Question about Kenmore 800 sq. in. Cooking Area Gas Grill EEK5547-K403
Kenmore Gas Grill 16219
I need to know wher ethe red cable connects to and the four black cables connects as well
  • 43 Answers
SOURCE: Gas is not getting to the burners on my Sears Kenmore gas grill.
check if regulator fully screwed to tank, turn on tank,then last burner,should hear/smell gas. if not replace regulator
Posted on Jan 07, 2010
0 characters
1 Points
The grill burners are not lighting, but the side burner does light. I have a 3 year old Kenmore grill with four burners.
Brian, is it case of the 3 ignitors not working or is it a case of gas not getting to those 3 burners? Have you tried match lighting any of those 3 burners?
I ask the above questions in an effort to determine which solution will work for you. Please advise and thanks for choosing FixYa.
Aug 02, 2011 | Kenmore Grills & Smokers
What is the NATURAL gas flow rating CFM for a Weber Genesis S-330 grill at 60,000 BTU max? I will be using 1/2" black pipe 40ft long run to the grill off a 3/4" main line - ok? Thanks...Dennis
Dennis, it's not the CFM you need to know, it's the water column inch that is required. In this case it's 7 inches. Also, if you're burying this 40' run, you can't use black iron pipe. A less labor intensive and perhaps less expensive way to go is 1/2" Flexible Copper Refrigerant Tubing. It's comes in 50' & 100 ' roles from your local home center. Even if you're not burying the line, it's a better way to go, as you'll have fewer fittings that could be prone to leaking. I
n addition, you'll also need and an inline gas shut off valve at the connection before the grill and a 12' long quick disconnect gas hose, that connects to the copper pipe connection at the shut off valve and then to the grill. This is a code requirement.
Now, with all this said, I hope you have a Genesis S-330 Natural Gas Grill. Because, the Genesis Propane Grills ARE NOT convertible to Natural Gas. And Genesis Natural Grills ARE NOT convertible to Propane.
Hope all this helped you make the right decisions. Have a great day and Happy Grilling!
Apr 13, 2011 | Weber Grills & Smokers
When i turn two burners on it works good with all four burner the gas pressure drops
The gas pressure regulator is either too small or it is not opening up all the way....
If it has worked in the past then the size is right and so it is going bad and needs to be replaced...
Sep 02, 2010 | Kenmore 463845504 Grill
One side of the grill base will not rise up when we hit the pedal. one side work, the other doesn't. any clue how to fix?we have put the grill on it and followed the instructions but only only side goes...
One one side, there is a gas strut which is connected to the other side via a cable, similar to that which you would find on a bicycle for the brake. When the strut side raises (it uses this cable and a series of pulley's) it shortens the cable and raises the other side. With use, this cable where's and can slide off the pulley. It could also be that this cable has been damaged, although the prior is more likely the case. It's fairly easy to disassemble and inspect. One regular and one small philips screw driver, along with a pair of needle nose plier are all the tools necessary. If you would like further info. please let me know.
Nov 21, 2009 | Thermos Grill2Go Fire+Ice
What is the bottom of the kenmore gas grilled called?????
Hello Dee,
Sorry you didn't get exactly what you thought you were getting but you should be able to find the model of the oven section ( top part of grill) and locate a tag of some sort that youcan bring with you to Sears ( they market Kenmore) Service deskand they should be able to track down all the parts you need to complete it ( You'll be looking for the base cabinet that matches the oven ).. They should also be able to provide you with assembly directions too.. Good Luck...
Sep 13, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
May 03, 2008 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Kenmore Elite 17680 gas grill needs a new burner. I purchased the burner, but do not know how to install it. Can this be done as "do it yourself" or does it require a serviceman?
I had a local barbeque grill retailer ( a fireplace and barbeque store which did repairs) install a new one for me. I didn't want to mess with the venturi tubes and the exact length of the openings so it would work. I am glad I did as it works perfectly.
Apr 25, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Kenmore Elite Grill will not start
The gas regulator that attaches to the tank may be bad.
May 18, 2007 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Kenmore 800 sq. in. Cooking Area Gas Grill EEK5547-K403 Logo
127 people viewed this question
Top Kenmore Grills & Smokers Experts
Dan Webster
Dan Webster
Rich Florenzen
Are you a Kenmore Grill and Smoker Expert? Answer questions, earn points and help others
