Toshiba 3387DB TV
Problem for Toshiba 3387DB TV
Toshiba 3387db has stopped working
By dobbo 1 on Apr 22, 2007
the tv was wired into the stereo, via the speakers only. this gave surroung sound when the tv was on. I put the stereo on to play but the tv was on standby. the stereo worked for a while then lost sound,stero ok nothing wrong with that. the tv has died now and will not come on. there was a smell at the time??? I think somthing has popped. any one know what or how to fix it?
Solution #1
posted on Apr 23, 2007
Not Rated)
joshv
Rank: Guru
Rating: 85%, 130 votes
did you hard wire the stereo directly to the TV's speakers or audio circuit? IF thats what you mean, bad idea, you probably blew the audio amp which can hold down the power supply and cause the tv not come on
Was this helpful?
Yes
No
Popular Solutions for Toshiba 3387DB TV
Questions and Unsolved Problems for Toshiba 3387DB TV
Do you recommend Toshiba 3387DB TV?
Answer
Answer
how do i set the starting channel on my Toshiba 42" - 42ZV650U?
Answer
when TV first switched on picture is narrow across middle of screen. after upto 10 min picture... (More)
Answer
Toshiba 3377DB: My TV will not switch on, although when I push the on switch it appears to be off... (More)
Answer
tv keeps going on standby have to switch off for few secs then on then its fine for 1.2.3/8hours... (More)
Answer
tv toshiba 2987db is stick on standby tv switches on ok then goes on standby then the green light... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
