Question about Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator
Water dispenser not working in my Maytag Model #MFD2561 HES
The water dispenser is not producing water. When I push the button, it sounds like the pump is being activated but there is no water coming out.
  • fredpeggy Jan 13, 2009
    Water line freezes. Freezer temp cannot be changed.
  • 135 Answers
Hi. Do an Internet search for Maytag recalls. Your fridg. may be on their list. If this solution has assisted you, please rate it. ricardok45.
Posted on Mar 14, 2009
Mfd2561 icemaker and water dispenser not working
The water supply line is possibly being restricted by lime tuild-up
  1. Turn water off, then start your inspection at the saddle valve attached to your cold water line, then go up to the water valve attached to the unit, Remove the water line and inspect for lime build-up or for foreign material. You may have to replace both valves. Link should help you
  2. https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 18, 2017 | Maytag MFD2561HE Bottom Freezer French...
The water and ice dispenser stopped working on our Maytag side by side model MSD2456GEW. Nothing will come out and when you push the dispenser buttons there is no sound like there normally would be.
First thing to check is the water connection. If your water is connected using a saddle valve, it has probably developed a blockage. The saddle valve makes a pin-sized hole in the water pipe and it is prone to accumulating lime and water scale which slows and even blocks the water supply.
If you find that is the problem, replace the saddle valve with a 1/4" tee fitting and the problem should go away permanently.
Jan 25, 2010 | Maytag Refrigerators
Will not dispense water only ice.
I will need the model number to proceed. But it does sound like the dispenser control has malfunctioned. If you get the number for me will you be able to let me assist you. We will need to test wiring in the keyboard, control board, hinge, back to control board if needed, Let me know, Sea Breeze
Dec 17, 2009 | Maytag Refrigerators
Water dispenser inside my maytag MFD2561 refrigerator is not working. what could be causing this problem and how do i fix it?
check water supply
check water valve
check filter
check for frozen water tamk
if none of those are bad check the switch at the control,
Jul 14, 2009 | Amana AFD2535DES French Door Refrigerator
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
May 26, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Water dispenser in my Maytag french door refer has suddenly stopped working. We use it every day and the filter seems to be fine. It almost sounds like it is frozen. Please Help!!!
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator Logo
309 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
