Question about Hotpoint RB787 Electric Kitchen Range
Electrical requirements for stove
Need to know the electircal requirements for stove
  • 59 Answers
240 volts of AC power
Posted on Dec 28, 2008
Do I need special electrical outlet?
You need to check with a licensed electrician for your area that would know the electrical codes. Most houses will all ready have an outlet for the stove and you will have to match it up with for the cord on your stove. Older homes that have not upgraded the electrical, typically will have a 3 wire outlet for the stove. Most newer homes, where the code requires, may have a 4 wire outlet. If you are replacing an existing stove I would recommend getting a new pigtail cord for the new stove so that you have new wires carrying the current instead of trusting old wires. Hope this helps!
Mar 20, 2015 | Ovens
Stove Manuals. My electric cooker is named STOVES 720ef. I dont know how to work it
You're in luck.
I have just uploaded a scanned copy of the manual to the link below.
Requires an Adobe Acrobat reader to view the manual which most computers have.
This address is below:-
http://wl.filegenie.com/~simun/Stoves720EF.pdf
Please share this file with others who need it.
Kind Regards,
Simon
Oct 28, 2011 | Stoves 720EF Electric Double Oven
How do I know if my stove is three fase. I am in Brazil and the here power is 220v. Would you help please?
Your oven is 2 phase 220 volt not sure about foreign electrical service.The stove requires 2 phase electric service,each leg impute can be no more than 135 volts.It requires 2 pole 60 amp service with no less than a 8 gauge 3 wire service line with ground.The pigtail on the stove is as follows,black wire 120 volt leg red wire the other 120 volt leg the white wire is the neutral leg,(which is sometimes run to the ground block which incorrect but will work) the green wire is ground.
Jun 13, 2011 | Whirlpool Stove Oven Sensor 8053344
I would like to know how to adjust the stove so that it sits level ?
Most stoves of this type have both wheels and screw adjusted levellers (generally in the front only).
The lower drawer opens to reveal these in the corners or a loose clip-on front panel needs to be removed by gentle pulling. The knurled wheel like knobs are generally turned anti-clockwise (Right to Left as you face the stove) to screw out and thereby lift the stove front up to suit your requirements. Good Luck.
Sep 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Correct wire gauge and circuit breaker to use?
If it is only the oven that is electric and not the entire stove, the required wire size is 10/3 with ground and a 30AMP circuit breaker. If it is the entire stove then you need 50AMP range cable and a 50AMP breaker. If your doing your microwave also, you need a 20AMP breaker and the wire you need is 12/2 with ground.. If the current breaker you were running was 30AMP I would keep that for your oven and run new wire for your microwave.
Feb 23, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
I have a GE electirc stove JDP37GT1Bb The blower that cools the oven doesn't turn off at all
If that blower that cools the oven is auto run and off automatically, then maybe the thermostat that controlling it, was damaged.
May 31, 2009 | GE JBP30 Electric Kitchen Range
Gas Safety
this is actually how every gas stove is set up and yes it would be a safety issue but there is really no way to change how they work i do wish the people building them would do it with at least a timer or something but that would make the product much more expensive. same type of technology is also used on propane bbq grills btw. it is just something you get used to after a while i have had gas for the last ten years and dont even notice it now
May 15, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Instruction manuel required for stoves 720ef
I have a user guide and as I said on another post I will try and scan it so that anyone can have a copy. In the meantime, is there anything you need to know?
Jan 01, 2009 | Stoves 720EF Electric Double Oven
Need electrical information for electrician to install new power
THE NEC NOW REQUIRES YOU TO INSTALL A 4 PRONG PLUG 10-4-WG WIRE CONNECTED TO A 30 AMP DOUBLE POLE BREAKER THE PIG TAIL ON THE NEW STOVE MUST MATCH THE PLUG SO THE ONE OFF OF THE OLD STOVE WILL NOT WORK GET THE 4 PRONG PLUG AS WELL THE WALL PLUG WILL BE EITHER A FLUSH MOUNT OR A SURFACE MOUNT AS TO SAY IN THE WALL OR ON THE BASEBOARD SURFACE REPLACE WITH THE SAME AS YOU HAD BEFORE IT IS LESS TROUBLE IN THE LONG RUN THIS SHOULD ANSWER ALL THE QUESTIONS THE ELECTRICIAN NEEDS TO KNOW IF NOT LET ME KNOW
Dec 01, 2008 | Jenn-Air JDS8850 Dual Fuel (Electric and...
How to connect a 220 stove with 2 110 cables
cannot be done you would be using the same side of the line and it would be a direct short
Apr 27, 2008 | Kitchen Ranges
Hotpoint RB787 Electric Kitchen Range Logo
109 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
