Question about 2wire 2700HG-B Router (2700HGB)
I cannot keep my connection to my wireless modem/router.
I set up the wireless router and it worked briefly, then the wireless light went out. Now I can't establish a wireless connection, I can only connect to the internet with the ethernet cord. When I unplug the router and plug it back up, the wireless light comes on and my computer detects the router but shortly after, the light goes back off and that is the end of my wireless connection. I am making sure that my wireless card is turned on and still can't detect the wireless signal.
    Problem Solver:
  • 19 Answers
The router may be bad i would take it back and exchange it
Posted on Dec 27, 2008
Was working ok then internet down and red light on router constant - have done the turn off turn on routine and reset router to no avail. have also plugged indirectly to computer - green light then comes...
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Aug 08, 2011 | Belkin N Wireless Router wireless router
I cannot access the router settings.The light keeps flashing green.I cannot manually set up my settings.It said the setup was a success, but later when I was setting the router settings it told me I lost...
Flashing green means its trying to contact the modem. So, there is some problem with modem-router connection or with the modem.
Disconnect the modem from the router and connect the modem alonely to the desktop and check.
If you are unable to go online, restart the modem/reset the modem.
After that, connect the modem to the router, then reset the router (In the back side, U can see a reset button. Hold the button upto 10-15 seconds, lights will go off and it will vary). then, power off the router and after 10 sec, make it on.
Then it will go to default settings. Now, try to go online.
If not, Call Belkin 1800 2BELKIN. Life time Free phone support 24*7.
Nov 30, 2010 | Belkin Connect N150 Wireless Router...
Wrt54gc wirless router lights keep blinking. cannot connect via wireless router, modem is ok.
which lights keep blinking ? I would do a factory reset - button on the back - hold for at least 10secs it should then reset back to the factory condition connect the modem to the wan port
quite often the default settings may work with the modem.
post back a comment and detail the status of each light on the router also the make and model of the modem and the status of each light on the modem
Mar 21, 2010 | Linksys (WRT54GC) Router
My router is suddenly not working. The internet, modem, router and the wired lights are on, but the wireless and security lights aren't on and I can't connect from my laptop wirelessly.
check the wireless settings of the router.
Open the set up page of the router and make sure that the wireless SSID broadcast is enabled.
If enabled then try to change the wireless channel of the router.
if that doesn't work then try to upgrade the firmware of the router.
Click Here for more info about routers
Dec 19, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot connect to my wireless router
If you connect the computer directly to the modem, it works .
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 19, 2009 | Computers & Internet
Internet light on wireless modem is red and wont connect to internet. DSL, Wireless and Ethernet port 4 are all connected with green lights. Wont properly connect the modem.
If you connect the computer directly to the modem, does it work?
It is very easy.
Dec 04, 2009 | NetGear DG834G Router
Has my router gone bad?
If no power lights come on... it looks bad, but try another power adapter on the router before tossing it... could be that.
Jan 09, 2009 | D-Link AirPlus DI-614+ Wireless Router
Error 51330 on nintendo wii siemens gigaset se587 wlan used.
hi
i have just solved this problem on the SE 587, hope it works for you.
1) in internet explorer type 192.168.1.1, which should bring up your router settings - then select "wireless" and then "basic wireless settings" - under "auto channel" set it to "disable" and the set "wireless channel" to "1" , then "save settings" - my pc briefly went offline and quickly came back.
2) when setting up the connection on the wii you need the code from the bottom of the router - make sure you have "caps lock" ON on the wii when you set up.
3) now everything works perfectly on the wii - you dont even need the pc on! just the router.
good luck, IAN.
Dec 16, 2008 | Siemens (120-5830-001) Modem
Wireless problem
try re-flash the router with the latest firmware version.
Oct 20, 2007 | Linksys Wireless-G Broadband Router
2wire 2700HG-B Router (2700HGB) Logo
87 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
