Question about Concord Camera Eye-Q 3040AF Digital Camera
Camera turns on & is stuck
Camera will turn on and seems stuck trying to do something. I have tried new batteries etc. but I cannot take a picture or turn on the menu. Can anyone help please.
    Genius:
  • 2,985 Answers
Tell more about the operation of the camera - is motor lens opening or zoom for example.
Posted on May 08, 2007
Camera turns on and says please turn camera off then on again, this is a never ending cycle have tried new battery etc etc, nothing works, also tried the tapping on carpet/table does nothing. please help...
The camera only says please turn off and then turn on again, when something serious is wrong. Could be a mechanical problem. like a lens that got stuck, but also when the camera can't access the memory. Please don't hurt your camera. Only when you know why and how to tap, it could help. But just tapping won't solve anything.
If the lens is really stuck, and you don't know what caused this, probably you can't solve this. When inside something broke, you can't solve this. Did you try to remove the battery for a little while and replacing it. Sometimes it can reset and forget a sensor is telling something is wrong. But really, if nothing helps, you only can get advice in a repair shop or with Panasonic.
Jan 04, 2014 | Panasonic Lumix DMC-LZ20
I have fitted a new Lens, and when trying to take pictures I am gett a fEE message in the Top digital display, I have tried changing settings but nothing seems to work... how do I resolve it?
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 04, 2011 | Nikon D2X Digital Camera
The lens will not retract on my Sony Cybershot DSC-S90 camera.
Hi there i like to inform you that its a lens guide pin problem. It is damaged or out of lens guide line. Thats why its stuck. The solution is only replacing the lens. But before that if you want to take a risk then on the camera and give a twist on the lens. Be careful. not much twist, just little. After that turn off / on the camera. If its working then fine. Other wise only the solution is contact with the service center and replace the lens.i am sure your camera lens position like a below mentioned picture.. before all this try to follow those step for luck.
1. Ensure batteries are fully charged.
May 06, 2010 | Sony Cyber-Shot DSC-S90 Digital Camera
My canon powershot s3 is ...the lens seems to be stuck in it vibrates like its trying ...lens error message apears ,it beeps and shuts off
May 06, 2010 | Canon PowerShot S2 IS Digital Camera
Kodak Z740 digital camera
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 08, 2008 | Kodak EasyShare Z740 Digital Camera
Camera keeps shutting off
Have you fully charged the new batteries
Nov 03, 2007 | Fuji FinePix A345 Digital Camera
Power button seems to be pushed down too far --- I can't take any pictures either
Button stuck down! Try removing the battery to see if lack of power will return the button. If that fails take it back to the seller under warranty terms.
Aug 05, 2007 | Olympus FE-230 Digital Camera
White screen, won't take pictures, battery door won't open!!
Sony customer support is the place to go but I suspect a new camera is likely to be a more economic option
Jul 28, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Camera freezes in any picture taking mode
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. you need professional service to fix it.
Dec 28, 2006 | Gateway DC-T50 Digital Camera
Camera Won't Turn On
have you tried plugging it to the wall AC? Use a reset button if there is one. Leave the camera with batteries out for a day or two. If nothing seems to have an effect take it to a repair shop to get a repair estimate, see if it's worth it. Good luck!
Jun 03, 2006 | Samsung Digimax 301 Digital Camera
Concord Camera Eye-Q 3040AF Digital Camera Logo
Top Concord Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Concord Camera Expert? Answer questions, earn points and help others
