Question about SkyGolf SkyCaddie Handheld GPS Unit
Failing to recognize any GPS signals - it gives no distances
This is an SG4 about 18 months old. I just started using it again after a layoff of a year and loaded a new course using the Mac interface. All went well but when I took it to the course (Shoreline at Mountain View, CA) it failed to recognize any distances. All else seemed to be working fine.
    Genius:
  • 1,239 Answers
Hi
It doesn't "attach" - it re-radiates the GPS signals.
A typical re-radiating antenna setup receives GPS
signals via it's own antenna, amplifies them, then
transmits them 'down the wire'. If the wire ends in
an appropriate antenna, the signals are radiated
from that antenna. Depending on the design, the
re-radiated signal may be received even if the GPS
receiver is 'some distance away'. For example, in
the Garmin headquarters in the call center they use
this to enable call center staff to receive GPS signals
at their desks when working on support calls.
There is a potential problem when using your GPS outdoors,
which is that the GPS antenna needs to be blocked from
it's normal reception of GPS signals, so it receives
only the re-radiated signals.
Because the re-radiated signal strength has been amplified,
it is usually enough to place the re-radiating antenna
in close proximity to the GPS's antenna.
On the etrex series, some people just use a rubber band
to hold the re-radiating antenna onto the etrex.
Posted on Dec 27, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 27, 2008
    If I remember correctly, the Tri-M Mighty Mouse antenna provides something
    like 28db gain. I don't know what the gain of the quadrifilar helix is. I
    doubt it is so high that 28db gain from the mighty mouse only gets the
    signal back up to the level of the quad-helix. 16.5 ft of RG174 should only
    give about 6db attenuation at 1500 Mhz. You should definitely see a major
    improvement in signal level between the quad-helix and the mighty mouse
    under identical reception conditions (EMI notwithstanding).
  • 1,800 Answers
Well try to give it a soft reset.
or hard reset.
soft reset= from the settings of ur unit
hard reset= there is a small hole press it with a needle and try again.
How is a pilot supposed to find out their distance in miles from an airport they're landing at?
Using the old (pre GPS) method you would use the sectional and plotter (aviation ruler) and measure the distance. Using a GPS you can usually turn on distance rings on the screen or if you have the airport selected as destination you can read it right off the screen. If it's your home base you should learn the landmarks and their distances from the airport. In the Miami area, there are so many airports and landmarks, if you're flying there, during your preflight preps you should measure out distances to some landmarks that you plan to pass over and mark them on the chart or flight log.
Jan 04, 2017 | Aircrafts
How to use gps receiver for land surveying?
It is quite simple to explain the question. But before that, you must also be aware of the fact that GPS is one of the major tools used in surveying, but it hasn't replaced the entire old-school system of surveying using facilities like electronic distance meter and so on. GPS needs no introduction. It means global positioning system, and it has become one of the most common features in mobiles and many other electronic gadgets. However, the roots of their usage started from surveying. GPS is used to map the location of the place that we are working on and also measure the distances between various points. It is added to the station (any point that has the central control) from where the signals are sent and received. It can happen in three ways, and they are Static GPS baseline, Real-time Kinematic Observations and Continuously Operating Reference Stations. Check out here and know more about it - Drilling Contractor Perth WA Australia Wide Hagstrom Drilling
Feb 08, 2012 | Vehicle Parts & Accessories
1997 chevy blazer s10 cranks but wont start
You have a new battery and it cranks. Turning over is cranking. You are saying it won't start after sitting for six months? What is an old mechanic? Was the cable installed at home during the one year layoff? It sounds as though you failed to hold the old mechanic responsible for installing the correct cable or adjusting the one you have ,so it will start. You have a safety switch issue by the sound of it. Make sure you have the right cable and then find out how to install and if applicable,adjust properly
Feb 07, 2010 | 1997 Chevrolet Blazer
When using my garmin to track exercise while on my stationary trainer, the Garmin does not record any speed or distance. I do have the cadense sensor installed and all of this seems to work fine when using...
The garmin works off of a GPS signal. If you are not moving, the GPS signal doesn't pick up any movement . . . .because you are not really moving. m Therefore, the speed and distance is nil.
Jan 27, 2010 | Garmin EDGE 705
I was in Dallas Texas and turned off my GPS. I arrive in Baltimore Airport and reinstalled my GPS. At this point of time it still showed the Dallas Airport area and would not resink up to Baltimore. I...
When its receives a signal from a satellite it receives also information about satellite positions in the coming days. When you boarded the plane you must have turned off the GPS, so it could not keep track of your position. You land a long distance away and turn GPS on. It starts to search for the satellites according to the information stored in it that pertains to their positions over Dallas. It is unable to lock on the satellites. And then it was able to receive GPS signals from other satellites and all fell into place.
Yes it will happen again if you travel long distances in a short period of time. If you cannot keep it turned on during the trip, you should try to update satellite positions through Internet after you reset the time zone.
You should also be patient, and give it time to find its bearings.
Jan 21, 2010 | Fine Digital FineDrive 400 GPS Receiver
Tomtom one sat nav 18 months old is now taking upto 5 minutes to get a gps signal. When desination is entered the calculation is done tap done and continue then it says gps signal was lost and takes...
try downloading tom tom home to your computer and use your dock or cable to connect it to your computer, switch on your tomtom and allow it to connect to your computer and updates should automatically happen, this should fix it, good luck
Aug 26, 2009 | Tomtom One XL GPS Receiver
I used my 705 on my trainer and it did not record distance or speed like my forerunner does. The 705 works fine on the road
the Garmin Edge series rely on GPS to track your location from point A to point B thereby calculating your speed and distance. Its no different from any other GPS unit which require a clear view of the sky. It does not sense wheel movement, so using any GPS on a trainer will show no movement and using it indoors will give you a bad signal. The sensor on the crank used on the Edge 705 is only for cadence and not speed.
Jul 16, 2009 | Garmin Edge 705 Handheld GPS Receiver
Garmin Nuvi 265 GPS wont recognize satelite
Look near the SN # and press the reset button.
Jun 14, 2009 | Garmin nuvi 265 Car GPS Receiver
Distance of Last Shot not working
you have to press the enter button, the bottom left hand button, while standing over where you took your shot from. It will then tell you the distance once you are again standing over your ball.
Feb 15, 2009 | Garmin GolfLogix GPS Receiver
SkyGolf SkyCaddie Handheld GPS Unit Logo
85 people viewed this question
Top SkyGolf GPS Experts
Oloyede Monsuru
Marvin
Marvin
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
