Question about E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply
My emachine w3611 revs up and makes noise
This reving sound is annoying and has me concerned
  • 1 more comment
  • billkoch1 Dec 27, 2008
    The sound seems to be coming from th hard drive when it searches for data
    After a closer look, i realize it IS a fan (the lower of two). Could this be a sign of a failing power supply?
  • Anonymous May 02, 2009
    i have a e machine T5212 and it also makes a revving noise
  • 1,800 Answers
Try take it apart and remove any wire on the way of the fan.
Posted on Dec 27, 2008
Reving sound in car when driving
It sounds like the engine driven cooling fan clutch is locked up on this vehicle. have it checked by a local shop.
Sep 06, 2012 | Cars & Trucks
We have a 2002 chevy silverado 4x4 2500. the transmission started making a reving sound occasionally then yesterday we had it in 4 w h due to snow and it started making this clicking sound and reving...
IT SOUNDS LIKE IT COULD BE A VALVE STUCK THEY ARE ALL COMPUTER DRIVEN. I WOULD HAVE SOMEONE LIKE AT IT. IF THE FLUID HAS NOT BEEN CHANGED IN A WHILE YOU COULD HAVE THE TRANS FLUSHED. IT MAY FREE YOU PROBLEM UP.
Jan 02, 2011 | 2002 Chevrolet Silverado 2500HD
Squeeling sound while driving and especially when brakes are applied even though my brakes are new on my 2002 Sunfire . They assure me it is not a mechanical concern but it is annoying. Weather seems to...
check to see if the tabs on the pads arent bent, try sandong the pas with emery cloth to remove the glaze and reinstalling them with a sound coating between the pad and caliper, available at a parts store, either as a spray or tube, and lube the caliper slides with silocon grease
May 09, 2010 | 2002 Pontiac Sunfire
The battery cells bubble when reved over 2000 rpm
This is not cause for concern unless voltage going to battery is very high. Using a volt meter test the voltage at idle and at above 200 rpm. If it is a fair amount above 14 volts you have a faulty regulator.
Oct 11, 2009 | 1994 Yamaha XJ 600 Diversion S
My refrig occassionally makes a loud "popping" sound. It has been doing this for quite some time. Frig works fine otherwise. Should I be concerned?
The "popping" sound is more than likely to be generated from the defrost cycle that it goes through normally about 3-4 per week at varying times. If all is working well then you should have no worries as this is a normal sound that comes from the expansion of materials when the defrost heaters come on. If this sound is annoying or bothersome, you can have a noise reduction kit installed to help alleviate the sound. You may be able to purchase one at; www.repairclinic.com, or www.appliancepros.com, or from a local dealer/servicer.
Jul 16, 2009 | Maytag Refrigerators
Just had the 100k service on 04 lariat 5.4 3V
THESE ARE THE CONCERNS AND MOSTLY CAUSED BY NON FL820 OIL FILTER AND PROPER OIL 5/20. THESE TRUCKS ARE VERY SENSATIVE TO AFTERMARKET OIL FILTERS,AFTERMARKET OILFILTERS PLUG OIL GALLEY'S BECAUSE OF DETERIORATION. FL820 MOTORCRAFT FILTER ALSO HAS A ANTI DRAINBACK DIAPHRAM IN OIL FILTER TO KEEP OIL IN TOP END FOR COLD STARTS SO ENGINE WONT BE OILSTARVED ON CODSTARTS. PROBLEMS IT CAUSED IS CAM PHASERS,IF ENGINE CAN REV TO 2000RPM AND NOISE IS GONE IT'S CAM PHASERS. LASH ADJUSTERS ALSO GET DAMAGED AND CAN CAUSE A TICK NOISE LOUDER THAN INJECTORS. ENGINE IS NOT REALLY COMPROMISED AT THIS POINT BUT IT'S AN ANNOYANCE. IF WANT IT FIXED GO TO THE DEALER,THEY ARE WELL INFORMED WITH THIS CONCERN ON 5.4 3V. NOT TO CHANCE AFTERMARKET SHOP CHALLENGING THIS,PARTS FOR THESE ENGINES ARE BUILD DATE SPECIFIC AND DON'T WORK WELL WITH AFTERMARKET PARTS. SEE A VERY REPUTABLE DEALER FOR ANY CONCERNS PLEASE.
Jul 14, 2009 | 2004 Ford F150
I have 2001 carisma 1.8 gdi with a trouble code p1221, what is tis, thanks
It is an issue which concerns the throttle and the throttle body. Have the pedal position also checked.. normally this code is also associated with high reving then going into gear.
Jun 03, 2009 | 2002 Mitsubishi Lancer
E-Machines Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply Logo
304 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
