Question about Sony KV-27V22 TV
Blank Picture, Sound OK on Sony TV
My 7 year old trinitron, KV-27v22, working great until recently, no longer produces a picture when first turned on. With time and patience we can get the picture on sometimes, but until then we get a blank screen or a picture that flashes or is distorted. Sometimes the red light flashes while the picture is not on, so I assume this may be a power problem. BTW, in the past, sometimes the set was turned off by flicking the main power to the room (a light switch) off rather than turning the set off first. Don't know if this may be a factor. Thanks Pete
    Sergeant:
    Champion:
  • 326 Answers
Hello, there can be a contact problem in power supply, deflection or RGB stage. Please ask the tech to repair it for you. Best regards, Arpi
Posted on Apr 22, 2007
  • Arpad Kothai
    Arpad Kothai Apr 22, 2007
    you can also try this:
    remedy
    Check connections on T501, R533, R536, R537, R551 and D531.
    remedy 2
    Check CN1641 for dry joints.
    remedy 3
    Replace C564 (1uF/50V).
SOURCE:
I have a ten year old 37" Sony XBR TV that works fine until you turn it off and then go to turn it back on. The picture does not come back, but sound does. The only way to solve this is leave it off...
most likely it needs repiars, (replacement of capacitors in the power-supply.)primary and secondary side.
Or loose conections (dry joints)
Apr 20, 2011 | Sony KV-27V22 TV
No picture, sound works on Sony TV KV-27V22.
try to adjust the screen. it is located behind the CRT board.(CRT board is the board that attached to the picture tube) you will find a black knob which label screen adjust it by turning the knob.
Jul 04, 2009 | Sony KV-27V22 TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
No picture no sound
Forward voltage/current problem....needs a new board....You might try unplugging it for a few hours...If the TV starts you will need to leave it on until it gets repaired or replaced.
Jun 12, 2009 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Trinitron color TV model no. kv-27v22
dear, you can check that transformers out put before connecting to a tv. also when its connected to a tv.
get a avo meter and connect in series with a tv.
observe the current on the intial switch on and when the picture goes. if you notice that current on intial switching is high and then it starts going lower and lower, then change the transformer.
but if the current starts going up from the intial current then check the power supply components of the tv.
thanks for asking fixya.
Mar 02, 2008 | Sony KV-27V22 TV
SONY WEGA KV-32XL90E
Hallo, IC MCZ3001D is damage. Cost 30 Euro. Greatings from Germany
Jan 04, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony trinitron KV27V22
Solder any / bad connects horiz,vert and power supply then
try again....................T.
Please rate this solution.........................
Nov 15, 2007 | Sony KV-27V22 TV
Hello, maybe there is a contact error in power supply or the deflection stage. If the resoldering does not help- here are some possible solutions: remedy Replace flyback location LP04. Entered for KV32S22 /SONY (Chassis) remedy 2 Replace IC351, Q602, Q601 (2SC4834M), R607 (1R/0.5W), R622 (10R), IC641 (SI3090CA) and Q502 (2SC5148). remedy 3 Replace tuner. remedy 4 Replace R607, Q502 and IC601. Entered for KV32S22 /SONY (Chassis) remedy 5 Replace regulator IC, R607, check C609, C610 (0.68pF) and C613 (0.0022pF/500V). remedy 6 Replace horizontal output transistor (2SC5148), IC601 (MX0841) and R607 (0.1R). remedy 7 Replace IC1701 and IC601. remedy 8 Replace Q501 (2SC5148), R607 and resolder horizontal driver transformer. remedy 9 Check and replace horizontal output transistor Q502 (2SC5148) and IC601 (MXD8411AB-F). remedy 10 Replace shorted R607. Also check T501 and Q501 for dry joints. remedy 11 Replace C608. remedy 12 Replace Q602 and D648. remedy 13 Replace Q502, Q601, Q602 and R602. Entered for KV32S22 /SONY (Chassis) remedy 14 Replace D626 (6.2V). remedy 15 Replace IC801 and R607. remedy 16 Replace horizontal output transistor and the associated damping capacitor. Check flyback transformer and SMD microprocessor as well. remedy 17 Replace R639 (4.7R/0.250W) located on G board in standby power circuit. remedy 18 Replace D600. remedy 19 Replace C502 (0.47uF/50V). remedy 20 Check D655(1N4937), D657 (1S1834) and Q601 (2SC4423). remedy 21 Check D606 for leakage. remedy 22 Check yoke between vertical and horizontal windings for S/C. remedy 23 Replace Q601 (2SC4834MNP), R607 (0.1R) and C517 (2.2uF/250V). remedy 24 Replace R611.
Apr 22, 2007 | Sony KV-27V22 TV
Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Nov 04, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
203 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
