Question about Black & Decker Leaf Hog 12-AMP Electric Blower/Vacuum #BV4000
One of the two electrical prongs retracts itself into the housing
If I take the blower apart is there a replacement part I can buy to replace the plug-in assembly?
  • sgwynne40 Jan 20, 2009
    one of the prongs came out of the plug
Instead of buying a part I fixed what there was in there. The slits in the housing for one prong were a little bit too big and the contour in the plastic that holds the prongs was melted so it wasn't holding the prong tightly. I reshaped the plastic **** and the contour as well as I could with a soldering iron and pick, and filled in the rest with Sumo glue, then scraped the glue down a bit as it foamed up. Not sure if Sumo glue is supposed to be ok to use on an application like this. Anyway, the blower works at least for now, and the prongs are tight. I cleaned out enough mulching fragments I wasn't surprised I'd started having sparks before the blower stopped working.
Posted on Dec 28, 2008
The electrical works but the heating is not working
If you have absolutely no heat in the unit at all, it is likely the thermostat described in the above description, or the element itself. Both are easy to replace, cheap compared to a repirman, and can be done at the same time. Here is a video I used to replace the heating element on my dryer. I have hard water in my state and it has gone out twice in 5 years. Dryers are all very similar. A big drum with a motor to turn it and a blower that sends the air past the heating element and through the drum, then through the lint trap and out the vent. You may have to access it differently (Back vs. front panel) but they are all very similar. in addition you can normally find the part itself at a local repair shop and put it in yourself. Hope this helps, and don't forget to rate!!
Mar 30, 2015 | Dryers
Dryer was not getting hot. Pulled it apart element seems fine but it looks like it may of been overheating at one point. wires look slightly melted
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Mar 28, 2015 | Kenmore Dryers
Hi - miele dryer won't heat up and the anti-crease light is flashing when I select any programme. Have replaced the NTC sensor but it hasn't made any difference. Can anyone help? thanks
ELECTRIC Dryer no heat or little heat:
Mar 21, 2015 | Miele Dryers
Replaced the fuse in dryer still no heat, but dryer tumbling well, what can be wrong
Jul 05, 2014 | Kenmore 600 7962 Dryer
Dryer not heating
Jun 26, 2014 | Kenmore Dryers
Why is kenmore he4 dryer not heating
Jun 25, 2014 | Kenmore Elite HE4 Electric Dryer
Electric dryer won't heat
Jun 10, 2014 | Kenmore Dryers
70 series
Check venting and lint basket. blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
May 16, 2014 | Kenmore Dryers
I have a Kenmore Electric Dryer Model 66812. The motor runs, but the heat doesn't come on ... so it's not drying. What's wrong? Is it worth fixing? Estimate to fix?
May 12, 2014 | Kenmore 62802 Electric Dryer
Dryer not heating
Apr 02, 2014 | Frigidaire Washing Machines
Black & Decker Leaf Hog 12-AMP Electric Blower/Vacuum #BV4000 Logo
207 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
