Question about Rosetta Stone Chinese Mandarin Level I & II Set Personal (chilspe)
Headset Problem Rosetta Stone
I set up the headset in the setup application (speak "1,2,3,4,5") and it works perfectly. Then when I go to my lesson, I can hear but the system does not know I am talking. Like it's muted.
  • Anonymous Mar 17, 2009
    I have the same problem. The error from Rosetta Stone is "There was a minor problem", you hit OK and go ahead, but then the mic is mute.
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Posted on May 07, 2009
  • polgera77
    polgera77 Jan 22, 2012
    Tried the given solution but it still does not hear my voice. It was working, I set it down and came back and it was not working.
  • sesshomaru38
    sesshomaru38 Jul 30, 2012
    Mine is like that too, I don't know how to fix it and it's extremely bothersome...
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Rosetta Stone Expert
  • 37 Answers
You get this problem for two reasons.
1. Sound settings in computer
2. Rosetta Stone settings
This link might help you to resolve this issue Questions Rosetta Stone Community
Posted on Dec 27, 2014
I had this same problem with my Windows 7 and Rosetta Stone 4. I discovered the problem may be solely with Windows as there is now a provision to improve VOIP that interferes with RS. I went to the Control Panel and in Sound clicked on the Communications tab and clicked on "Do nothing" When Windows detects Communication activity. The mic is now working perfectly.
Posted on Aug 07, 2012
  • Malcolm Gaissert
    Malcolm Gaissert Sep 02, 2012
    The above worked for a few days, but I worked harder.
    The problem in Vista and Windows 7 is the Microphone Boost function. Go to "Control Panel", click on "Sound", click on the tab "Recording". Right click on the default "Mic" setting menu, on the Menu that pops up, click on "Properties". Click on the Tab "Levels", using the mouse set the Microphone Boost to +10.0 dB. Click on Apply if you can, then OK out of the menus. Best of Luck Malcolm
Fatal error code 2124 on Rosetta stone
There is file called tracking.db3 which gives us lot of error like 2124, 5611, 2123 etc.... you can find a perfect fix at Questions Rosetta Stone Community
Jan 03, 2012 | Rosetta Stone 1, 2, 3, 4 & 5 Set English...
I have a Rosetta Stone V 3.4.5 and Win Xp. Rosetta Stone doesnt recognize the mic. What can I do to fix this error. The number of th error is 1117. My OS is Win Xp Waiting for help Alex
Create a security exception. 1. In ESET NOD32 (Smart Security 5), click Setup.
2. On the Setup screen, click Enter advanced setup... (bottom of screen).
3. On the Advanced setup screen, open Computer -> Antivirus and antispyware -> Exclusions.
4. Click Add , locate/select the Rosetta Stone Version 3 executable, then click OK. (In my case, the executable was in the C:\Program Files (x86)\Rosetta Stone Version 3 folder.)
5. Click OK on the Advanced setup screen.
Set the Rosetta Stone compatibility mode. 1. Right click the Rosetta Stone desktop icon or Start -> All programs -> Rosetta Stone.
2. Select Properties from the list.
3. Select the Compatibility tab.
4. Check the Run this program in compatibility mode box.
5. In the list below the check box, select the OS (in my case, Windows 7).
6. Click OK.
Sep 23, 2011 | Rosetta Stone Spanish (Latin American) -...
I fave a microphone in my web camera. And Rosetta Stone detects it. But I can't pass the microphone setup before a leson. I can speak for hours, but Rosetta Stone doesn't stop the checking. However it can...
I solved by going to Control Panel, Sound, Recording, then click on your mic and click on Configure, and then Set up microphone... Thats probably going to fix your problem... That easy... xD
Apr 04, 2010 | Rosetta Stone V3 English (U.K.) Level 3...
Wiring broke for all five wires in the usb connection of a Rosetta Stone Head Set 20090205. I may be able to re-attach. Where do the wires go on the usb plug?
Open the plug case by prying it apart.
The tiny circuit board is labelled on one side - three connectors for the headset and two for the microphone.
G - headset ground - red/gold wire
R - headset right - blue wire
L - heasdet left - red wire
M+ - microphone + - green wire
M- - microphone - gold wire.
Use hot soldering iron to 'melt' off the tip of the wire coating and apply tiny amount of solder. Place wire in position and solder together.
Finally use electircal tape to hold the plug covers together and continue to tape along the cable so it will not pull out again.
Jan 17, 2010 | Rosetta Stone Spanish Level 1-2-3 Full...
Rosetta Stone Microphone Not Found
This worked for me:
1) Right click on the Rosetta Stone icon in the Start menu
2) Click the "Compatibility" tab
3) Set it to run in compatibility mode with Windows Vista SP2 (mine was defaulted to run in XP compatibility mode, which seemed to be the problem)
4) Start the program again, if you are lucky all mics will now show up
Jan 13, 2010 | Rosetta Stone V3 English (U.K.) Level 3...
RS V3 Error 1117 - does not detect microphone
I have finally found a solution! I found it by chance on the rosetta stone troubleshooting page. I have nod 3 antivirus + firewall and in the firewall settings the rosetta stone application was blocked (it was denied internet access). I just deleted it from the list and the next time rosetta stone asked for internet access I clicked yes. Now rosetta stone detects both my dynamic microphone and my usb headset and it works fine. Hope this works for everybody.
Jul 16, 2009 | Rosetta Stone Spanish (Latin American) -...
Microphone will not pass setup
Jun 21, 2009 | Rosetta Stone Spanish (Latin American) -...
Rosetta stone won't recognize my logitech headset
Make sure that your device is set as your default device by making sure that there is a green check mark next to the device. If not, right click and select "set as default device" (or something like that... I have vista and not win7)
If that does not work, right click on the headphones and go to "Properties" then go and under the "General" tab, change the name of the device to "Microphone HS" For some reason, Rosetta Stone does not recognize the headset unless it has the word "Microphone" in its name... Kinda stupid if you ask me. Hope that helps...
Jun 15, 2009 | Rosetta Stone V3 Spanish (Latin America)...
I tripped and ripped headset cord out of usb port leaving plug in
I don't need assistance like your Premium Plan! I need to find a replacement for my headset specific for the Rosetta Stone program.
Mar 22, 2009 | Rosetta Stone Italian Level I and II...
Rosetta Stone Chinese Mandarin Level I & II Set Personal (chilspe) Logo
7,860 people viewed this question
Top Rosetta Stone Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
vince
k24674
Are you a Rosetta Stone Computer and Internet Expert? Answer questions, earn points and help others
