Question about GE JVM1490 Convection/Microwave Oven
On replacing nite-lite/under hood bulb, 1 lead broke off in the socket
In my GE Spacemaker JVM1490, I have replaced the bulbs several times - even if I don't touch the bulb at all, they seem to burn out all too often. Anyway, my current problem is this: Last time I pulled the bulb out, one of the bulb's leads broke off in the socket. I cannot reach the end of the broken lead with pliers - nothing protrudes from the opening. So I've been living without the light, but it's annoying. Do you recommend replacing the socket and is that something I can do alone, or is this a service call? I haven't attempted to unscrew anything - I'm worried that it'll be hard to put back together if I try. Any suggestions gratefully received - thank you.
  • Anonymous Mar 08, 2008
    replaced halogen bulb and the low level of light (nite Light) won't funchion
  • GE Master
  • 9,149 Answers
Be sure to disconnect the oven from the power line before removing or installing bulbs or working on it. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Apr 23, 2007
I have a GE Spacemaker Ovenover the range. JVM1490. There isn't a light that goes on with cooking anymore. Can't find how to replace it.
After disconnecting the power, you should be able to remove the control panel by removing a couple screws from the side or bottom. Once the control panel is removed you should be able to see the bulb.
Nov 05, 2017 | GE Microwave Ovens
On our GE Spacemaker model JVM1350 the socket for the surface/nite light is loose enough that tie bulb and socket wiggle when the door is opened or closed such that the light flickers off and on. I thought...
In most cases the bottom panel can be removed if not the whole unit will have to be dropped. If the bulb is not loose u can bend the center conductor of the socket out for better connection. Or just replace the socket.
Apr 30, 2014 | GE SpaceMaker Microwave Ovens
Bulb on ge microwave keeps burning out
Hi anything is possible being that you even replaced two different brands of bulbs. I don't think the wiring harness is the problem but like I said anything could be the problem. Might I make a suggestion. Why not replace both the left and right side bulbs with LED bulbs with the same base configuration. Maybe that just might be able to solve your problem. I would like to know if it does. It also seems that a lot of others are having the exact problem. Good luck.
Marty
Apr 14, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
GE JVM1640WB004 light bulbs break off when trying to replace them
GE uses a bulb that includes two flat pins. It looks like a bulb and removable socket, but it isn't. Just a way to cost you more. The bulb is removable from the top where it's mounted, and removed from the hole that it sticks vertically down thru. 1. You have to remove the unit cover to get to the bulb. 2. You have to unplug the connector to remove the bulb. 3. You have to squeeze two plastic pins, to extract the bulb from its location. This is not a common bulb; good luck finding one.
Nov 14, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker nite light will turn off
test the switch for defective and replace or clean the contacts. or course your must unpplugged the power before to test.
see the diagram attached.
God bless you
Jul 14, 2012 | Microwave Ovens
Microwave GE MD JVM140K Spacemaker yr= 1994 NOHEAT, DISP/TIMER OK
Call GE answer center 1-800-626-2000
ask for tech help
Have you model # off your data plate ready.
May 10, 2009 | GE Profile Spacemaker Over-the-Range...
Need new light bulb socket for GE spacemaker mircrowave
The bulbs are glued in at the factory. Unplug the microwave and see if you can remove the base of the bulb from the socket with needle nose pliers. You may have to twist the heck out of the bulb base but it should come out. If you do need a new socket it is available at www.geappliances.com under parts and accessories. Or call 1-800-626-2002 for GE factory parts
Dec 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacesaver XL1800 Nite Lite will not go off
The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed
without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site,
linked here on Fixya: http://tinyurl.com/yzjozk
Nov 04, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1490 Convection/Microwave Oven Logo
202 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
