Question about Meade ETX-80AT-TC Telescope
The telescope doesnt go up it goes down
When i try to align the telescope the telescope instead of going up it goes down.Also when i try to search for a planet i dont see it i just see star.
  • 3,186 Answers
I assume you are using the 497 hand controller? Planets will always be a little bit OFF since their orbits are calculated. You should be able to see Venus, Jupiter, and Saturn as a disk-- the other planets are very tiny and can be mistaken for a star.
Use the Automatic alignment feature and center the brightest nearest star. It will not be in the eyepiece. Be sure you calibrate motors, and train the drives, and the time, and date and site are accurate.
Posted on Dec 27, 2008
First time using the mead etx 60at. I turned it on and set the date / time / enter. Then set it at north and horizontal,enter. It asked if i wanted the easy alignment, I said yes. I said searching. Then it...
Did you lock down BOTH clutches?
You should have Calibrated motors and trained drives before you actually tried to do a goto.
Read this manual completely:
http://www.meade.com/manuals/TelescopeManuals/ETXtelescopes/ETX-60-70AT%20manual.pdf
Aug 21, 2010 | Meade ETX-70 (240 x 70mm) Telescope
Scope is 12.5, 9 years old. We align by going to "named star," selecting one, slewing, correcting, hitting synch. Repeating with another star. Almost always the scope goes to accurately there after. (We...
Runaway DECLINATION is what this is called. Usually it can be fixed with a new hand controller cable. If a new cable does not fix it, then it has a blown motor circuit board and must be returned to Meade for repairs.
Meade customer service:
http://www.meade.com/support/index.html
Aug 18, 2010 | Meade LX200GPS Telescope
I have the Nexstar 8. It will not auto align or manual....
First do a RESET on the hand controller and make sure TIME, DATE, and SITE, are correct.
If this does not work then RE-load the firmware in the hand controller. If that fails contact Celestron customer service.
http://www.celestron.com/c3/page.php?PageID=37
May 15, 2010 | Celestron NexStar 102 SLT 102 mm (4.0)...
Aligning my scope and slewing problems
You need to synchronize the telescope with stellarium. Center the telescope on a known star, then select the same star on the laptiop and 'synch' with it.
Apr 14, 2010 | Celestron NexStar 102 SLT 102 mm (4.0)...
You must set TIME, DATE, and SITE-- probably does not know your actual location. Read the manual and perform all of the setup procedures.
Some of these have a "starting position" again read the manual and make sure you are in the "home" position before you start the alignment. Read my TIP on my profile page about GOTO telescopes, and join the NEXSTAR forum on www.cloudynights.com
Mar 27, 2010 | Celestron NexStar 102 SLT 102 mm (4.0)...
I can go through the Sky Align procedure and the telescope will not find an object for which it has been tasked (ie. the Moon). I have triple checked the time, lat/long, etc. and still no luck after many...
Is the mount level? Did you center both alignment stars?
Are you running it off of fresh batteries or an outside power pack? 10 degrees sounds like Daylight Savings time is set to YES instead of Standard Time.
Dec 28, 2009 | Celestron NexStar 130 SLT (306 x 130mm)...
I have been given a tasco telescope 49t-e i have no user manual (have not got a clue what goes where ... please help!
Here is a link to a Meade telescope similar to your telescope. They all go together pretty much the same way.
http://www.meade.com/manuals/m285/index.html
You apparently have a refractor on an equatorial mount. You must learn how to POLAR ALIGN the telescope on Polaris to use the telescope. I do not recommend equatorial mounts to beginners.
Read this:
http://www.astromax.org/faq/p-align.htm
Nov 04, 2009 | Optics
GoTo Problem
Be sure that the telescope is configured for EQ SOUTH mode to tell it is in the southern hemisphere. Once a star alignment is completed NEVER manually move the telescope. Use only the control panel to slew. Everytime the telescope is move by hand, the motors do not know it has been done, and assume it is still pointing at the old direction. Check the manual for setup.
Here: http://www.celestron.com/c3/images/files/downloads/NexStar_SLT_manual.pdf
Apr 06, 2008 | Celestron NexStar 130 SLT (306 x 130mm)...
Meade DS-2114 ATS LNT
Also had the problem. I found that the LNT did not find north unless the bottom of the Smartfinder is close to parallel with the ground.
Oct 11, 2007 | Meade DS-2114 ATS (325 x 114mm) Telescope
Optics Logo
138 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
