Question about HP Pavilion dv7-1132nr Notebook PC
No sound available
I have called the place I got the laptop from and they told me all of things I have done to make sure the volume is up and working I am doing right..... the volume is not working and it used to.
Any suggestions???
  • Anonymous Jan 15, 2009
    yes
  • Randall  Trahan
    Randall Trahan May 11, 2010
    First, make sure the mute box is not checked. Then go into Device Manager and see if they is a Yellow! or a RedX next to your sound controller. If there is then right click on it and download a new driver. If neither one of those things work, then I'm afraid you may need a new sound card...
I've had a similar problem once or twice over the years. What you're going to want to do is reinstall the audio driver your computer came with which can be done through the recovery manager. It will ask you if you want to perform a program recovery, select no. Afterwards it willa sk you if you want to perform a driver recover and select yes. scroll down the list of drivers and select the audio one. it will take a few minutes to install and then to restart your computer. your volume should be up and running again. Good Luck!
Posted on Jan 04, 2009
Microphone not working when using skype
You just have to enable it in volume control ..(just engage the sound settings in control panel and you will find the point where you have to enable the mic and its volume ..or double click on the icon for volume in the tray system on task bar ...and in the volume control tab ..select options and in there select the mic or the pink rear entry ..and enable it ..)
Another thing to do ..is open skype ..and look in the settings or preferences..and make a call set-up ..or something like that ...basically you run a check for devices ...Im not sure how its called..I know its called like that in yahoo ..but on skype may be called check devices ..or check sound..and video ..and during that it will check them one by one ..and also enable if needed..
Dec 01, 2011 | Acer Aspire 5735 Notebook
No sound on asus k52f
You may call on 1-800-585-2494 for support on Asus.
Nov 11, 2011 | ASUS K52F-BBR9 Notebook
My laptop has no sound yet I have no money to purchase a sound driver. can I get a free one
Laptop's sound can fail to work for a couple of reasons:
(1) the sound drivers are not properly installed - as far as I know, every computer manufacturer's web site will allow you to download their hardware drivers for free. Hope you've already done that.
(2) the sound hardware in the laptop are either disconnected or failed - a small number of laptops actually use separate sound cards (instead of integrating the audio hardware on the main board). Hopefully you've already checked that, too.
(3) the audio output jack (headphone) is damaged - in which case the sound hardware is functioning 100%, but there's no sound produced due to a shorted jack.
That being said, if it's neither of the above, the cheapest means of getting some basic sound to a muted laptop would be a USB sound card and a set of external laptop speakers. If it sounds elaborate and expensive, I assure you it's not. Assuming you're running Windows (hopefully XP or newer), you can buy a USB sound card on eBay for around $2 and pay about the same price for a cheap set of cheesy laptop speakers - plug the USB sound card into a working USB port, plug the speakers into the USB sound card, it's plug and play, and ... viola - you'll get $4 worth of cheap sound. It's a bit cumbersome but it's a cheap workaround that I've done before when a laptop went mute and I had only a shoestring budget to work with...
Sep 08, 2011 | Computers & Internet
I think that I need to replace my gateway laptop MX6440 series sound card. My device manager says that it is not working, I have done such things as download the latest drivers and nothing, I have even...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the side of a laptop computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 11, 2011 | Gateway (6000161) Sound Card
I have no sound when I go to the internet to play a video.
If your sound works everywhere else, then look for the volume setting right on the video itself. Most videos online have there own volume setting and it may be muted.
Mar 01, 2011 | Computers & Internet
ATR3350 Microphone: Battery in. Plugged into laptop. Recorded video. ATR3350 Mic is ignored. Audio is still recorded from my Logitech Webcam software. How does this thing work?
You need to tell your computer which microphone / sound source to use.
In he absence of other instructions it is defaulting to the built in microphone.
Normally your sound-card software should detect a new device plugged in and ask you to confirm it. However if it is not doing so you may need to change the audio settings.
How to correct this will vary slightly depending on which operating system you are using.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
Feb 09, 2011 | Audio Technica ATR3350 Microphone
I have no sound, I think I need to reinstall the driver, how and where do i do that?
First make sure you haven't done something basic, like mute or turn down the sound (Double-click the Volume icon in the System Tray to get the Volume Control settings).
Next, look in the Device Manager to see whether drivers are still installed and working for the sound (Control Panel, System, Hardware tab, Device Manager button, Sound video and game controllers).
Drivers are available for download on several websites including
http://www.toughbookdrivers.com/drivers/CF-51/
Mar 25, 2010 | Panasonic Toughbook CF-51 Notebook
Dell Inspiron 1100 Laptop with FN Volume issues.
Starbug1S1- This may have been something you have already checked but I will suggest anyways. You said you had control of your sound from other means - Sounds and Audio Devices properties was one- did you notice a check box that reads Place volume icon on the task bar. This may remedy part of your problem if you put a check in the box. Hopefully this helps. Thanks.
Feb 11, 2010 | Dell Inspiron 1100 Notebook
My windows media player has no sound,ya the volume
Assuming you did not get a device error while attempting to play there is a sound device thing in control pannel open it and tell it to place a sound icon in the taskbar once the icon is in the taskbar double click it and make sure all volumes are on high and make sure none are checked mute. If this does not work for you you may have a more serious problem and will need to repost.
Nov 24, 2009 | Microsoft Windows XP Home Edition
HP Pavilion dv7-1132nr Notebook PC Logo
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
