Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Dishwasher fills, when the pump is supposed to start it just whir
When the wash cycle starts after the water fills the bottom, the pump sounds like its on, but no water comes out of the jets. The dishwasher
thinks it is going through all of its cycles successfully, but if the pump
isn't pumping, the dishes never get clean. Could this be a bad pump?
  • brilyn Dec 28, 2008
    my maytag goes through a cycle and doesn't get my dishes clean. there is always small chunks of food and water in the bottom of the washer after the cycle. they get wet, but I believe the arms are not spinning and there isn't enough water pressure coming out to spray off my dishes. I took the insides apart. the arms are not clogged. It makes this clicking grinding noise at certain times while it is running.
  • 61 Answers
Hello, sounds like a broken wash impeller or a stripped drive impeller (the piece that fits inside the impeller). These two parts are driven by the wash motor and propell the water through the spray arms. good luck
Posted on Dec 27, 2008
Machine starts fills Ok but when it clicks on to start the wash pump, nothing happens, I can hear a faint hum. When cancelling wash and starting new wash it pumps out ok too. After rinse cycle it indicates...
sounds like your main circulation pump is not working, if it is humming when it is supposed to start, sounds like it is getiing power, so probably not the control circuits, can you measure voltage to pump?
if you are getting 120 there, probably pump motor is dead
Mar 02, 2013 | Asko D1876 Dishwasher
After rinse fill the pump will not start
Hello, is there water in the bottom of your dishwasher? If there is water in bottom. Then try running the dishwasher throught another washing cycle. Now, if there is not water in the bottom of your dishwasher. Then the dishwasher has finished its washing cycle, rinsing the cleaned dishes. GB...stewbison
Sep 17, 2011 | Dishwashers
I have a Neff Dishwasher S5446x0/29 FD 8109 460056. It started making a whirring noise and when I looked it was not emptying the soapy wash water. I stopped the machine and manually drained the water out....
if the pump is not emptying properly it will think its still full, they have a sensor in the bottom that tell the machine that the system is empty and to begin next cycle.
Jun 27, 2017 | Neff 24 in. S5456 Built-in Dishwasher
Shortly after cycle starts, a whirring sound starts, is this a problem with the motor?
with LG dishwashers: after starting, 1st, DW pumps out any remaining water, 2nd, DW fill fresh water, 3rd, main wash motor starts, which is normally a whirring sound. (If you here grinding or rattling, then you have a problem.)
Feb 28, 2011 | LG LD-1420T1 Dishwasher
DISHWASHER GE PDW7800J00BB DOES NOT WASH ,FILLS WITH WATER BUT NO WASH
It is unclear from your description if the wash pump starts and pushes the water around but never stops cycle or the dishwasher stops as soon as the water is filled.
If you do not hear the wash pump start then it is possible the wash motor is faulty. But if the wash pump starts and never completes the wash cycle then it is possible the heater is faulty and dishwasher is waiting for water to heat up before it can go to next cycle.
See the attached diagram for location of wash pump motor and heater.
Hope this helps you find the problem. Please rate the solution if you found it useful.
Oct 10, 2010 | GE 24 in. Profile PDW7800 Built-in...
Our LG LDF7920st dishwasher (6 months old)makes a whistling noise
Hey, consider the float assembly!
We bought this dishwasher and ran it for the last 1 1/2 months and it made a grinding and whistling sound from day one (it's supposed to be nearly silent in its operation). Turns out the drain pump was cutting in while the machine was still filling, thereby emptying the wash tub of any water. Then, when the cycle proceeded to wash, the dumb thing had no water and made a horrible noise. So I had to pitch in at least 2-3 litres of hot water, and then it worked quietly! Had to do this every time there was new water intake.
After working with the repairmen - four visits later, we isolated the float assembly as the problem and they set about replacing the part. Turns out the two parts were markedly different. LG HAD INSTALLED an older model float assembly at the factory and it was the problem. The replacement part was the correct float assembly and things worked perfectly after that - thank goodness. No more babysitting the dishwasher.
Don't let anyone tell you the motor assembly needs replacement. I have seen that cop-out 'fix' all over the web. But use deductive reasoning to find out where the problem is in the cycle, and explore this option first - it's a quicker and cheaper fix than replacing the whole motor assembly.
'Mr. Float' as he is now called works like this:
-expels any residual water in the tub from the last wash
-intakes water for the wash or rinse
-whirs 2-3 times prepping for the cycle
-begins to wash, quietly
-expels at the end of the wash or rinse.
He used to:
-expel residual water
-intake new water for wash or rinse
---drain pump would cut in WHILE still filling
-machine would whir once, realize it didn't have enough water
-perform a brief top-up intake shot
-begin to wash and whistle and GRIND (this is where I would have to add the water)
-expels water from wash or rinse, and start all over again.
It's a good dishwasher and it will work, but the right model parts have to be in place!
Jun 27, 2009 | LG Dishwashers
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Empties and fills but boils the water
Can you hear/see any washing sound/spray, it sounds to me like the wash pump could be faulty.
Nov 20, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
310 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
