Question about Nokia 800 XA Monitor
Nokia 800 Xi Monitor
No Display? However, I do get power and the green light remains constant. On checking the vga (male)connector, attached to the monitor - I notice a pin is missing in the second row (pin 4). Can I change the lead/vga connector fairly easily, if I open up the monitor? It is my son's monitor and would like to do simple home repair/ at little-no cost if poss. Any advice, would be very much appreciated. Many thanks Nadia
    Problem Solver:
  • 5 Answers
Actually pin 4 is supposed to be missing, that's normal. What you should do is try these troubleshooting techniques: 1. Do you get a no signal on the monitor screen. If so, there can be something wrong with the computer or you can have a short in the cord. 2. Try connecting the monitor to another computer. If it works then you've found your problem. If not, consider purchasing a new monitor. Especially if it's a CRT, because they carry some really high voltage that will harm you if you don't know what you're doing.
Posted on May 07, 2007
Model 2200W Proview LCD Monitor - How do I connect it to HP Laptop?
Since you don't provide the laptop model, I assume your PC has at least a 15 Pin VGA connector. You will need a 15 pin male VGA to 15 pin male VGA cable, just plug it at the laptop and the monitor, that should do. If your laptop has also an HDMI or DVI or Display Port, you will need a proper cable or adapter.
Jul 30, 2014 | Proview Computers & Internet
Can i get an adapter for my emachine monitor to go into a dell desktop ...my lead i have now doesnt fit as unable to screw it in
YES.
I believe it is time now for the guessing game............
1) Is the monitor about so high, and so wide?
2) Does the monitor look like a small TV, or is it flat in appearance?
3) What does the monitor cable look like?
4) Is your hair Brown, and do you smoke cigarettes?
NO.............just wanted to see if you were following along! Geez!
An Analog monitor, such as a CRT type of monitor, uses a VGA cable,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for a VGA Cable example.
Flat LCD screen monitors are Digital.
Some may have a VGA Cable attached, but the best cable option is a DVI cable,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
(Click on any photo on those two Wikipedia pages, to enlarge)
Using these two examples, does one apply to the eMachines, and one apply to the monitor?
Let us say the monitor has a DVI cable.
The eMachines Desktop PC has a VGA port. (Connector)
For this you would simply use a DVI to VGA adapter,
http://www.directron.com/dviadapter.html
Now notice...........this is a VGA MALE to DVI FEMALE.
The DVI cable on the flat LCD screen monitor, has a male connector.
The contact pins of it go into socket holes, in the DVI end, of the DVI to VGA adapter.
The VGA port on the eMachines, has socket holes.
The male VGA connector end on the DVI to VGA adapter, has contact pins.
Point?
Make sure you get the correct DVI to VGA adapter.
There is a male DVI to female VGA adapter, also.
This is just one example.
For instance I'm using an HP 2009M 20-inch widescreen monitor, AND an RCA 26-inch HDTV, as dual monitors.
Presently using the HP 2009M with a DVI cable, and the RCA L26HD31 HDTV with a VGA cable.
(I'm also using an ATI Radeon HD5450 graphics card. Pretty 'pud', but it does OK for what I want)
Primer;
A computer sends out a digital signal. To get the best graphics quality, you ideally use a monitor with a digital cable. (DVI, etc)
When you use an Analog monitor on a computer, the computer has to change the digital signal down to an Analog one.
Therefore the graphics quality is not as great.
Digital cable technology now, is DVI, HDMI, Display Port, and Mini-Display Port. And some others I'm sure I've forgotten.
http://www.hardwaresecrets.com/article/Video-Connectors-Tutorial/157
For additional questions please post in a Comment.
Also post what the monitor manufacturer name, and model number is. (Look on the back)
Are you using the VGA connector on the motherboard, (Back of computer), or do you have a graphics card installed?
If you have a graphics card installed, what is the manufacturer name, and model number?
Regards,
joecoolvette
Mar 06, 2013 | Dell Dimension 4300 PC Desktop
Keyboard lights up screen stays black....after inserting recovery disk screen still remains black...
Would like you to attach an external monitor for a diagnoses.
A VGA monitor.
Can be a CRT monitor that resembles a small TV, or a flat LCD screen monitor, that has a VGA cable attached,
http://en.wikipedia.org/wiki/VGA_connector
1) Laptop OFF, monitor OFF, attach the VGA cable of the monitor to the laptop's VGA connector.
[For the HP Pavilion dv6000z Notebook PC, the VGA connector is on the Left side at the Rear. Second port from the rear. 15 pins.
3 rows of 5]
2) Turn the monitor on. If a CRT style allow it to warm up.
3) Turn the laptop on.
By default the display should show on the external VGA monitor.
If not, press, and hold down on the FN key,
(Second key from the left, on the Bottom row on the Keyboard),
and tap on the F4 key.
(Top of Keyboard towards the left)
Still no? Hold the Fn key down again, and at the same time tap on the F4 key.
