Question about Whirlpool GGQ8831L Gas Dryer
Consequences of using high heat in dryer
My husband uses only high heat in the dryer. Says it is faster and he can see no problems with the clothes. I say low or medium heat is better, doesn't use any more energy even though it run longer. Please explain values of each.
  • betsilja Jan 27, 2009
    I have heard and read that high heat is the least energy efficient setting. My husband feels that less drying time compensates for the higher heat. Just wondering what the facts are...?
  • 640 Answers
The vavle in using high heat only comes in to play when you have a load of towels or some other heavy cotton,,thats what high heat is mainly for,,more moisture,,,on the norm medium with a regular load is the way ..now go to the dryer and look at the back vent where the heat comes out does it look like burnt and dark as if you burnt shirt and it stuck to the iron,,that comes from high heat scortching,,rubber in elastic in your sock and other clothing...onthejob slow low and steady
Posted on Jan 06, 2009
It takes at least 2 cycles to dry clothes. It is Roper heavy duty high capacity electric dryer. Thank you for any help you can give me. janebellard@yahoo.com
Check for air restrictions which cause the heat control to shut down faster than normal.
When the moisture cannot be removed fast enough the heat builds up and has nowhere to go so the heat control stays off longer and the clothes just tumble on.
Service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 14, 2011 | Roper Dryers
My roper dryer is spinning my electric meter like a top I replaced the heating unit but problem is still there on fluff dry no heat the meter crawls but low or high heat and the meter spins like atop
I am assuming that your talking about how much energy your using. When the unit runs on full heat, your electric meter will spin as you say like a top, this is quite normal. Electric dryers use tremendous amount of energy. Going on fluff your using just the normal 120v and not pulling many amps to run the dryer. However with the unit on high your pulling more amps and are now drawing 240v to operate your unit.
If your clothes are drying than it is not the heating unit.
If your concern is the amount of energy expended, there is always the old clothes line, which is energy efficient and if you live in a part of the world where the air is clean your clothes will smell fresher than if it came from a dryer.
Oct 11, 2009 | Roper REX4634KQ Electric Dryer
Takes too long!
This may be caused by a partially burnt out heating element, a faulty thermal fuse, or a faulty high limit thermostat. I would start with the thermal fuse. It is located just inside the back of the dryer and is usually mounted on the exhaust duct. The components can be checked with an ohm meter or multimeter for continuity. If the component shows zero ohms, it is defective and must be replaced. Hope this helped and best wishes.
Jul 28, 2009 | Roper REX4634KQ Electric Dryer
Clothes smell burndt after drying in a Kenmore gas dryer
Rule number one NEVER EVER use the top of your dryer to stack piles of clothes while in use. That is the main reason why dryers over-heat. Also clean out the exhaust tube to the exterior.
Feb 21, 2009 | Kenmore 73952 Gas Dryer
The clothes dried on high or medium heat come out smelling like heated metal
hi .thanks for the question .yes i would check all venting from dryer to the outside . clogged venting, or dryer too close to the wall could cause this problem . thanks the appliance doc
Sep 30, 2008 | Kenmore Elite HE4 Electric Dryer
Heat level in dryer
A dryer usually overheats because of a kink or blockage in the duct work, blockage in the outside wall cap, or because of a defective cycling thermostat. The cycling thermostat tells the dryer when to heat and not to heat. Clean any lint from the inner and outer ductwork. You can also remove the vent from the back of the dryer for a load or two to determine if the clothes dry faster or not. If this doesn't fix it, go ahead and replace the cycling thermostat. Make sure to use the appropriate setting to dry the clothes.
Aug 09, 2008 | LG DLG0452W Gas Dryer
LG Stacking Dryer
To make sure it is a vent problem ,Do one load without the vent hose attaching to the wall ,keep in mind that it may blow out some dust, you may want to cover the end of vent hose with a nylon stocking for just this ONE time.Now run this 1 cycle on a timed dry cycle at the highest mark...60, 70,etc.If the clothes are dry at the final stopping point than you know your vent is blocked.Or you pinched the vent hose closed.It only takes a small blockage to create alot of waiting time for dryer to end its cycle.The faster the air can get out of the dryer the faster it dries.
May 21, 2008 | Dryers
Damp clothes
the dryer is not the problem the problem is the house vent it is restricted some where
May 02, 2008 | Whirlpool LER6636PW Electric Dryer
Whirlpool GGQ8831L Gas Dryer Logo
179 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
