Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
How high should you mount a 42" flat screen from the floor?
How high from floor
  • Sharp Master
  • 19,396 Answers
Depends on where you sit to watch TV.
Usually the view angle must be between 20 and 30''.
Sit on the couch or on the chair and verify at what height you can watch the TV confortably enough.
See also
Introduction to Wall Mounting a Flat Panel LCD or Plasma TV
How to Mount a Flat Panel TV -
Posted on Dec 28, 2008
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
Lg 42lg50 42 hdtv lcd
It appears to be a "Bad Capacitor"
There are usually 5 of them on the mother board.
I would replace all 5 but you can also just replace the bad one.
They are small cylinder shaped components that are up to an inch long maybe 1/8th to 1/4 inch diameter.
They Black, light green etc,
You can usually tell that they are blown by looking at the top of them. It should be flat with a plus sign etched across it's aluminum cap.
If it is blown; it will be "Bulging" out of the top.
They are mounted with "high temp solder"
I did not mention how to access the mother board because these flat screened TV's vary in the way that they open up.
This capacitors generally cost from 1-5 bucks.
Good Luck! I hope this helps!
Oct 27, 2013 | LG 42LG50 42 in. LCD HDTV
My screen broke moving on my sony flat screen. Tv
I would try contacting<a href="http://www.tvvideorepairil.com">flat screen tv repair in Chicago, IL</a> because that's where I went when mine broke.
Oct 03, 2013 | Universal 40-42 Inch Flat Screen Panel...
CAN YOU PLIZ HELP ME FIX MY TV
Press the AV button on the remote control. If it do not help you, make it a hard reset.
May 28, 2013 | Universal 40-42 Inch Flat Screen Panel...
How to use universal remote control 22E
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 17, 2013 | Universal 40-42 Inch Flat Screen Panel...
I have a 42" Toshiba flat screen. It was a floor
Electronics stores don't sell bases for TVs.
Each TV comes with one base, each base comes with a TV. The only way to get a replacement base would be to contact Toshiba and ask them directly for a replacement. For this to work, you'd need the model number of the tv. This can generally be found when you look at the back of the TV, it will have the label on a small sticker somewhere on the back.
Once you have the model number, try doing a quick search on Ebay. Someone may have an old base there that they no longer need, otherwise you're stuck with a wall mount or with contacting Toshiba.
Mar 10, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I have a flat screen with no stand
pc world have a universal wall mount that will work or ask youre local ironmongers the can normally make you one
May 04, 2010 | NEC PlasmaSync 42MP2 42 in. Television
Samsung projection 42 in. floor model, powers on
tv is in shutdown, drawing to much current. usually focus or high voltage divider (sometimes they are one). not usually the power supply.
Jul 05, 2009 | Samsung Televison & Video
46 sony bravia Lcd tv on a articulating wall mount Whats a Good hight floor to bottom of the tv
The ideal height would be between 38" and 42". with your stand being 42" high I would say 45" would be fine. Anything over 50" off the floor will put strain on your neck and give you constant headaches after watching for extended periods of time.
May 17, 2008 | Sony BRAVIA KDL-46V3000 Television
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
1,865 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
