Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
LG LDF6810ST Won't Turn ON
My LG dishwasher won't come on when I push the power button. I checked for power at the box junction box on the dishwasher and have full power.
Note: the dishwasher has been leaking at the bottom left.
Any solutions?
  • 1 more comment
  • homfxr Jan 10, 2009
    I have the same problem with the same unit. I cannot get an answer to why this is happening.
  • rrlr Apr 02, 2009
    The dishwashe rturns on and leaks but It does not allow me to select a cycle and sometimes the cycle lights are very dim
  • chungds Apr 06, 2009
    same-same.  Mine also has a leak on the lower left and the power just won't come on suddenly.  This happened once before and I checked the power and a couple days later it came on.  The other solution was to empty the water out and ensure the drain hose in the rear was lifted up in an "S" curve for proper relief.
    We bought all LG products and swear we will never do so again - they are all ****!
  • 423 Answers
If you are still having the problems you describe and especially is you are getting a leak from the lower left door panel, please provide the model number and the serial number.
There IS help available if you provide the info.
Please report back. Thanks!
Posted on Mar 30, 2009
LG LDF6810ST won't power up there is power going to dishwasher
the main control board is fried from what you've described, you will need to dismantle it and remove the board (there will likely be visible signs of damage if there was a burning smell) relatively easy and cheap to replace
Jan 01, 2017 | LG LDF6810ST Stainless Steel Built-in...
Bosch SHX4605UC/30 dishwasher won't turn on
Since you have power to the dishwasher, check to see if there is a push button reset, there could also be a fuse blown.
Jan 21, 2013 | Dishwashers
Won't turn on
unit will only run on cancel cycle
Jan 29, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
Jenn air dishwasher model JDB3610AWX has no power at the control board please help
Their are a couple possiblities that could be causing that;
1) the connections where the house wiring connects to the dishwasher in of the junction box has burnt, the circuit breaker will very likely be on but the bad/burnt connection wont send power to control.
2) one or both of the door switches on the latch asm. are bad,to check those use a meter set to a low ohms setting and check for ZERO ohms when the door is closed,to check those TURN OFF CIRCUIT BREAKER remove wires from switch(s) and place one meter lead on each terminal
I hope this will help you to figure out why your dishwasher won't come on,
Gene
Aug 06, 2011 | Jenn-Air Dishwashers
I am getting error code PF on my LG LDF6810ST, what does that mean?
PF means power failure. You are having a power supply problem. Check to make sure that the plug is connected properly. Check the junction box on the lower right corner behind the kick plate to make sure the wires are connected properly. If your dishwasher is 5 years or older, remove the front door panel and check the wire harness in the door liner for any broken wires. Good luck
Jun 17, 2011 | LG LDF6810ST Stainless Steel Built-in...
It will not turn on
Check to make sure there is power to the dishwasher at the junction box behind toe kick on the right side. Make sure electrical connections are good there by holding a wire nut and giving each individual wire a firm tug. If problem still persists, diss-assemble inner from outer door and check the door switches. If those are good and power gets all the way to the electronic control board, there should be a red LED light on in the middle of the electronic board. If not, replace board.
Feb 05, 2011 | LG LDF6810ST Stainless Steel Built-in...
Info on replacing seal on LG model LDF6810ST dishwasher
Hi, Jus replaced a door seal for my sister in law... very simple.. just pull out the old one, soak the new one and push it in place...15 minutes tops...
Here is a tip that I wrote about leaking dishwashers
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Apr 22, 2010 | LG LDF6810ST Stainless Steel Built-in...
Kitchenaid Dishwasher KUDS24SEWH?
This problem was aparently classified under the LG dishwasher / LDF6810ST section, I don't think this problem got looked at by KitchenAid gurus.
Were the problems resolved?
Sep 24, 2008 | LG LDF6810ST Stainless Steel Built-in...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
815 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
