Loud humming noise
I have a Nordyne electric forced air furnace in my manufactured home. The home and furnace are only four years old and the furnace doesn't get much use. All of a sudden when I turn on the furnace now it starts up normal and really puts out lots of heat but after about ten minutes it starts making this loud humming noise. I can turn it down to stop it and thern turn it back up and it's ok for a while longer. I am scared to keep it running when it's humming in case it is not safe.
  • Danny Clark
    Danny Clark May 11, 2010
    The only way to determine the problem is to track down the noise.
    Humming noises usually come from bad fan motors, contactors, or vibration.
    You will have to physically track down the location of the source of the noise before we can help you find the right course of action.
    Habit-Forming:
    New Friend:
  • 117 Answers
I can guarantee that the return is undersized and that's is what causing that humming noise.
Is this furnace in a closet ,if yes is there enough ventilation .
Posted on Jun 04, 2017
    Top Expert:
  • Heating & Co... Master
  • 19,466 Answers
When was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Posted on Jun 03, 2017
SOURCE: Lous Noise
It could be the blower fan is loose and needs to be tightened. If so, and you're handy, shouldn't be too difficult. Depends on the specific design.
Posted on Jun 23, 2007
pierre1811
  • 144 Answers
SOURCE: Heat pump is humming loud>
When the heat is not on. Go to the T-stat and turn the fan to the on position. With the blower now running is it making the noise? If so you probably either have something in there such as the filter that was mentioned, a piece of paper etc. or one or more of the blades on the blower wheel is vibrating. Don't let the condition persist w/o having it checked out or you may turn a simple fix into a costly one.
Posted on Jan 22, 2009
jumptrout51
  • 3361 Answers
SOURCE: Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Posted on Mar 11, 2009
  • 687 Answers
SOURCE: Anyone have a wireing diagram for a nordyne E1EH-015HA
Intertherm does not offer a wiring diagram for the E1 series anymore. So I have included a link to the E2 series. They are very similar and you may find this service manual helpful for whatever problem you may be having.
http://www.nordyne.com/literature/359a.pdf
Posted on Apr 11, 2009
breeze_ac
  • 8 Answers
SOURCE: i got a electric furnace and oil heat but when may
make sure the blower is working i believe that what make that noise.
www.breeze-air.com
Posted on Nov 02, 2009
Electric Nordyne Furnace/AC/with heat pump makes buzzing noise when turned on, registers do put out heat. Any ideas what is causing the buzzing noise?
is it only in heat? Possibly the heater contactor but I don't believe nordyne uses a contactor. could possibly be the transformer humming? many different strange noises come from units, may want to have it serviced.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 10, 2017 | Heating & Cooling
How do I know if a fuse is blown in an electric mobile home furnace? Nordyne
trip main breaker in breaker panel, open up furnace and open small door at bottom to access electrical wiring. most of the time on older furnaces , fuse is in series with low voltage red wire..
Feb 18, 2015 | Heating & Cooling
Nordyne furnace FEH017HA-04 the fan runs full force when the ac is on but half speed when the furnace kicks in
That is probably normal if it is electric heat to slow the air over the heating elements. Even some gas units do this. Check to see if the unit blower motor has wires for multiple speeds.
Oct 24, 2013 | Coleman Intertherm Nordyne Miller Furnace...
We have an Intertherm furnace in our manufactured home which is apparently a replacement furnace as this is not the brand showing on the original paperwork for the home. Problem is that it is very loud. ...
That is a common furnace for manufactures homes and yes they are loud....that is because there is no return duct on the unit and the fan sits jsut inside the door so the noise is not contained...
short of moving the furnace there is not much you can do about it...yes it stinks I agree with you... wish I could give you better news...
heatman101
Aug 08, 2010 | Intertherm P3RA-048K Air Conditioner
Neighbor's kerosene tank makes horrible noise at night
The oil lines that run from tank to furnace is acting like a guitar string. As oil is being pumped through the pipe, it is humming. Try placing an old rug on the tank to see if it absorbs the hum.
Jan 22, 2010 | Reddy HEATER RH125T 125,000-BTU...
Sears 92 gas furnace noise when not in air handling mode
a very subtle hum or buzz is normal and is the transformer that creates 24 volt control voltage continually. some are noisier than others . sometimes a tap or bending of the transformer will tweak the metal enough to make it quieter. they can also get loud if incoming voltage is not correct. incoming 120 volts on a furnace is not usually a problem but the transformers are usually wired to the available incoming 230 voltage or 208 voltage if it is a heat pump or electric heat. If it is powered by 230 or 208 volts as most heat pumps are ,then you need to verify which you have and connect the appropriate leads from the trans former to power . it tells you on the side of the transformer which to connect to 230 and which to connect to 208. tape or cap off any unused leads.since you have not mentioned any performance problems i assume the fan does come on when called for and that it is not the loud hum you hear. switching the fan switch at stat to on should bring the fan on right away. if it doesn't then you may hear a loud hum and then youll need to check the fan motor and capacitor. but it sounds like a noisey transformer from here.
Oct 28, 2008 | Heating & Cooling
Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Dec 11, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
199 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
