Hard drive failure
Firstly thanks so much for your help, im currently at the recovery console in dos after doing what you said, what should i type?
  • 238 Answers
Hi, you have nothing to type there. You mean you have chosen the 1st section that opens recovery console,right? not that one. You should see the Terms of Agreement in your WinXP cd first, press F8. A section containing to install a Windows XP appears, Press Enter. Then that's the time it will search for your previous Win xp installation. In will then let you choose whether you will install a fresh copy of WinXP OR to Repair it. Choose the Repair. It will automatically repairs and format your Harddisk without deleting your files in it.  IF there's no Option to repair it, that's the time you will have to go to Recovery Console.
  • To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
    Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
    When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
    If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
    When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
    At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
    For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
    For information about a specific command, type help commandname at the command prompt, and then press ENTER.
    To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
If still you cannot get through to that, drop me a comment again and tell me what you have done. Feel free to ask me.
Posted on Dec 28, 2008
Biostar TA790GXE 125M keeps shuting down when I boot windows, on SATA and IDE hard drives
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 31, 2012 | Biostar TA790GXE 128M 5.x Motherboard
Tip
Share hidden division of rapid delete
Several ways of rapid delete hidden division
We install the system, may encounter this problem computer can install Vista or install version of Windows xp, a Ghost installation of xp not contain is constantly to restart. The cause of the fault is that a series of PinPaiJi cabin hidden division. Sometimes the technical personnel to help us system, also can be in a hard disk, and you will see division, also not afraid you miss delete their recovery operation convenience. How to delete the hidden division, I collected many operation method, are as follows:
1, delete the ordinary hidden recovery
Disk management, drawing on disk partition in hidden division, right click delete disk partition ".
2 the notebook, delete Lenovo 42T3403 Laptop Keyboard LEOS
The new generation of LENOVO laptop, called "using a key LEOS" hard to restore technical data backup, restore, this function is integrated in the BIOS by a program and WINGDOWS one under the interface of software interaction, namely on disk to establish a division of division, the implication of the backup, (which is also usually say the disk C), in order to destroy a key file system, ordinary operation of the C can modify the area before 5G) to (approximately delete it, actually not difficult, first appeared in LENOVO reboot your computer, interface into the corner by the keyboard "resume/custom" button will appear a key recovery of concise interface, here only two options, one is the system restore, another is the software and drive, then click "order", and the Shift + B input password "LENOVO" will appear a key recovery in the interface standard interface, select uninstall backup. If the above methods cannot be solved, can use to start running under the Dos, CD LEOS management software. LEOSTOOL/DB, typing, then turn backup LEOSTOOL/DLEOS "type" can put lenovo backup system deleted.
3 and delete IBM Thinkpad G41 Laptop Keyboard HPA's
Currently the notebook HPA mostly by Phoenix First EareRecover - established in software, software component to delete, for a series of notebook, ThinkPad Recovery of Recovery CD directory is the component -- Fwdelete, want to delete HPA, must First in the BIOS setting, enter the BIOS ThinkPad notebook, select "Security -- Predesktop Area" will "Access" to "PredesktopArea IBM Disable". Then use CD to DOS, in Fwdelete input "DOS interface DRV = 0all" and enter, can be deleted, HPA stubborn zoning after you can use all the hard disk space.
4, delete the notebook HPA associations
Some of the Dell Inspiron 1501 Laptop Keyboard notebook to associate the hidden division by lenovo Hddfunc tools HPATool/unloading unloading, Hddfunc use simpler, with CD to DOS mode, and then run in the DOS commands "Hddfunc/d" can be hidden disk backups unloading, for Hddfunc not delete HPA zoning, need to use HPATool, under HPATool type "in the DOS CLR", can/could have removed the module record.
on Aug 09, 2010 | Computers & Internet
Each time during starting up my VAIO EB33 shows smart failure warning,immediately back up your data,a hard disk failure may imminent. Now i want a solution that will fix the problem.
I'm afraid that the error means you're hard drive is about to get busted the best thing to do about this is to back up the data on your computer to an external hard drive or burn them onto cd's or if they are not that many you can save them to a USB Flash drive.
It may also be wise to contact Sony support so they can do a hardware check on your hard drive, If it's still under warranty they may even replace it for free.
May 03, 2011 | Computers & Internet
I have a Dell Latitude D610. It acts like Windows XP is starting then goes to the blue screen with the massage "Stop: coooo218 {Registry File Failure} The registery cannot load the hive (file);...
Follow this instructions http://support.microsoft.com/kb/822705 to repair the Operating system and retrieve your files. Or you can just reinstall the Operating system to make things easier if you dont have any important files in your computer.
Dec 29, 2010 | Dell Latitude D610 Notebook
Safeboot corrupted (error 92h)
Check the BIOS setting to see if the hard disk is detected. If not either the hard disk controller or the hard disk is faulty.
First thing I would try is to remove the hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an external hard drive and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services.
Jun 24, 2010 | HP EliteBook 2530p Notebook
My sony laptop with windows xp home media center keeps rebooting
When XP gets into the rebooting mode, you will have to run a chkdsk or do an XP repair. You will not lose your data. But you do need your recovery cd or a WinXP cd.
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Type chkdsk C: /R at the prompt in the recovery console.
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
Lastly, your drive can be taken out of the unit and set into an enclosure or adapter. The data can be saved, the your hard drive can be formatted and programs and data reinstalled.
Good Luck,
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 10, 2009 | Sony VAIO VGN-NR120E/S Notebook
Hard Drive Data Recovery
Well, in your case the MOST effective way is to try some so-called data recovery software.
First of ALL - Connect your hard drive to your personal computer. And install this software Wondershare Data Recovery on the computer in order to perform data recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem!
Jul 04, 2008 | Computers & Internet
Hard drive cant boot
If you're running Windows XP, put your Windows XP (or recovery) disc in, load Windows Setup, then press R for Recovery in setup. You'll be asked eventually which installation of Windows you want to use, it's usually 1. It'll ask for an admin password, if you haven't set one, hit enter. Then type "fixmbr" and confirm the action. Restart, then that should sort your problem.
Sep 08, 2007 | Computers & Internet
Missing or corrupt \system32\hal.dll
You didn't need to replace the hard drive if there is a missing NTLDR file, it just means that the boot sector is missing or corrupt. You can fix it by putting in your WinXP CD, and choosing REPAIR.(This is known as the Recovery Console and it's in DOS just to warn you...) Then you can type the following at the dos prompt: fixmbr - Fixes corrupt master boot record fixboot - Fixes corrupt boot sector bootcfg /rebuild - Fixes corrupt or missing boot.ini
Mar 28, 2007 | Western Digital Scorpio WD800UE 80 GB Hard...
Error message
Details please. Computer Type Operating System etc. Try booting from your OS CD, and see if you can get to a recovery console or DOS prompt and read the drive.
Jan 01, 2007 | Seagate Barracuda 7200.7 80 GB Hard Drive
Computers & Internet Logo
88 people viewed this question
Alun Cox
David Payne
David Payne
