Question about Whirlpool GU2400XTP Built-in Dishwasher
My whirlpool gold silent partner III is leaking fro the bottom.
It leaks from the bottom near the back left area, not the water supply connection. What could be the source? from inside the washer it looks like it's coming from where the heating element comes up into the inside of the washer, left side back. Could those washers go bad? is it a possible fix? Thanks- Jon
SOURCE: whirlpool gold- quiet partner III
I had a similar problem. So I bought a new computer for it. It didn't fix the problem. It turned out to be the button pannel. With all of moisture surrounding it steam go into the buttons and caused all kinds of faulse info that the computer could not interpt. Had to buy new button pannel and problem was fixed.
Posted on Mar 29, 2008
  • 14 Answers
SOURCE: Whirlpool Gold quiet partner III, leaves dirty, greasy dishes
Ifixall is correct. I also learned several things with the apartment buildings I maintain.
1. the screen or pump trap must also be cleaned regularly to make sure there is no debris, food etc stuck in there.
2. The spray arms must be free of debris or obstructions.
3. Jet dry solution must be filled or has some solution in it.
4. Water must be hot
5. Scraping dishes and prewash them before putting them into dishwasher.
6 install water softner sometimes helps. (I don't know how true this is, since I am unable to do this in our buildings)
7 drain line must be picked up, or secured to prevent backwash.
8. MAKE sure that the lower rack is not obstructing the sprayer arms. Sometimes overloading dishwashers will cause dishes not being cleaned properly.
9. if all else fails, a service technician can come out to determine if the dishwasher is operating properly.
Posted on May 24, 2008
tzweeb
  • 318 Answers
SOURCE: lock light will not go off
what you have to do is push and hold, i believe, the air/heat dry button for 5 seconds and that should change the control from lock to unlocked.
look for a "lock" symbol under the button and thats the one that you have to hold in on.
it may not be the air dry button but there will be one that does have the symbol.
Posted on Jan 04, 2009
appldoctom
  • 311 Answers
SOURCE: Whirlpool gold Quiet Partner III is really loud.
now you'll be able too hear under the tub if motor bearing was the noise.put a long tool to the motor and close to you ear,see if that gives you a clue[i don't want you to give up on it if its not the motor]if was to buy that motor wholesale it would be around 50 bucks or so ,retail about 100 or so.so if replacing depends on the shape of the rest of the unit.[i have sold and installed many]new dishwasher on sale 300$ or so,plus your time to install.but if new its a forsure thing.so depends how much motor,how sure you are wiill solve problem,what shape unit in.hope that helps. God bless ,tom
Posted on Jan 12, 2009
SOURCE: won't full cycle.
Ok. Mine has started working again somewhat. I ran a rinse cycle and the pump motor started working again. I then drained it, and started a regular cycle and it's working again for now. The motor still does not sound right though.
Posted on Mar 23, 2009
Cabrio model WTW824OYWO . is leaking water a from the back at the valves area all hoses and connection ok ..leaks about one to two cups water only sometimes what will cause this ???
If the supply connections are located above the machine inlets, water pressure and gravity may cause leaks, even though all connections are tight. Some manufacturers recommend turning off the supply between washing sessions but I don't think this is practical.
Oct 10, 2016 | Whirlpool Washing Machines
Water leaking about once a week from french door fridge
Look in back on the bottom left in the area below the compressor at the plastic drain pan. Most likely it's cracked
Jan 03, 2011 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool Dishwasher GU1500XTL Leaking from wash motor
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
q3taga
Aug 31, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold Quiet Partner Dishwasher - Leaking!
Hello Summers2Go! We are terribly sorry to hear of your concern with your Whirlpool Dishwasher. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Summers2Go), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool 24 in. GU2500 XTP Built-in...
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool dishwasher leaks everywhere
CHECK YOUR HOSES FOR CRACKS. BE SURE THEY ARE ATTACHED SECURELY TO THE PUMP OULET.
THERE IS ALSO A BLACK HOSE FROM THE VALVE THAT GOES UP THE LEFT SIDE TO A VACUUM BREAK ON THE SIDE OF THE TUB. BE SURE THE HOSE HASN'T BEEN DAMAGED OR DISCONNECTED. IF THERE IS SUFFICIENT SUPPLY HOSE, PULL THE DISHWASHER OUT OF IT'S INSTALLATION AND TURN IT ON. WATCH FOR WATER DRIPPING ON THE FLOOR AND TRACE IT BACK TO FIND THE PROBLEM.
Mar 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GU2400XTP Built-in Dishwasher Logo
152 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
