Question about KitchenAid KP26M1X Stand Mixer
Kitchen aid mixer stopped working
Sometimes it would work on one speed. Then it stopped all together.
  • 16 Answers
Nieu, I'm not sure what kind of mixer you have nor am I should what the one speed is.  In my case, I have KA 575 watt professional 6 model that would operate at only the highest speed regardless of setting. If your problem is similar to this, I would recommend that you first check the Hall Effect sensor which determines the mixer’s speed.  I bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My mixer worked as good as new! But I was curious to know if my original sensor was defective, so I put it back in mixer and again made sure all of the connections were tight. Guess what?  My original sensor also made my mixer work! There was absolutely nothing wrong with the original Hall Effect sensor except that the connection between the control board and sensor was not tight--unfortunately I didn't check the connection before I decided to buy the new sensor. My best guess is that the connection between the control board and the sensor probably loosens and comes undone over time from use and vibrations. Follow these steps:
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall Effect sensor looks like. BTW the part number is 9703312 for my model.
2.  You'll need a phillips head screwdriver to open up the mixer gear case cover.
3.  Make sure that the connection between the control board and sensor is absolutely tight and snug.
4.  Also, make sure that the orientation of the sensor is correct.  It's difficult to tell which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or down. After you've made the connection, run the mixer. If it still doesn't work, disconnect the sensor, reconnect it with the prongs facing the opposite direction and try it again.  I actually found the right sensor orientation through a little trial and error.  But by going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work if it were reconnected with correct orientation.
5.  This whole process probably takes less than 10-15 minutes to perform.
6.  Use your common sense and make sure to unplug the mixer before checking, connecting or disconnecting anything.
Posted on Dec 30, 2008
Kitchen Aid K5SS mixer runs for a little while then stops
Check the carbon brushes, they could be worn out. Apart from that you will be pulling it apart to find the burning, that's where the fault will be.
Jan 22, 2017 | KitchenAid Food Mixers
How do I replace a kitchen ais speed control lever on a kitchen aid 4.5 quart mixer
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
This is a full tear down manual for your mixer, you will need the new speed control switch, spring and bar about $12.00 and new grease and new gasket all together about $40.00 dollars for all parts. It will take about an hour and a half to two hours. OH!!! and a roll of paper towels, but better a handful of throw away towels works much better. I hope this helps you, please let us know so we can help FixYa.
Mar 01, 2015 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid mixer only goes 1 speed
The number in your question (9706529) is for the worm gear.
What is the model Kitchenaid mixer you have?
Jul 21, 2014 | KitchenAid 9706529 Stand Mixer Worm Gear...
Funky speed
Could also be a broken wire to the control plate. It's not very often the plate itself. Just looking in there while operating the lever may reveal something. The shaft at the bottom that moves the plate closes a set of points to start the mixer, maybe the points are loose and not closing when they should. Just be careful operating it with the cover off and alive.
Dec 28, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
Kitchen aid switch not working
Which switch speed or head lock? What are the problems? Need more info to help.
Sep 07, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Who repairs kitchen aid mixers
Call the Kitchen Aid small appliance warranty office and they will tell you where the authorized repair person is that is close to you.
Dec 16, 2012 | KitchenAid K45SS Classic Stand Mixer
No power to my kitchen aid mixer
please i need help kitchen aid mixer i have no power
Jun 27, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchen aid growls at slow speed
Hello again, BCPSBT. I’m sorry, but I’m just a little confused because neither the Part List nor the Owner’s Manuals go into any detail about changing/replacing the lubrication grease in your mixer, so I’m not sure what you are referring to when you say your system ‘times out’ when you get to page 10 when you attempt to download it?
The Parts List manual is only 8 pages. Are you perhaps attempting to download the Owner Instruction and Recipe manual instead, which is much longer?
The reason you need the Parts List Manual K45SSWH-0.pdf (2730.37 KB) is to see the ‘exploded views’ which will aid you in the disassembly and reassembly of your mixer. The best instructions for regreasing you mixer are from these two websites:
I’m sorry I don’t have more specific step by step instructions to offer you. Sometimes you have to step out in faith and trust that you can actually accomplish the work yourself.
I wish you good luck in completing your ‘oil’ change.
Good luck and have fun. I hope this provides a little more clarification. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
May 07, 2010 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
883 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
