Fuji xerox docuprint P205b red light at ! light
The light ! is red and printer will not print. unplug everything and not help no paper jam please help thanks
  • Nootan Sep 10, 2013
    After I print document just 4 pages, my printer show red light at both warning and ready. Then it can not print any paper. I try to reset and turn off it already buy still has red light. It not paper jam problem. Please help
  • 186 Answers
SOURCE: my Fuji Xerox Printers DocuPrint 203 A got
the drum or toner LED? if it's the drum, then just press the button until all the LED are ON then let go and this will reset the drum..
if it's toner, you need to take out the toner and on the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, re screw the whole cover and install back to the printer, this will reset your toner, make sure there is toner in the cart.
Posted on Feb 18, 2010
alicecelik
SOURCE: FUJI XEROX DocuPrint M205 b
i just bought a FUJI XEROX M250b and it keeps displaying paper size mismatch not allowing me to do any printing or use other application. ive read the manual over and over and i cant fix this problem. Anyone have any idea how to fix this?
Posted on Nov 25, 2011
SOURCE: Fuji xerox won't pick up paper for printing.
Managed to get it going ,pulled all the toner cartridge out and reset and all is sweet.....!
Posted on Aug 31, 2009
  • 186 Answers
SOURCE: the red light is flashing on the printer. I
take out the drum unit and clean it, normally when the drum unit is dirty with toner, it will give you error.
  • 4 Answers
SOURCE: FUJI XEROX DOCUPRINT C1110 WRONG PAPER SIZE MESSAGE
This printer have a sensor to remind the user when using a wrong paper size.
If you still using a paper that not the same with your software settings, it's still reminds you.
I solve this promblem by after print my works I just press "Cancel Jobs" button to clear a data.
Good luck.
Posted on Mar 23, 2010
Brothers HL-5370DW. Yesterday, I printed about 20 sheets with no problem. Then I set up to print more pages and the yellow paper light started blinking and the red status light came on. I checked for a...
I had the misfortune of between two sheets of paper, out of the packet, there was a piece of tape that jammed the drum.
Nothing else for it with your, take the drum and toner out and check for bits of paper.
Mar 11, 2017 | Brother HL-5370DWT Laser Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Printer won't print. Flashing red light. No paper jam and ink cartridges are ok. Please help!!
Per the manual, it's 99.9 % one of these causing the issue. The other .1 % should take it back or get a new one.
The printer requires attention. Try the following:
● If the printer is connected to a computer, check the computer screen for
instructions. If the printer is not connected to a computer, check for the following
problems:
– Top cover open
– Out of paper
– Paper jam
– Print carriage jammed or stuck
– Print cartridge inserted incorrectly
– Incorrect print cartridge installed
● If you are unable to solve the problem by using the instructions above, turn off the
printer and unplug the printer's power cord. Wait one minute, then plug it in again.
Turn on the printer.
Sep 29, 2009 | HP Photosmart 7450 InkJet Printer
Power light flashes and won't let me print - HP3650 no paper jam
Go into your control panel, go to your printer, right click it, then choose "Cancel all print jobs". You may also have to uncheck the "Pause Printing" function.
If all else fails, get the cd. remove the printer and reinstall the software after shutting the printer down and start from scratch just like it was new. If neither of those solve it, go to http://www.hp.com and download your owners manual. There you will find a troubleshooting section that will help walk you through what to do. Hope that helps.
Kevin
Sep 12, 2009 | HP DeskJet 3650 InkJet Printer
Kodak ESP3 paper jam when theres no paper
Kodak esp3 always showing paper jam .I have disconnected and followed instructions to fix through IT phoneline No joy! How can I fix this problem ? mary
Jul 28, 2009 | Office Equipment & Supplies
Says paper jam and there is none. wont let me print. tried everything
When you removed thejammed paper the paper sensor might still be stuck in an active position.
Have to pull it back in place. Just have to follow the paper path and find out where it is.
May 26, 2009 | Xerox Phaser 8400 Laser Printer
EPSON R230 PRINTER
ONCE PRINTE COMMAND IS GIVEN PAPER IS ROLLED IN AND THEN PAPER JAM RED LIGHT BLINKS. CAN NOT PRINT ANYTHING.BUT NOZZLE CHECK PRINT CAN BE PRINTED.
Jul 23, 2008 | Epson Stylus Photo R200 InkJet Printer
Paper jam
There could be a tiny piece of paper blocking the paper path or sensor. See if you can find any.
Jun 30, 2008 | HP LaserJet 1200 Printer
Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Try shutting the printer completely down & unplug power. then plug power back in and while holding down all buttons on the printer control panel, turn it back on. this should put it into a self diagnostic mode that prints out just about everything the printer can do, including a sample page. Also, be sure all rollers are clean & trays are completely closed before restarting. If the printer works when you do this, you should most liely check all settings in the software package (driver) or perhaps reinstall the drivers. If this is necessary, be sure to download the latest drivers from the Brother website.
Feb 10, 2008 | Brother HL 1440 Laser Printer
6,224 people viewed this question
k24674
Marvin
Marvin
