Question about Water Heaters
I have a ruud oil forced air furnace, but the model # says it is a Rheem ROBC-130. My problem is that the blower motor runs all the time, the furnace will fire and run for about a minute then shut off it will fire again in about a minute and do the same thing.
    Sergeant:
  • 359 Answers
This is more than a fan control relay . it is a black relay that will appear to have several wires connected to it but those wires connect to the base ,it unplugs , if it is set up for ac it might have 2 relays one toward the front one toward the rear replace the front one first ,,, if on good replace one @ rear should fix if not let me know
Posted on Dec 29, 2008
Heater blower won't start and we get o heat! What is going on with this Rheem REAA-080c
Earl, is this a furnace heater for your house? And are you referring to the blower that distributes the heat throughout the house? And does this unit have a flame exhaust blower? This last blower is a small blower in the unit itself, if it has one you usually can spot it.
Dec 08, 2016 | Rheem Water Heaters
I have Rheem Pvw50, 50 gallon water heater installed at home. For the past few days, there is a noise coming out of blower motor. What could be the reason?
Your water heat is at an age that I would recommend replacing the whole unit. That one cannot be too efficient and most likely has sediment built up on the bottom of it pretty bad.
Jan 25, 2016 | Rheem Water Heaters
How do you clean the fan in a rheem air handler?
Pull the blower assembly...2 screws on the angle bracket holding the blower & disconnect the wiring if needed to the motor.
May 28, 2014 | Rheem Complete Split System Straight...
Aircondition builds ice on coil
Either lack of refrigerant, stopped up metering device or capillary tube/s, or lack of air flow (due to bad blower motor, or dirty indoor coil) Good luck.
May 19, 2014 | Rheem Complete Split System Gas Furnace 5...
GX90-715A wont stay fired
1) Product manual has burner info page 11, maintenance 12, and troubleshoot flow charts starting page 17
Otherwise, Rheem does not post service manuals.
http://bostonheatingsupply.com/Rheem/Rheem%20Commerical%20Gas/Rheem_CommGas_Extreme_Use%20and%20Care%20Manual.pdf
2) Post question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Is air intake clear? Is the burner sooted? Is the flame large and clear blue? Is the vent obstructed? Does air draft when blower activates?
Feb 14, 2013 | Rheem RUUD GX90-715A Water Heater,gas,90...
Keeps giving a code of ops on boiler and will not kick blower on
Are you certain this is a boiler? Furnaces use blowers; boilers do not.
Could you be referring to an induced-draft small blower motor that normally runs immediately on a call for heat?
Is there an electronic control board measuring about 6 inches by 8 inches visible?
We can help if you give us a model # and brand name. Does it operate by oil, natural gas, or propane (LP)?
Feb 02, 2013 | Water Heaters
My Rheem powervent2 water heater squeals while running
The power vent motor squeals when burner is activated?
See if you can oil the power vent motor.
http://waterheatertimer.org/images/Anode-under-blower-200.jpg
If the water heater squeals when water is turned on, then remove heat trap nipples and inserts and install di-electric nipples from water heater department local home store.
Copy following link illustrations.
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
Additional link:
Troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Oct 08, 2012 | Rheem Water Heaters
Fuirnace blower motor doesn't blow very hard and sound rough
Maybe if you put a drop of liquid soap on the shaft for the fan. Since it is a heater, I wouldn't use a lubricant like wd-40. GOOD LUCK. Soap is cheap. Hope it works.
Jul 02, 2012 | Rheem Gas Furnaces 125K BTU 80 AFUE Single...
Furnace filter is black and sooty wall seem to be sooty
   By sealed unit you mean that the burner air comes from outside of the house?      You have checked the heat exchanger for cracks by removing the burners and looking with a mirror and flashlight, correct, or had a service tech so?
The furnace burners have enough air and are burning clean (blue) with just a tip of orange at the end? You bought the house new and the fireplace has never been used?  If it has been used to clean smoke for the house for whatwever reason I woudl start by havign the ducts cleaned.   Another possibility I have seen is insolation inside of ductwork breaking down.
Jan 28, 2009 | RTO Home Heating Products 5.5HH240...
Water Heaters Logo
163 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
