Question about Husqvarna Chain Saw 20" Bar
Cain saw when i pull it to start it sometimes it will start but will not idle
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 18 Answers
You might have to adjust the low on the carb, turn the low adj. all the way in and go out 1&1 half turns out. start from there. If that doesnt work you will need a carb rebuild. Also checkyour compression and cyl.
Posted on Dec 29, 2008
Homelite 330 chain saw no lubrification to the chain
Allot of times this is caused by dirt plugging up the outlet. Pull the side cover that holds the bar on and clean using carb cleaner and compressed air. You should see a small metal tube or hole where the chain runs at the top, make sure it is clear. If you remove the cain and the bar you can start and rev the saw to make sure oil is weeping, it won't squirt out.
Mar 09, 2011 | Homelite ZR10926 16" Chain Saw
Poulan 2025 chain saw, I prime it cain saw, set the choke, give it a pull, it runs for a few seconds and quits. where do I start
Probably with the carburetor, fuel lines, and fuel filter. Check the air cleaner and muffler for plugging. Make sure the fuel lines are not decayed or damaged. If the above does not help, then remove the carburetor, clean it with spray carburetor cleaner, and check the two diaphragms for hardness or any damage. Check the impulse pumping passage behind the carburetor which may be plugged or is open to the air. Any fault with these pulsations will prevent the carburetor from pumping fresh fuel into itself while running. Hope this helps!
Jun 23, 2010 | Garden
Had difficulty starting chainsaw DCS4610 for the first time. Think it was flooded. Problem now it wont idle.
Is this a new saw? If yes return it or at least ask for a recommended repair facility. Your saw is actually a Dolmar (owned by Makita) and a fine saw. In order to meet EPA requirements they are set very lean (many 5100s seize with factory settings). To protect your investment and not invalidate your warranty I recommend it be adjusted by the
professional recommended by the merchant where you purchased it or one recommended by Makita.
The starting procedure is probably similar to this:
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
Most new owners miss opening the choke after it tries to start or do not hear the pop when it does and flood the saw.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 09, 2010 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
How do I start rental model 96.
Place the saw on full choke with the switch on. Pull the rope until it fires. Place the saw on half choke, and pull again, and it will start running. Half choke should release as soon as you hit the trigger.
Mar 23, 2010 | Husqvarna Chain Saw 20" Bar
18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Feb 18, 2010 | Poulan Garden
I have an Electric Remington Cain Saw. I need
You can order Remington parts at 1-800-654-8534
Nov 18, 2009 | Garden
Mcculloch 3516 chain saw, does not always start.
It must have spark, fuel and compression to run. Your task is to figure out which is missing.
Sometimes electrical components quit operating once beyond a certain temperature. Does it always start cold and become tempermental when warm?
IMO most hard start problems on a chainsaw with a good fuel delivery system are flooded.
Start Procedure
Cold:
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
The 3516 is a MTD McCulloch (Chinese). These saws are in a class by themselves. Good Luck
Lou
Nov 15, 2009 | McCulloch Garden
Husqvarna 345 chainsaw will not start. It is 3 years old. No problem till now. spark good, getting fuel, filter, sparkplug good.
I suspect she is flooded. Flooding is the most common cause of fails to start on a chainsaw. Remove the plug I bet it's wet.
Start Procedure
Cold:
Warm:
Hope this helps
Lou
I've a 359 one time I forgot to pull then push the choke (sets fast idle). My shoulder gets sore just thinking about it.
Nov 10, 2009 | Husqvarna Forest & Garden No.967012396 345...
Blowing out gas at the start. Drained and filled with fresh gas mixture. Cleaned spark plug and srayed carb cleaner in hole. Pull choke pull cord , blowing gas out of carb. Stuck float? Buy carb kit from...
No floats in chainsaw carbs. Severly flooded most common start problem with chainsaws. Read and follow the start procedure in your manual. Don't use choke on flooded engine (may set fast idle, set then turn off)!
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
Start Procedure
Cold:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls)
Warm:
Hope this helps
Lou
Oct 31, 2009 | McCulloch Garden
Hartd to start when saw is warm
Are you choking it? You shouldn't be if hot. If no clean the air filter and try again. Are you setting the fast idle? You should be. Better? If your start procedure is similar to below and your fuel hoses have no cracks or holes the carburetor needs adjusting. A tune up might be a good idea. About $40 at your friendly neighborhood Stihl dealer (regardless of make). If taken in for tune up, get the oil/fuel ratio and use it until your next tune up (regardless of what manual says). HTH
Lou
Start Procedure
Cold:
Warm:
Hope this helps
Lou
Oct 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Husqvarna Chain Saw 20" Bar Logo
77 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
