after careful examination, I see no defective solder connections or a burned loose resistor, also after use of contact coolant spray on certain components, has also turned up nothing, I wonder could the High Voltage Transformer itself be failing and causing the protection ckt to shut down the set? I notice a horizontal tearing of the picture as the deflection is pulling in from the right side too, just before the set shuts down, does this give you any other ideas?
    Novelist:
    Champion:
  • 236 Answers
I think you're on the right track. It sounds like the problem is in the horizontal deflection circuit or pincushion circuit.Maybe a bad solder connection or a resistor burned loose from the circuit board. Stargazer
Posted on Apr 23, 2007
SOURCE:
The picture has gone out on my 27 inch Color Sansui. The sound is still working but no picture. This has been going on for some time. The problem started out blacking out for about 10 min., then the pic...
there could be other causes but the first thing that shoud be checked first is the existence of dry joints that develop overtime between souldered joints due to contaraction end expansion forces caused by the heat as you leave you tv on for hours and off again. if you scruitnize the souldered areas you can see then and just resoulder the areas.
Nov 02, 2010 | Sansui 27" TV
Tv not showing picture but just horizontal line.
Failure of vertical output. Check vertical output components.
Jul 06, 2010 | Sansui DTV2760 27" TV
I have a 27 inch sansui television. It is about 5 years old and white lines have started to appear at the top of the screen. They are kind of annoying. Does anyone know what that is.
If your TV has a picture tube rather than an LCD display, you have a problem with the vertical circuit
(the circuit that "paints" the picture from top to bottom). Usually a capacitor in this circuit will open up causing this type of problem.
Stargazer
Jan 04, 2010 | Sansui 27" TV
Describe your Sansui DTV2760 27" TV Problem Loss of picture. A very thin line goes across the screen.
vertical line = bad horizontal output transistior
horizontal line = bad vertical output transistor
Oct 05, 2009 | Sansui DTV2760 27" TV
My tv shuts off after only two minutes
try using a master reset to fix this.
Sometimes after being used for awhile electronics tend to malfunction.
press and hold these buttons in this order....
power / volume up / channel down.
The tv should shut off after doing this.
Turn it back on manually.
This will reset the TVs internal memory chip.
I dont guarentee this as a permanent fix....but it worked for me.Good luck
Sep 19, 2009 | Sansui DTV2760 27" TV
Sansui 29' Tv software malfunction
i have a 29'' sansui furrato sx , the picture tube is not swithcing on , but itz changing channels, and sound also is ok , can i do anything on my own
Mar 20, 2009 | Sansui 27" TV
Tv off
my sansui tv is on no picture is coming but audio is working perfectly why?
Oct 08, 2008 | Sansui D 27" TV275 TV
Sansui 54cm TV zoom
push the pip buttton
Nov 08, 2007 | Sansui DTV2760 27" TV
Sansui TVS2750 27" Logo
127 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
