Question about Toto Drake ADA Compliant Toilet with Elongated Bowl
Toto Drake ADA: Usual rush of water on flushing doesn't happen
Water flows into bowl slowly and drains slowly. The normal power flush seems disabled.  Cleansing action is not sufficient.
  • eberbee Feb 10, 2009
    I have the same problem. How did you unblock the waste line?
Problem solved.  Reason was a totally blocked waste line that resulted in toilet malfunction.  Toilet functions normally now with removal of blockage.
Posted on Dec 30, 2008
After flushing the toilet the bowl only a small amount of water comes back into bowl. This is a new problem. Could there be a clog?
Is the flapper valve closing sooner then it should? Is the water line (the 1/4" vinyl tube at top of fill valve) going into the tank or into the overflow tube? Did anyone drop anything into the flush valve?
Jul 02, 2014 | Toto Drake ADA Compliant Toilet with...
The water level in my Toto Drake toilet bowl is normal right after a flush, but often is very low a few hours later.
The bowl is cracked and is leaking down the drain. You will have to replace it. It may have cracked if the bowl hold-down bolts were overtightened, or the bowl was not able to sit flush (pardon the pun) on the floor. If the bowl rocks when it is first installed, instead of tightening the hold-down bolts, use a couple of tapered shims under the edge of it, then caulk to fill the gap and hide the shims.
Good luck.
Jun 09, 2012 | Toto CST744SLR Elongated Drake Two Piece...
The water level in the bowl is too low after flushing. Can I adjust it somehow to leave more water in the bowl?
Make sure the fill tube in the tank from the fill valve is in the overflow tibe inside tank. The tube allows bowl to fill with water to correct level.
Aug 30, 2011 | Toto Drake ADA Compliant Toilet with...
TOTO DRAKE flushes then the tank fills, stops, then slowley leaks and the water just runs on and on at a trickle pace down the overflow spout.
The rubber stopper that is inside the back of the tank is allowing water to get by do to:
(1.) Be wore out- must be replaced with a new one.
(2.) The chain that is connected to the flush handle needs to be adjusted. However, if it has not been messed with recently, then it will be the (1.)
Jim
Sep 13, 2010 | Toto Drake ADA Compliant Toilet with...
Toliet won't get rid of solids
first shorten the chain from flush lever to the flapper valve by one or two links at a time until flushing properly
second the flapper valve might need a wipedown as well as its seal (top edge of tube where water goes down into bowl) the leaking is because the flapper valve is not seating properly.. you may need to replace the flapper itself.. easy to do, and a common part at hardware store.
Jul 08, 2010 | Toto Drake ADA Compliant Toilet with...
G-max flushing system is not filling to proper level
Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
Jan 06, 2010 | Toto Drake ADA Compliant Toilet with...
The toilet makes a very loud, high pitched noise when flushed.
I recently had the same problem. to let you know I replaced the filler and the flapper to NO avail. I tried flushing with the water OFF and it still did it thought it was in the siphon so I removed the water going in there and it still made the sound. This AM it got to me so I was determined to be rid of the WHINE It only happens when the TOP is on that is when it hit me is the seal so great that the vacuum creates the whine I put the little rubber door stops, the one you use in door jams, on the four side and tada no more sound Hope this helps
Dec 26, 2009 | Toto Drake ADA Compliant Toilet with...
Flushes very slowly, not the "power" flush it used to do.
This type of problem is, for pretty obvious reasons, difficult to diagnose, especially when you can't interact with it. My guess is that you might actually have a blockage in your venting system. This system allows air in behind the water you are flushing to allow it to flow freely down the drain. If you have a blockage in it, the water has to pull air through the trap in the toilet, and that can lead to symptoms like the ones your describing. Are other drains in the bathroom running a little slower as well? Sometimes birds or squirels build nests in the top of vent pipes (which generally stick out of your roof) and end up blocking the air flow.
Sep 21, 2009 | Toto CST744S Two-Piece Elongated Toilet...
Delay on tank fill after flush. Toto Drake bowl ada elongatred
I am not a plumber but stumbled across the solution on my own. While watching the float during the flush cycle, it was obvious that it was very slow in moving downward along with the water level in the tank. The problem was that the small opening in the float chamber was partially clogged. Using just my fingers, I reached under the float chamber and cleaned off any debris that was blocking the opening underneath the float chamber. Put the float back on, and instantly the problem was solved. The tank fill started immediately after I flushed.
Mar 09, 2009 | Toto Drake ADA Compliant Toilet with...
Toto Drake ADA Compliant Toilet with Elongated Bowl Logo
473 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