There are 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
IF, the display shows up on the external monitor, and if it is OK, the problem lies in the Display Assembly, and/or the Video Cable.
More on that in a moment.
IF, the display does Not show up on the external monitor, or if it is garbled, the graphics chipset is bad.
HOWEVER, there is a problem with the graphics chipset, for the dv6000 series of HP Pavilion Notebook PC's.
More specifically it isn't actually the graphics chipset itself, but the mounting of the graphics chipset to the motherboard.
More on this in a moment.
External VGA monitor shows a good display;
Video Cable:
The video cable is checked for apparent damage first, and at the same time, see if it's connectors are tightly plugged in.
On one end, the video cable is plugged into the motherboard.
(ALL power removed, AC adapter { Charger} and Battery, the Switch Cover is removed, and the Keyboard, far enough to lay it back out of the way. Keyboard Cable still attached to motherboard. The Display Cable is the one to the Far left, right under the left side of the LCD screen. The cable next to it, to the immediate right, is the Microphone Cable )
The video cable routed from the connection on the motherboard, up under the left Hinge Cover, and into the Display Assembly, where it then attaches to the Back of the LCD screen.
THIS connection must be checked also.
{ Just gave advice similar to this earlier. The asker's problem turned out to be a loose video cable connection, on the back of the LCD screen }
Examine the sheath of the video cable. See if there are signs of damage. If so the tiny wires inside the cable could be damaged.
Apparent damage or not, you may want to remove the video cable, and perform a continuity check with a multimeter. (Ohm's. Check each wire in the cable)
Video Cable connections prove to be tight, video cable continuity check proves video cable is OK, move on to the screen Inverter.
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED lights.
The Backlight is a CCFL for an HP Pavilion dv6000z Notebook PC.
[It is 2mm Wide, and 334mm Long. Or a little thicker than 1/16th inch Wide, and a little over 13 inches Long ]
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A screen Inverter is used to convert power (Electricity) from the laptop, FOR the Backlight, and LCD screen.
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Example of a screen Inverter for a Pavilion dv6000z Notebook PC,
http://www.nylaptopparts.com/index.php?main_page=product_info&products_id=560
The thin plastic frame that surrounds the LCD screen, and is in front of the LCD screen, (Resembles a picture frame), is the Display Bezel.
The screen Inverter is located behind the Display Bezel, and at the bottom of the LCD screen area.
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
External VGA monitor does NOT show a good display, it is a graphics chipset mounting issue, more to follow.
Regards,
joecoolvette
Jan 15, 2012 | HP Pavilion dv6000z Notebook
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
http://sewelldirect.com/dviaftovgam.asp
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
More information on the DVI connector styles, and the Digital Visual Interface technology,
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Regards,
joecoolvette
Jul 16, 2011 | Computers & Internet
I want the pictures of VGA CABLE of Samsung Sync Master 798 MB plus
Hey,
All VGA cables going to a CPU are essentially the same. Although, you may come across two types of cables. Picture 1 shows male-to-male connections. One end goes to the monitor and the other one to the CPU. The 2nd picture shows a male-to-male connector. It's always male-to-male connectors. However, you may use a male-to-female connector if you want to extend the existing VGA cable. Before buying it, just check what type of connection your CPU and monitor have at the back, for safety sakes.
Picture 1: .hak26_0.jpg
Picture 2: x hak26.jpg Hope this helps.
May 03, 2011 | Computers & Internet
Came with 2 cables for attachment - on longer type with 2 sets of pins to middle and one side and another smaller with 2 rows of pins - problem is monitor has 2 places to attach but the smaller has 3 rows...
The monitor comes with DVI and VGA (DB15HD 3-ROW HIGH DENSITY) connectors. If your PC only have VGA (DB-15HD) output for the monitor, then you need to use VGA cable (DB-15HD Male to Male) for connection. Hope I explained clearly.
Apr 01, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
Power on nothing on montior
1. Take out the battery
2. Attach the power cable only (no battery)
3. If you are not getting any power then the problem is either with your power cable or your power supply
Mar 15, 2010 | HP OmniBook XE3 Notebook
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
MAG 700P monitor display goes black after 60 seconds
Can you send pictures of the power board to me at tech@ccl-la.com I will check our service manuals for the model and get back with you about a solution.
Buddy
Corporate Computer
Jun 29, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Vga cable and power cord for monitor
The vga cable is a DB15, 3 ranks with male connector at each end,
(you can use a vga extention and add a little male to male adaptor at the female end to get finaly 2 males connectors)
And, the power cord is in fact an ac/dc adaptor, the replacement part is: 12b27-0428 (12v 5A 60w 4 pins) ...
just type de number 12b27-0428 on internet and you're on ...
Mar 12, 2009 | ViewSonic VG900b 19" LCD Monitor
Nokia 800 XA Monitor Logo
612 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
