Question about Onkyo TX-SR705 Receiver
Bose 901 iwht tx-sr 706
Hi
how do I connect bose 901 speakers with tx-sr 706 receiver. Can I also connect denon turntable dp47f to the receiver?
Thanks
  • 2 more comments
  • rmachav Dec 29, 2008
    Thanks very much for the info.
    Do I need another/seperate AMP to make the equalizier connection or can I make the loop between the tx-sr706 receiver tapein/tapeout and the equalizer tapein/tapeout?
    Thanks and Best Regards
  • rmachav Dec 30, 2008
    Thanks very very very much. I will try this and will let you know. Good to know about the Denon DP47F.
    sorry to bother you again.
    I connected the speakers to receiver's Front +/-.
    Iconnected theequalizer's Amplifier connections to receiver's tapein/outconnections.How can I control the equalizer unless I put the receiverin TAPE mode,if that is the case I cannot watch anything. Is thisconnection right? Am I missing anything. How should I make thetape-loop engaged always?
    Following are the connetions I made:
    equalizerhas AMPLIFIER CONNECTIONS AND TAPERECORDER CONNECTIONS.Currently I usedthe AMPIFIER connections(FROM AMP"TAPE OUT" and TO AMP"TAPE IN") fromthe Equalizer to connectto the RECEIVER (TAPE IN/TAPE OUT)>
    Equalizer (OUTPUT) to RECEIVER (TAPE IN)
    Equalizer (INPUT) to RECEIVER (TAPE OUT)
    THanks and Best Regards
  • speedread Jan 19, 2009
    So, on a similar model (TX-SR606) what do you have to set on the receiver to
    make the tape loop active with the equalizer? Also, is it then filtering just the front pair of speaker or _all_ the audio input (to all channels)???
    Brigadier General:
  • 8,546 Answers
You have been given some bad information, as you probably know.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as you have them will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). IF yours does NOT (*) we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious alternative place would be at one of the few OUTputs on the back, assuming you have one free to use.
* I can't find your exact manual so I have to extrapolate features.
I see on the SR70>5< there are TAPE and VCR audio OUTS. Use one of these to feed the Bose EQ if you don't have Pre Outs specifically for the front channels.
If you DO have Pre Outs for all channels you're golden.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out; (or VCR or Tape Out) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receivers speaker level setup.
*** If you use a Tape or VCR Out you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. DO NOT USE the monitor switch for that source.
You may have to get ugly with your other input components to find them all homes on the receiver. The labeling won't necessarily match up with the device types. Mine is ugly like that and I have a lot of connectors, but I have even more input devices.
If you have CD, TV Cable box and DVD (typical) you need to assess what you have that is digital and use what you can wherever you can, then the leftover analog device(s) can go into any available analog input that is left over.
Whichever of these connections you DO NOT use for the 901's will still be available for using some kind of conventional analog recording device or sound processor such as an EQ or dbx Expander. However, as with any digital receiver, selection of that device for monitoring will kill the sound from any DIGITAL source you have playing (or maybe it just won't allow you to monitor).
Posted on Apr 25, 2009
  • 24 Answers
You will need to connect the speakers to the front channels as you would with any normal set(Speaker + to amp +, speaker - to amp -, etc) then you connect the special Bose equalizer through a tape monitor loop and always have the monitor loop engaged.
Posted on Dec 29, 2008
  • weirdal Dec 29, 2008
    No extra amp is needed. Just connect the Bose EQ as you would a tape deck. The EQ should have the tape in/outs clearly labeled.
    As for the phono question, yes the Onkyo does have a phono input (according to Onkyo's website). The Denon DP47F is a very nice turntable - I have one as well :)
Will bose 901 speakers work with a AVR-4308CI
Yes they will, I have a set on a denon receiver amp ( not sur of the model # its in another town). The main thing for bose 901's is that the equlizer has to be connected somewhere beteen the preamp and the main amp, most higher power amps have a switch that opens a set of patch cord jacks that the Eq. can be connected thru. So you should verify this feature with any amp you chose. With out the Eq connected the 901's have no bass or highend sound.
Apr 11, 2011 | Bose 901 VI Main / Stereo Speaker
I cannot connect my bose 901 series v1 active equalizer to my denon av surround receiver avr-891
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
The reason: You can't use the Active EQ (or ANY processor) in a tape Monitor loop with anything but 2-channel stereo material. As soon as you activate the loop you lose digital sources.
Adding to YOUR particular problem is that the Denon doesn't have a volume-controlled pre-out to feed that amp. If you want to deal with controlling the separate amp volume manually you COULD connect the Active EQ between DVR Out and the 901 amp IN but you would have a stereo mixdown instead of true front channel from the speakers.
Bummer.
Dec 26, 2010 | Bose 901 VI Main / Stereo Speaker
I have a Denon AVR 3805 receiver. It does not have a Main Amp in or a pre Amp out in the back. How do I properly hook up the Bose 901 equalizer to this receiver? I use the 901 speakers as surround...
By properly, you must mean WITH the Active EQ.
According to this picture, you're in luck BUT...
http://www.audioholics.com/reviews/receivers/denon-avr-3805/denon_AVR3805_rear_lg.jpg
(Short answer from personal experience.)
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers. A good 100-wpc amp will do. (I like Carver)
Connect the Active EQ between the Front pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Helpful Hint: If you don't have sufficient between-speaker room for proper reflection off the front wall you CAN turn the 901's around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
Oct 14, 2010 | Bose 901 VI Main / Stereo Speaker
I have the following equipment and am going crazy trying to figure out how they get connected together. I also have the Carver Multi CD player and Carver Cassette Deck which I was able to connect to the...
Get a separate amp for the 901's and the rest falls into place.
1,2, 5) Place the 901 Active EQ between the pre/main front OUT of the receiver and the TFM-55X. Attach the 901's. Keep track of the jumpers you remove from the receiver. Or replace the jumpers with RCA splitter cables so you still have pre/main connection but can share the output with the TFM.
3) Pinnacle subwoofer (self-powered?) to the subwoofer out of the receiver.
4) Bose (AMS???) 5. As surrounds on the receiver. Place the sub module toward the rear so it mates sonically and directionally with them.
What? No center speaker? I'd get something more robust with bass capabilities, like a pair Bose 301 series 1's because the tweeters face in one direction only.
Except for the amps and the cube stuff that is essentially what I have. 6.1 with full-range speakers everywhere.
Aug 31, 2010 | Onkyo TX-SR803 Receiver
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Onkyo tx sr 705 & bose 901
No. Active Equalization is required for the 901's and not to be used with any non-901 speakers.
Sep 13, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 speakers hookup
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Jul 02, 2008 | Denon AVR588 Receiver
Is it possible to to have a home theatre with Denon AVR 3600
one option that may yield results, since the bose connection to equalizer is presently not possible is to set the speaker out put on the denon for 'small' on all but the front speakers.
and then set the delay for all speakers based on the distance to the amp.
this should result in better audio that that with the bose eq.
will work on the issue of using the eq. with the denon if you like. but, you will likely not improve on the sound with the denon set up correctly.
good luck
mark
Dec 17, 2007 | Bose 901 VI Main / Stereo Speaker
Onkyo TX-SR705 Receiver Logo
384 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
