Question about Kenmore 24902 Top Load Washer
Washer does not stop filling up
The washer will not stop adding water. even when in the "off" position, it will still begin to add water and eventually overflow. is this a sensor problem or something much worse?
  • red_stang94 Dec 31, 2008
    thank you so much. spot on fix!!!
  • 640 Answers
Replace inlet vavle...if you need instruction ,,post question how to replace inlet vavle
Posted on Dec 27, 2008
  • onthethejob1
    onthethejob1 Dec 31, 2008
    you had the answer yourself,,i just confirmed,,happy new year,,im here if you need me im a cross over tech ...onthejob,,,
Why is water overflowing my resivor on my pathy
If I understand correctly, your coolant (water) is overflowing out of your resevoir? Either you have too much coolant, and it doesn't have any place to go, or it is boiling over. Remeber even water expands when hot.
Aug 09, 2013 | 1989 Nissan Pathfinder
Kenmore elite he5t front loading washer door locks, unlocks, then locks again before beginning cycle
This is aself test procedure on the door locking mechanism . You will also hear a click, the drum will make a partial turn,and the door will unlock berore locking again. Once the door has locked a second time the washer will begin tumbling and adding water. The sensing process will continue until the correct amount of water is added to the load.
Feb 12, 2013 | Kenmore Elite HE5t Washer
Electrolux washer MEX731CFS0 overflows
Possible fault with the inlet valve section. It is possible that the inlet valve is open, clogged or is not working due to a faulty coil. also if there is no voltage from the program controller unit it will not be active. so check this voltage to the inlet valve to confirm.
click this link for tips : Inlet valve
Jun 25, 2012 | Washing Machines
Washer wouldn't stop filling and leaks
Hello, here is a great link to check out everything you can think of on your washer repair and trouble shooting. Make sure you really check out the different areas to click on on this site..
Here is the link. I hope this helps you, mike
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Oct 20, 2011 | Whirlpool LCR5232H Top Load Washer
GE WBSR WASHER WATER OVERFLOWS
He probably disconnected the water level sensor when replacing the belt or the timer is dead.
Check for any unconnected sensor or check if the main program button is turning propely..
cheers
Dec 20, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool washer overflowing
Water pump on the washer has gone out. Have it fixed by a technicain. Or if you are a do it yourselfer like me.
Go to http://www.repairclinic.com/
Feb 10, 2008 | Washing Machines
Overflowing and smell
needs a new pressure switch located in control panel are the small rubber hose going from the switch to the tub has a pin hole in it
Nov 29, 2007 | Frigidaire GLWS1233A Top Load Washer
Oasis water level problems
Most likely, your tape is not holding the pressure and the machine starts filling because it thinks the water is low. The new hose should fix the problem. If not it will probably mean a new control.
I would also like to know the location of the rub hole on the hose. What was it rubbing against? Thanks/Mike
Oct 21, 2007 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Water overflow
when u replaced the sensor was it the round one that has a clear pipe going to it if ti wasnt u will need to replace it if it was then take the clear pipe off and blow down the pipe this will reset the wayer pressure sensor and should stop the washer from overflowing m8
Aug 19, 2007 | Maytag PAV2300 Top Load Washer
Kenmore 24902 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
