Question about Ovens
Oven door doesn't close all the way. Is there a way to replace the hinges ? If so how hard is it to do and do you have directions as to how to do this ?
  • Barry Coates
    Barry Coates May 11, 2010
    Yes, the door hinges can be replaced quite simply, but I would need to know make and model of oven if I am able to help you in anyway.
  • Ovens Master
  • 3,463 Answers
Re oven door hinges.
Try this site,I think it should help you with your prob.
In your browser bar type in youtube.com
In the search box, type in fitting oven door hinge
Then click on nthe appropiate video clip.
plz rate this solution.
Thanks.
Posted on Jan 01, 2009
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
My JenAir oven door doesn't close fully
most likely you have bad door hinges if the door doesn't close correctly,i don't know if you know this but alot of parts are no loner available for this model,it must be old,the only thing you can get for the door is the hinges and that's it,you'll need the rest of the model number to get the right hinges you're missing the last two letters,you can go here put your model number in to look up parts.
https://www.searspartsdirect.com/model-number/JMW8527CAB/1266/0125300.html
go to door and look at part 16 the hinge,hope this helps you out,when you open the door,if it sags down lower to the ground the hinges are bad,when open it should be at a 90 degree angle
Feb 01, 2018 | Jenn-Air JMW8527C Electric Double Oven
I reinstalled the door of my kitchenaid gas oven/range but the door hinge won't go in the last 1/2 inch. The door is not sealed and doesn't close properly. I have tried pushing very hard at the hinges and...
Go to this site http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
type in your model number (or at least one that is close) and look up the directions for removing and reinstalling the oven door. Sometimes you have to open the door fully after reinstalling to get the mechanism to work correctly.
Dec 22, 2010 | Ovens
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
I removed the oven door and took out the hinge to clean. When I tried to put the hinge and oven door back the hinge will not close it is stuck. How do I unlock or hook the hinge so my oven door closesI
You will have to pull the oven dorr up and out again, it might be a little hard to pull but the door didn't went in straight and it's preventing the hinge from closing. go to repairclinic.com for an ilustration on how the door and hinges fit in place.
Jan 14, 2010 | Ovens
Doors don't shut all the way and light stays on
It sounds like your door hinges are worn, usually on older ovens due to weight of door. Most oven doors can be removed by simply raising the tabs/ fitting small screwdriver on both hinges(refer to user manual) etc. Once door is removed you can place a medium size screwdriver or similar in the hinge slot, pushing the hinge plate on the bottom in an outward direction, thereby bending this plate(very slightly) forward. This will make the door close fully, activating the door switch, and turning off the oven light. This is only a short term solution, as this hot air escaping can lead to further problems. Hinge pair will need replacing. Door hinges are spring loaded ALWAYS KEEP FINGERS AND HANDS CLEAR OF LOADED HINGES.
Sep 18, 2009 | Jenn-Air JJW8230D Electric Double Oven
Thermador oven door won't close all the way - seems like the seal is holding it open. I can press and hold it closed, but if I release, it pops out. The oven light stays on all the time. Model smw272
Have exactly the same situation. All the solutions I have seen talk about replacing the hinges or seal. But people report the same thing happens a month later. Looking hard at the door what it needs is something to pull it right at the top. So I installed a rare earth magnet from www.kjmagnetics.com I used part number BX884DCS which costs $4. It mounts with a couple of screws and I put it on the door a couple of inches down from the top.
Its possible that heat from the oven will kill the magnet over time but for $4 I can replace it for a lot less than hinges and it works great. The door closes more securely than it ever did when the oven was new.
Hope this helps.
Aug 05, 2009 | Thermador SMW272 Electric Double Oven
Oven door does not fully close
The usual reason for oven doors not closing properly, is weak door hinges,if it does not close all the way, and the door seal is o/k, then I suggest you replace both door hinges. Please rate my solution. Thamks.
Jun 06, 2009 | Amana AOCS3040 Electric Single Oven
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
Mar 08, 2009 | KitchenAid KEBC208 Electric Double Oven
My oven doors wont close all the way
When the door came open you may have bent the hinges. Open the door fully and it should stop at 90 degrees. If lower than that, then the hinges are bent and will need replaced. Also you may look at the install directions and see if your model shows removing the door. If it is removable for install, you can try removing and reinstalling the door. It is possible with removable doors for them to slide up during install and then they are out of alignment for closing. Hope this helps.
Jan 04, 2008 | GE Profile JTP56 Electric Double Oven
Ovens Logo
333 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
